Hi Matt,
please find log below log. issue happened between 21:22:00 - 21:24:00. i turned on movie scene and all devices took long to respond. In fact, between the series of commands, there was 3 - 5 sec delay. appreciate all your help.
2021-05-03 21:09:53.071 INFO ZWAVE: Node 31: value updated: 50-0-value-66049 0 => 0
2021-05-03 21:09:54.708 INFO ZWAVE: Node 44: metadata updated: 49-0-Air temperature
2021-05-03 21:09:54.711 INFO ZWAVE: Node 44: value updated: 49-0-Air temperature 22.4 => 22.3
2021-05-03 21:09:54.819 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:09:54.822 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 65 => 64
2021-05-03 21:10:08.026 INFO ZWAVE: Node 51: value updated: 50-0-value-66561 238.17 => 235.059
2021-05-03 21:10:08.309 INFO ZWAVE: Node 51: value updated: 50-0-value-66817 5.785 => 5.716
2021-05-03 21:10:08.590 INFO ZWAVE: Node 51: value updated: 50-0-value-66049 790.703 => 768.71
2021-05-03 21:10:08.871 INFO ZWAVE: Node 51: value updated: 50-0-value-65537 296.588 => 296.601
2021-05-03 21:11:08.027 INFO ZWAVE: Node 51: value updated: 50-0-value-66561 235.059 => 234.773
2021-05-03 21:11:08.311 INFO ZWAVE: Node 51: value updated: 50-0-value-66817 5.716 => 5.7
2021-05-03 21:11:08.591 INFO ZWAVE: Node 51: value updated: 50-0-value-66049 768.71 => 761.084
2021-05-03 21:11:08.872 INFO ZWAVE: Node 51: value updated: 50-0-value-65537 296.601 => 296.613
2021-05-03 21:11:13.000 INFO ZWAVE: Node 15: value updated: 50-1-value-65537 12.51 => 12.55
2021-05-03 21:11:19.931 INFO ZWAVE: Node 20: metadata updated: 49-1-Power
2021-05-03 21:11:19.935 INFO ZWAVE: Node 20: value updated: 49-1-Power 33 => 33.2
2021-05-03 21:11:54.709 INFO ZWAVE: Node 44: metadata updated: 49-0-Air temperature
2021-05-03 21:11:54.715 INFO ZWAVE: Node 44: value updated: 49-0-Air temperature 22.3 => 22.3
2021-05-03 21:11:54.818 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:11:54.822 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 64 => 65
2021-05-03 21:12:08.027 INFO ZWAVE: Node 51: value updated: 50-0-value-66561 234.773 => 233.63
2021-05-03 21:12:08.311 INFO ZWAVE: Node 51: value updated: 50-0-value-66817 5.7 => 5.729
2021-05-03 21:12:08.592 INFO ZWAVE: Node 51: value updated: 50-0-value-66049 761.084 => 770.919
2021-05-03 21:12:08.872 INFO ZWAVE: Node 51: value updated: 50-0-value-65537 296.613 => 296.627
2021-05-03 21:13:08.027 INFO ZWAVE: Node 51: value updated: 50-0-value-66561 233.63 => 234.768
2021-05-03 21:13:08.311 INFO ZWAVE: Node 51: value updated: 50-0-value-66817 5.729 => 5.724
2021-05-03 21:13:08.591 INFO ZWAVE: Node 51: value updated: 50-0-value-66049 770.919 => 772.672
2021-05-03 21:13:08.872 INFO ZWAVE: Node 51: value updated: 50-0-value-65537 296.627 => 296.64
2021-05-03 21:13:23.039 INFO ZWAVE: Node 51: value updated: 50-1-value-66561 236.417 => 234.612
2021-05-03 21:13:23.331 INFO ZWAVE: Node 51: value updated: 50-2-value-66561 249.467 => 248.475
2021-05-03 21:13:23.623 INFO ZWAVE: Node 51: value updated: 50-3-value-66561 236.465 => 242.19
2021-05-03 21:13:23.915 INFO ZWAVE: Node 51: value updated: 50-1-value-66817 0.822 => 0.825
2021-05-03 21:13:24.498 INFO ZWAVE: Node 51: value updated: 50-2-value-66817 2.445 => 2.444
2021-05-03 21:13:24.790 INFO ZWAVE: Node 51: value updated: 50-3-value-66817 2.262 => 2.45
2021-05-03 21:13:25.081 INFO ZWAVE: Node 51: value updated: 50-1-value-66049 127.635 => 127.832
2021-05-03 21:13:34.041 INFO ZWAVE: Node 51: value updated: 50-3-value-66049 324.42 => 374.848
2021-05-03 21:13:34.331 INFO ZWAVE: Node 51: value updated: 50-1-value-65537 52.948 => 52.98
2021-05-03 21:13:34.947 INFO ZWAVE: Node 51: value updated: 50-2-value-65537 218.01 => 218.078
2021-05-03 21:13:35.240 INFO ZWAVE: Node 51: value updated: 50-3-value-65537 25.486 => 25.582
2021-05-03 21:13:38.756 INFO ZWAVE: Node 8: metadata updated: 49-0-Air temperature
2021-05-03 21:13:38.761 INFO ZWAVE: Node 8: value updated: 49-0-Air temperature 29.9 => 29.8
2021-05-03 21:13:39.137 INFO ZWAVE: Node 8: metadata updated: 49-0-Air temperature
2021-05-03 21:13:39.142 INFO ZWAVE: Node 8: value updated: 49-0-Air temperature 29.8 => 29.8
2021-05-03 21:13:39.299 INFO ZWAVE: Node 8: metadata updated: 49-0-Air temperature
2021-05-03 21:13:39.302 INFO ZWAVE: Node 8: value updated: 49-0-Air temperature 29.8 => 29.8
2021-05-03 21:13:39.447 INFO ZWAVE: Node 8: metadata updated: 49-0-Air temperature
2021-05-03 21:13:39.450 INFO ZWAVE: Node 8: value updated: 49-0-Air temperature 29.8 => 29.8
2021-05-03 21:13:39.870 INFO ZWAVE: Node 8: metadata updated: 49-0-Air temperature
2021-05-03 21:13:39.872 INFO ZWAVE: Node 8: value updated: 49-0-Air temperature 29.8 => 29.8
2021-05-03 21:13:47.897 INFO ZWAVE: Node 27: value updated: 50-1-value-66049 0 => 0
2021-05-03 21:13:54.707 INFO ZWAVE: Node 44: metadata updated: 49-0-Air temperature
2021-05-03 21:13:54.710 INFO ZWAVE: Node 44: value updated: 49-0-Air temperature 22.3 => 22.3
2021-05-03 21:13:54.818 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:13:54.820 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 65 => 65
2021-05-03 21:13:58.947 INFO ZWAVE: Node 8 is now awake
2021-05-03 21:14:00.042 INFO ZWAVE: Node 8 is now asleep
2021-05-03 21:14:01.095 INFO ZWAVE: Node 29: value updated: 50-0-value-66049 0 => 0
2021-05-03 21:14:02.760 INFO ZWAVE: Node 24: value updated: 50-1-value-66049 0 => 0
2021-05-03 21:14:02.832 INFO ZWAVE: Node 24: value updated: 50-2-value-66049 0 => 0
2021-05-03 21:14:08.027 INFO ZWAVE: Node 51: value updated: 50-0-value-66561 234.768 => 237.339
2021-05-03 21:14:08.310 INFO ZWAVE: Node 51: value updated: 50-0-value-66817 5.724 => 7.055
2021-05-03 21:14:08.592 INFO ZWAVE: Node 51: value updated: 50-0-value-66049 772.672 => 1396.091
2021-05-03 21:14:08.872 INFO ZWAVE: Node 51: value updated: 50-0-value-65537 296.64 => 296.653
2021-05-03 21:14:46.655 INFO ZWAVE: Node 30: value updated: 50-0-value-66049 0 => 0
2021-05-03 21:15:08.028 INFO ZWAVE: Node 51: value updated: 50-0-value-66561 237.339 => 237.604
2021-05-03 21:15:08.311 INFO ZWAVE: Node 51: value updated: 50-0-value-66817 7.055 => 6.804
2021-05-03 21:15:08.592 INFO ZWAVE: Node 51: value updated: 50-0-value-66049 1396.091 => 1339.003
2021-05-03 21:15:08.872 INFO ZWAVE: Node 51: value updated: 50-0-value-65537 296.653 => 296.675
2021-05-03 21:15:15.284 INFO ZWAVE: Node 45 is now awake
2021-05-03 21:15:16.391 INFO ZWAVE: Node 45 is now asleep
2021-05-03 21:15:42.464 INFO ZWAVE: Node 47: metadata updated: 49-0-Air temperature
2021-05-03 21:15:42.467 INFO ZWAVE: Node 47: value updated: 49-0-Air temperature 21.1 => 20
2021-05-03 21:15:54.705 INFO ZWAVE: Node 44: metadata updated: 49-0-Air temperature
2021-05-03 21:15:54.708 INFO ZWAVE: Node 44: value updated: 49-0-Air temperature 22.3 => 22.4
2021-05-03 21:15:54.816 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:15:54.819 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 65 => 66
2021-05-03 21:16:08.028 INFO ZWAVE: Node 51: value updated: 50-0-value-66561 237.604 => 237.698
2021-05-03 21:16:08.310 INFO ZWAVE: Node 51: value updated: 50-0-value-66817 6.804 => 6.801
2021-05-03 21:16:08.591 INFO ZWAVE: Node 51: value updated: 50-0-value-66049 1339.003 => 1341.861
2021-05-03 21:16:08.872 INFO ZWAVE: Node 51: value updated: 50-0-value-65537 296.675 => 296.697
2021-05-03 21:17:08.027 INFO ZWAVE: Node 51: value updated: 50-0-value-66561 237.698 => 238.575
2021-05-03 21:17:08.428 INFO ZWAVE: Node 51: value updated: 50-0-value-66817 6.801 => 6.788
2021-05-03 21:17:08.709 INFO ZWAVE: Node 51: value updated: 50-0-value-66049 1341.861 => 1344.955
2021-05-03 21:17:09.603 INFO ZWAVE: Node 51: value updated: 50-0-value-65537 296.697 => 296.719
2021-05-03 21:17:54.704 INFO ZWAVE: Node 44: metadata updated: 49-0-Air temperature
2021-05-03 21:17:54.707 INFO ZWAVE: Node 44: value updated: 49-0-Air temperature 22.4 => 22.4
2021-05-03 21:17:54.815 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:17:54.819 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 66 => 67
2021-05-03 21:18:08.027 INFO ZWAVE: Node 51: value updated: 50-0-value-66561 238.575 => 239.074
2021-05-03 21:18:08.311 INFO ZWAVE: Node 51: value updated: 50-0-value-66817 6.788 => 6.985
2021-05-03 21:18:08.591 INFO ZWAVE: Node 51: value updated: 50-0-value-66049 1344.955 => 1398.948
2021-05-03 21:18:08.872 INFO ZWAVE: Node 51: value updated: 50-0-value-65537 296.719 => 296.741
2021-05-03 21:19:08.028 INFO ZWAVE: Node 51: value updated: 50-0-value-66561 239.074 => 235.778
2021-05-03 21:19:08.312 INFO ZWAVE: Node 51: value updated: 50-0-value-66817 6.985 => 5.784
2021-05-03 21:19:08.593 INFO ZWAVE: Node 51: value updated: 50-0-value-66049 1398.948 => 786.407
2021-05-03 21:19:08.875 INFO ZWAVE: Node 51: value updated: 50-0-value-65537 296.741 => 296.761
2021-05-03 21:19:54.704 INFO ZWAVE: Node 44: metadata updated: 49-0-Air temperature
2021-05-03 21:19:54.708 INFO ZWAVE: Node 44: value updated: 49-0-Air temperature 22.4 => 22.4
2021-05-03 21:19:54.815 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:19:54.819 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 67 => 67
2021-05-03 21:20:08.028 INFO ZWAVE: Node 51: value updated: 50-0-value-66561 235.778 => 237.791
2021-05-03 21:20:08.311 INFO ZWAVE: Node 51: value updated: 50-0-value-66817 5.784 => 5.765
2021-05-03 21:20:08.593 INFO ZWAVE: Node 51: value updated: 50-0-value-66049 786.407 => 778.879
2021-05-03 21:20:08.875 INFO ZWAVE: Node 51: value updated: 50-0-value-65537 296.761 => 296.774
2021-05-03 21:20:58.749 INFO ZWAVE: Node 17: value updated: 37-1-currentValue true => false
2021-05-03 21:20:59.012 INFO ZWAVE: Node 17: value updated: 50-1-value-66049 34.1 => 0
2021-05-03 21:21:08.029 INFO ZWAVE: Node 51: value updated: 50-0-value-66561 237.791 => 238.297
2021-05-03 21:21:08.313 INFO ZWAVE: Node 51: value updated: 50-0-value-66817 5.765 => 5.723
2021-05-03 21:21:08.595 INFO ZWAVE: Node 51: value updated: 50-0-value-66049 778.879 => 744.236
2021-05-03 21:21:08.877 INFO ZWAVE: Node 51: value updated: 50-0-value-65537 296.774 => 296.788
2021-05-03 21:21:54.703 INFO ZWAVE: Node 44: metadata updated: 49-0-Air temperature
2021-05-03 21:21:54.708 INFO ZWAVE: Node 44: value updated: 49-0-Air temperature 22.4 => 22.5
2021-05-03 21:21:54.942 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:21:54.945 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 67 => 66
2021-05-03 21:22:08.218 INFO ZWAVE: Node 51: value updated: 50-0-value-66561 238.297 => 237.59
2021-05-03 21:22:08.500 INFO ZWAVE: Node 51: value updated: 50-0-value-66817 5.723 => 5.771
2021-05-03 21:22:08.781 INFO ZWAVE: Node 51: value updated: 50-0-value-66049 744.236 => 758.937
2021-05-03 21:22:09.061 INFO ZWAVE: Node 51: value updated: 50-0-value-65537 296.788 => 296.8
2021-05-03 21:22:59.549 INFO ZWAVE: Node 47 is now awake
2021-05-03 21:23:00.142 INFO ZWAVE: Node 47: value updated: 132-0-wakeUpInterval 21600 => 21600
2021-05-03 21:23:00.146 INFO ZWAVE: Node 47: value updated: 132-0-controllerNodeId 1 => 1
2021-05-03 21:23:01.168 INFO ZWAVE: Node 18: value updated: 38-1-currentValue 10 => 0
2021-05-03 21:23:01.484 INFO ZWAVE: Node 47 is now asleep
2021-05-03 21:23:01.884 INFO ZWAVE: Node 18: metadata updated: 49-1-Power
2021-05-03 21:23:01.888 INFO ZWAVE: Node 18: value updated: 49-1-Power 38.5 => 15.9
2021-05-03 21:23:08.033 INFO ZWAVE: Node 51: value updated: 50-0-value-66561 237.59 => 238.846
2021-05-03 21:23:08.315 INFO ZWAVE: Node 51: value updated: 50-0-value-66817 5.771 => 5.402
2021-05-03 21:23:08.597 INFO ZWAVE: Node 51: value updated: 50-0-value-66049 758.937 => 719.013
2021-05-03 21:23:08.877 INFO ZWAVE: Node 51: value updated: 50-0-value-65537 296.8 => 296.812
2021-05-03 21:23:12.901 INFO ZWAVE: Node 18: metadata updated: 49-1-Power
2021-05-03 21:23:12.904 INFO ZWAVE: Node 18: value updated: 49-1-Power 15.9 => 0
2021-05-03 21:23:12.953 INFO ZWAVE: Node 19: value updated: 37-1-currentValue true => false
2021-05-03 21:23:13.184 INFO ZWAVE: Node 19: value updated: 50-1-value-66049 11.8 => 0
2021-05-03 21:23:45.400 INFO ZWAVE: Node 19: value updated: 37-1-currentValue false => false
2021-05-03 21:23:45.519 INFO ZWAVE: Node 18: value updated: 38-1-currentValue 0 => 0
2021-05-03 21:23:45.699 INFO ZWAVE: Node 18: value updated: 38-1-currentValue 0 => 0
2021-05-03 21:23:45.946 INFO ZWAVE: Node 31: value updated: 37-0-currentValue false => false
2021-05-03 21:23:46.193 INFO ZWAVE: Node 20: value updated: 38-1-currentValue 99 => 0
2021-05-03 21:23:46.441 INFO ZWAVE: Node 21: value updated: 37-1-currentValue true => false
2021-05-03 21:23:46.581 INFO ZWAVE: Node 21: value updated: 37-1-currentValue false => false
2021-05-03 21:23:46.611 INFO ZWAVE: Node 15: value updated: 38-1-currentValue 15 => 0
2021-05-03 21:23:46.882 INFO ZWAVE: Node 21: value updated: 50-1-value-66049 13.3 => 0
2021-05-03 21:23:46.901 INFO ZWAVE: Node 15: value updated: 38-1-currentValue 0 => 0
2021-05-03 21:23:48.265 INFO ZWAVE: Node 15: metadata updated: 49-1-Power
2021-05-03 21:23:48.268 INFO ZWAVE: Node 15: value updated: 49-1-Power 42.6 => 25.3
2021-05-03 21:23:51.833 INFO ZWAVE: Node 19: value updated: 37-1-currentValue false => false
2021-05-03 21:23:51.871 INFO ZWAVE: Node 19: value updated: 50-1-value-66049 0 => 0
2021-05-03 21:23:52.114 INFO ZWAVE: Node 19: value updated: 37-1-currentValue false => false
2021-05-03 21:23:52.560 INFO ZWAVE: Node 19: value updated: 37-1-currentValue false => false
2021-05-03 21:23:52.728 INFO ZWAVE: Node 29: value updated: 37-0-currentValue false => true
2021-05-03 21:23:52.753 INFO ZWAVE: Node 21: value updated: 50-1-value-66049 0 => 0
2021-05-03 21:23:52.993 INFO ZWAVE: Node 21: value updated: 50-1-value-66049 0 => 0
2021-05-03 21:23:54.167 INFO ZWAVE: Node 31: value updated: 37-0-currentValue false => false
2021-05-03 21:23:54.702 INFO ZWAVE: Node 44: metadata updated: 49-0-Air temperature
2021-05-03 21:23:54.706 INFO ZWAVE: Node 44: value updated: 49-0-Air temperature 22.5 => 22.3
2021-05-03 21:23:54.718 INFO ZWAVE: Node 20: value updated: 38-1-currentValue 0 => 0
2021-05-03 21:23:55.936 INFO ZWAVE: Node 29: value updated: 50-0-value-66049 0 => 7.9
2021-05-03 21:23:56.430 INFO ZWAVE: Node 31: value updated: 37-0-currentValue false => false
2021-05-03 21:23:56.513 INFO ZWAVE: Node 29: value updated: 50-0-value-66049 7.9 => 7.9
2021-05-03 21:23:56.675 INFO ZWAVE: Node 20: metadata updated: 49-1-Power
2021-05-03 21:23:56.679 INFO ZWAVE: Node 20: value updated: 49-1-Power 33.2 => 9.3
2021-05-03 21:23:57.035 INFO ZWAVE: Node 20: value updated: 38-1-currentValue 0 => 0
2021-05-03 21:23:57.272 INFO ZWAVE: Node 15: metadata updated: 49-1-Power
2021-05-03 21:23:57.276 INFO ZWAVE: Node 15: value updated: 49-1-Power 25.3 => 0
2021-05-03 21:23:57.380 INFO ZWAVE: Node 44: metadata updated: 49-0-Air temperature
2021-05-03 21:23:57.384 INFO ZWAVE: Node 44: value updated: 49-0-Air temperature 22.3 => 22.3
2021-05-03 21:23:57.625 INFO ZWAVE: Node 23: value updated: 37-1-currentValue true => false
2021-05-03 21:23:58.045 INFO ZWAVE: Node 20: metadata updated: 49-1-Power
2021-05-03 21:23:58.049 INFO ZWAVE: Node 20: value updated: 49-1-Power 9.3 => 0
2021-05-03 21:23:58.363 INFO ZWAVE: Node 20: metadata updated: 49-1-Power
2021-05-03 21:23:58.368 INFO ZWAVE: Node 20: value updated: 49-1-Power 0 => 0
2021-05-03 21:23:58.508 INFO ZWAVE: Node 44: metadata updated: 49-0-Air temperature
2021-05-03 21:23:58.512 INFO ZWAVE: Node 44: value updated: 49-0-Air temperature 22.3 => 22.3
2021-05-03 21:23:59.129 INFO ZWAVE: Node 29: value updated: 37-0-currentValue true => true
2021-05-03 21:23:59.419 INFO ZWAVE: Node 23: value updated: 37-1-currentValue false => false
2021-05-03 21:23:59.729 INFO ZWAVE: Node 29: value updated: 37-0-currentValue true => true
2021-05-03 21:23:59.803 INFO ZWAVE: Node 44: metadata updated: 49-0-Air temperature
2021-05-03 21:23:59.806 INFO ZWAVE: Node 44: value updated: 49-0-Air temperature 22.3 => 22.3
2021-05-03 21:23:59.873 INFO ZWAVE: Node 44: metadata updated: 49-0-Air temperature
2021-05-03 21:23:59.876 INFO ZWAVE: Node 44: value updated: 49-0-Air temperature 22.3 => 22.3
2021-05-03 21:24:00.043 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:24:00.046 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 66 => 66
2021-05-03 21:24:00.489 INFO ZWAVE: Node 30: value updated: 37-0-currentValue false => false
2021-05-03 21:24:00.660 INFO ZWAVE: Node 19: value updated: 37-1-currentValue false => false
2021-05-03 21:24:00.749 INFO ZWAVE: Node 19: value updated: 37-1-currentValue false => false
2021-05-03 21:24:00.864 INFO ZWAVE: Node 19: value updated: 37-1-currentValue false => false
2021-05-03 21:24:01.073 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:24:01.076 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 66 => 66
2021-05-03 21:24:01.160 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:24:01.163 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 66 => 66
2021-05-03 21:24:01.187 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:24:01.190 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 66 => 66
2021-05-03 21:24:01.539 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:24:01.542 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 66 => 66
2021-05-03 21:24:01.598 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:24:01.602 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 66 => 66
2021-05-03 21:24:01.657 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:24:01.660 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 66 => 66
2021-05-03 21:24:02.219 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:24:02.223 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 66 => 66
2021-05-03 21:24:02.266 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:24:02.269 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 66 => 66
2021-05-03 21:24:02.346 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:24:02.350 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 66 => 66
2021-05-03 21:24:02.546 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:24:02.549 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 66 => 66
2021-05-03 21:24:02.569 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:24:02.572 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 66 => 66
2021-05-03 21:24:02.647 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:24:02.651 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 66 => 66
2021-05-03 21:24:02.920 INFO ZWAVE: Node 23: value updated: 50-1-value-66049 8.8 => 0
2021-05-03 21:24:02.932 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:24:02.934 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 66 => 66
2021-05-03 21:24:02.978 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:24:02.982 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 66 => 66
2021-05-03 21:24:03.033 INFO ZWAVE: Node 23: value updated: 50-1-value-66049 0 => 0
2021-05-03 21:24:03.059 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:24:03.062 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 66 => 66
2021-05-03 21:24:03.798 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:24:03.801 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 66 => 66
2021-05-03 21:24:03.826 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:24:03.828 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 66 => 66
2021-05-03 21:24:03.885 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:24:03.888 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 66 => 66
2021-05-03 21:24:04.059 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:24:04.061 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 66 => 66
2021-05-03 21:24:04.125 INFO ZWAVE: Node 23: value updated: 50-1-value-66049 0 => 0
2021-05-03 21:24:04.414 INFO ZWAVE: Node 23: value updated: 50-1-value-66049 0 => 0
2021-05-03 21:24:04.537 INFO ZWAVE: Node 23: value updated: 50-1-value-66049 0 => 0
2021-05-03 21:24:08.035 INFO ZWAVE: Node 51: value updated: 50-0-value-66561 238.846 => 239.743
2021-05-03 21:24:08.256 INFO ZWAVE: Node 23: value updated: 50-1-value-66049 0 => 0
2021-05-03 21:24:08.458 INFO ZWAVE: Node 51: value updated: 50-0-value-66561 239.743 => 239.743
2021-05-03 21:24:08.739 INFO ZWAVE: Node 51: value updated: 50-0-value-66817 5.402 => 5.869
2021-05-03 21:24:09.028 INFO ZWAVE: Node 51: value updated: 50-0-value-66049 719.013 => 828.538
2021-05-03 21:24:09.310 INFO ZWAVE: Node 51: value updated: 50-0-value-65537 296.812 => 296.825
2021-05-03 21:24:14.797 INFO ZWAVE: Node 12: value updated: 37-0-currentValue true => false
2021-05-03 21:24:16.257 INFO ZWAVE: Node 30: value updated: 37-0-currentValue false => false
2021-05-03 21:24:16.439 INFO ZWAVE: Node 12: value updated: 37-0-currentValue false => false
2021-05-03 21:24:18.309 INFO ZWAVE: Node 12: value updated: 50-0-value-66049 28.9 => 0
2021-05-03 21:24:19.827 INFO ZWAVE: Node 42: value notification: 91-0-scene-003 0
2021-05-03 21:24:19.906 INFO ZWAVE: Node 12: value updated: 37-0-currentValue false => true
2021-05-03 21:24:21.049 INFO ZWAVE: Node 12: value updated: 37-0-currentValue true => true
2021-05-03 21:24:23.870 INFO ZWAVE: Node 12: value updated: 50-0-value-66049 0 => 28.9
2021-05-03 21:24:25.912 INFO ZWAVE: Node 29: value updated: 50-0-value-66049 7.9 => 2.8
2021-05-03 21:24:53.826 INFO ZWAVE: Node 12: value updated: 50-0-value-66049 28.9 => 28.9
2021-05-03 21:25:08.034 INFO ZWAVE: Node 51: value updated: 50-0-value-66561 239.743 => 239.521
2021-05-03 21:25:08.316 INFO ZWAVE: Node 51: value updated: 50-0-value-66817 5.869 => 6.082
2021-05-03 21:25:08.598 INFO ZWAVE: Node 51: value updated: 50-0-value-66049 828.538 => 884.207
2021-05-03 21:25:08.879 INFO ZWAVE: Node 51: value updated: 50-0-value-65537 296.825 => 296.837
2021-05-03 21:25:18.220 INFO ZWAVE: Node 22: value updated: 50-1-value-66049 0 => 0
2021-05-03 21:25:18.296 INFO ZWAVE: Node 22: value updated: 50-2-value-66049 0 => 0
2021-05-03 21:25:54.829 INFO ZWAVE: Node 44: metadata updated: 49-0-Air temperature
2021-05-03 21:25:54.832 INFO ZWAVE: Node 44: value updated: 49-0-Air temperature 22.3 => 22.2
2021-05-03 21:25:54.938 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:25:54.942 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 66 => 66
2021-05-03 21:26:08.032 INFO ZWAVE: Node 51: value updated: 50-0-value-66561 239.521 => 239.55
2021-05-03 21:26:08.457 INFO ZWAVE: Node 51: value updated: 50-0-value-66817 6.082 => 4.871
2021-05-03 21:26:08.738 INFO ZWAVE: Node 51: value updated: 50-0-value-66049 884.207 => 603.22
2021-05-03 21:26:09.028 INFO ZWAVE: Node 51: value updated: 50-0-value-65537 296.837 => 296.848
2021-05-03 21:27:08.035 INFO ZWAVE: Node 51: value updated: 50-0-value-66561 239.55 => 238.653
2021-05-03 21:27:08.318 INFO ZWAVE: Node 51: value updated: 50-0-value-66817 4.871 => 4.867
2021-05-03 21:27:08.599 INFO ZWAVE: Node 51: value updated: 50-0-value-66049 603.22 => 605.328
2021-05-03 21:27:08.882 INFO ZWAVE: Node 51: value updated: 50-0-value-65537 296.848 => 296.86
2021-05-03 21:27:25.882 INFO ZWAVE: Node 42: value notification: 91-0-scene-003 0
2021-05-03 21:27:25.960 INFO ZWAVE: Node 12: value updated: 37-0-currentValue true => false
2021-05-03 21:27:27.108 INFO ZWAVE: Node 12: value updated: 37-0-currentValue false => false
2021-05-03 21:27:29.863 INFO ZWAVE: Node 12: value updated: 50-0-value-66049 28.9 => 0
2021-05-03 21:27:54.701 INFO ZWAVE: Node 44: metadata updated: 49-0-Air temperature
2021-05-03 21:27:54.705 INFO ZWAVE: Node 44: value updated: 49-0-Air temperature 22.2 => 22.2
2021-05-03 21:27:54.812 INFO ZWAVE: Node 44: metadata updated: 49-0-Humidity
2021-05-03 21:27:54.816 INFO ZWAVE: Node 44: value updated: 49-0-Humidity 66 => 64
2021-05-03 21:27:59.804 INFO ZWAVE: Node 12: value updated: 50-0-value-66049 0 => 0
2021-05-03 21:28:08.036 INFO ZWAVE: Node 51: value updated: 50-0-value-66561 238.653 => 239.165
2021-05-03 21:28:08.319 INFO ZWAVE: Node 51: value updated: 50-0-value-66817 4.867 => 4.742
2021-05-03 21:28:08.599 INFO ZWAVE: Node 51: value updated: 50-0-value-66049 605.328 => 568.458
2021-05-03 21:28:08.880 INFO ZWAVE: Node 51: value updated: 50-0-value-65537 296.86 => 296.869
2021-05-03 21:28:23.047 INFO ZWAVE: Node 51: value updated: 50-1-value-66561 234.612 => 238.895
2021-05-03 21:28:23.337 INFO ZWAVE: Node 51: value updated: 50-2-value-66561 248.475 => 251.972
2021-05-03 21:28:23.630 INFO ZWAVE: Node 51: value updated: 50-3-value-66561 242.19 => 238.376
2021-05-03 21:28:24.113 INFO ZWAVE: Node 51: value updated: 50-1-value-66817 0.825 => 0.784
2021-05-03 21:28:24.507 INFO ZWAVE: Node 51: value updated: 50-2-value-66817 2.444 => 2.002
2021-05-03 21:28:25.121 INFO ZWAVE: Node 51: value updated: 50-3-value-66817 2.45 => 1.969
2021-05-03 21:28:25.415 INFO ZWAVE: Node 51: value updated: 50-1-value-66049 127.832 => 113.861
2021-05-03 21:28:33.152 INFO ZWAVE: Node 8: metadata updated: 49-0-Air temperature
2021-05-03 21:28:33.155 INFO ZWAVE: Node 8: value updated: 49-0-Air temperature 29.8 => 30
2021-05-03 21:28:34.046 INFO ZWAVE: Node 51: value updated: 50-3-value-66049 374.848 => 281.953
2021-05-03 21:28:34.337 INFO ZWAVE: Node 51: value updated: 50-1-value-65537 52.98 => 53.015
2021-05-03 21:28:34.629 INFO ZWAVE: Node 51: value updated: 50-2-value-65537 218.078 => 218.183
2021-05-03 21:28:34.921 INFO ZWAVE: Node 51: value updated: 50-3-value-65537 25.582 => 25.671
2021-05-03 21:28:55.535 INFO ZWAVE: Node 8 is now awake
2021-05-03 21:28:56.889 INFO ZWAVE: Node 8 is now asleep
