Zwave nodes problem after changing SD card and OS
HI,
I recently changed the system on my RPi 3B+ to Ubuntu Mate. I used to have HA inside docker and did the same on Ubuntu Mate. I’ve installed the same version of HA on the new docker and copied all te configuration files from the “old” docker folder. Now when i start the HA i cant see some of the nodes. Also the names of the nodes reverted to their defaults. Did anyone had this problem and managed to resolve it ? I’ve digged a lot of post and no solution was found.
Did you move the old zwave config file over as well?
zwcfg_0xd9f660ea.xml, might have a different name for you.
yes, i did. I moved each and every file. I can see some nodes but dont see others. It has no rule which is not seen.
