ZWave not loading after update
I just installed the 110.4 (originally 109.x and updated regularly) update along with the OS 4.8 update (was on 3.1x that was originally installed from the image file). After the updates my zwave controller has stopped working. Seems like a lot of these issues floating around and after 2 hours of Google reading, I am asking for some help. I think this is all setup correctly. I am running a RPi B+ and Razberry.me board.
Configuration -> Integrations -> Zwave shows 10 devices and 74 entities. This was all working before the update.
Supervisor -> OpenZwave installed, updated and was working perfectly.
Supervisor -> System -> Hardware shows this entry and it matches the openzwave setup above.
serial:
* /dev/ttyAMA0
After a reboot this is what is in my zwave logs.
2020-06-01 21:11:03.769 Always, OpenZwave Version 1.4.3469 Starting Up
2020-06-01 21:11:18.217 Info, Setting Up Provided Network Key for Secure Communications
2020-06-01 21:11:18.218 Info, mgr,     Added driver for controller /dev/ttyAMA0
2020-06-01 21:11:18.219 Info,   Opening controller /dev/ttyAMA0
2020-06-01 21:11:18.221 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2020-06-01 21:11:18.221 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2020-06-01 21:11:18.222 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-06-01 21:11:18.222 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-06-01 21:11:18.223 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-06-01 21:11:18.223 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-06-01 21:11:18.223 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-06-01 21:11:18.223 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-06-01 21:11:18.223 Detail, contrlr, Notification: DriverFailed
If I click Configuration -> Zwave -> “start network” it just spins forever. Nothing loads and after 30 mins I give up.
Please help. I don’t have that many devices and the only real reason I have zwave is for my frontdoor lock and garage door.
Also after the update logbook and history no longer load at all. They just spin forever. Not sure if I have a bad install or what.
I am experiencing the same issue.
After updating zwave is not starting on my rpi3b+ with razberry.
I tried rolling back a snapshot just hours before I updated but with no luck.
Any ideas?
Same here. Must be with the OS update. Not sure what it broke yet.
Luckily I take snapshots every other day and had a fresh backup.
Both ssh and zwave broke and after several restorations I rolled back to 3.1.3 on a formatted SD.
Took my a few hours and I will stay off the updates for a while
