zWave re-discovery of shutter (QLSH-001P10EU)
I have a QLSH-001P10EU Shelly zWave shutter which seems to have 'forgotten' that it has Venetian blinds tilt possibilities. The two separate devices are there, but the GUI of Home Assistant doesn't show it as one open/close/tilt device (which it previously did).
I see that in discovery.py the device should be correctly classified as tilt-capable if parameter 71 is set accordingly. That parameter was set incorrectly in my device, but after correcting it the device doesn't change to tilt-capable.
I've tried re-interviewing, restarting Home Assistant, but nothing seems to re-trigger the discovery. Is there any way to re-trigger discovery except fully excluding and re-including the device?
Any other suggestions?
I think you are on to something here.
