Here we go again!
I updated the core to 4.11 and ZWave no longer works. Here’s the log but it’s the same issue when we moved from 3.13 to 4.8.
I am running a razberry 2 on a pi 3b+. Any help is greatly appreciated.
2020-07-08 00:59:21.087 Always, OpenZwave Version 1.4.3469 Starting Up
2020-07-08 00:59:43.595 Info, Setting Up Provided Network Key for Secure Communications
2020-07-08 00:59:43.595 Info, mgr, Added driver for controller /dev/ttyAMA0
2020-07-08 00:59:43.596 Info, Opening controller /dev/ttyAMA0
2020-07-08 00:59:43.596 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2020-07-08 00:59:43.596 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2020-07-08 00:59:43.597 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-07-08 00:59:43.597 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-07-08 00:59:43.597 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-07-08 00:59:43.598 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-07-08 00:59:43.598 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-07-08 00:59:43.598 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-07-08 00:59:43.598 Detail, contrlr, Notification: DriverFailed
