Zwave repeater flooding network
I am trying to get a zwave signal to devices in a detached garage, the garage isn’t too far away from the house (about 2 meters) however it is mostly underground and made entirely of concrete. I’ve found that with one device at the closest corner of the garage I get an intermittent response, so I thought the best bet would be to put a repeater at the closest corner of the house to bridge the gap and reinforce the network.
To that end I purchased a pair of Aeotec Range Extender 6 modules (1 for the garage, 1 for the house) and figured this would bridge my gap. Both repeaters pair fine to the zwave network, however I looked at my OZW_Log.txt this morning, and it was over 10MB in size, and none of my Z-Wave devices were responding to commands. I opened OZW_Log.txt with tail -f and it was scrolling so fast I couldn’t read anything. Here’s a sample, but note that this repeated text goes on for 10MB of log!. Node027 is the repeater in the house:
2018-05-04 09:40:06.015 Detail,
2018-05-04 09:40:06.015 Info, Node027, Response RTT 37 Average Response RTT 36
2018-05-04 09:40:06.015 Info, Node027, Received Association report from node 27, group 1, containing 1 associations
2018-05-04 09:40:06.015 Info, Node027,   The group contains:
2018-05-04 09:40:06.015 Info, Node027,     Node 1
2018-05-04 09:40:06.016 Info, Node027, Get Associations for group 2 of node 27
2018-05-04 09:40:06.016 Detail, Node027, Queuing (Send) AssociationCmd_Get (Node=27): 0x01, 0x0a, 0x00, 0x13, 0x1b, 0x03, 0x85, 0x02, 0x02, 0x25, 0x36, 0x68
2018-05-04 09:40:06.016 Detail, Node027,   Expected reply and command class was received
2018-05-04 09:40:06.016 Detail, Node027,   Message transaction complete
2018-05-04 09:40:06.016 Detail, Node027, Removing current message
2018-05-04 09:40:06.017 Detail,
2018-05-04 09:40:06.017 Info, Node027, Sending (Send) message (Callback ID=0x1f, Expected Reply=0x04) - AssociationCmd_Get (Node=27): 0x01, 0x0a, 0x00, 0x13, 0x1b, 0x03, 0x85, 0x02, 0x02, 0x25, 0x1f, 0x41
2018-05-04 09:40:06.026 Detail, Node027,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-05-04 09:40:06.026 Detail, Node027,   ZW_SEND_DATA delivered to Z-Wave stack
2018-05-04 09:40:06.041 Detail, Node027,   Received: 0x01, 0x07, 0x00, 0x13, 0x1f, 0x00, 0x00, 0x02, 0xf6
2018-05-04 09:40:06.041 Detail, Node027,   ZW_SEND_DATA Request with callback ID 0x1f received (expected 0x1f)
2018-05-04 09:40:06.042 Info, Node027, Request RTT 24 Average Request RTT 24
2018-05-04 09:40:06.042 Detail,   Expected callbackId was received
2018-05-04 09:40:06.053 Detail, Node027,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x1b, 0x06, 0x85, 0x03, 0x01, 0x01, 0x00, 0x01, 0x6d
2018-05-04 09:40:06.053 Info, Node027, Response RTT 36 Average Response RTT 36
2018-05-04 09:40:06.053 Info, Node027, Received Association report from node 27, group 1, containing 1 associations
2018-05-04 09:40:06.054 Info, Node027,   The group contains:
2018-05-04 09:40:06.054 Info, Node027,     Node 1
2018-05-04 09:40:06.054 Info, Node027, Get Associations for group 2 of node 27
2018-05-04 09:40:06.054 Detail, Node027, Queuing (Send) AssociationCmd_Get (Node=27): 0x01, 0x0a, 0x00, 0x13, 0x1b, 0x03, 0x85, 0x02, 0x02, 0x25, 0x37, 0x69
2018-05-04 09:40:06.054 Detail, Node027,   Expected reply and command class was received
2018-05-04 09:40:06.054 Detail, Node027,   Message transaction complete
2018-05-04 09:40:06.055 Detail, Node027, Removing current message
2018-05-04 09:40:06.055 Info, Node027, Sending (Send) message (Callback ID=0x20, Expected Reply=0x04) - AssociationCmd_Get (Node=27): 0x01, 0x0a, 0x00, 0x13, 0x1b, 0x03, 0x85, 0x02, 0x02, 0x25, 0x20, 0x7e
2018-05-04 09:40:06.063 Detail, Node027,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-05-04 09:40:06.063 Detail, Node027,   ZW_SEND_DATA delivered to Z-Wave stack
2018-05-04 09:40:06.080 Detail, Node027,   Received: 0x01, 0x07, 0x00, 0x13, 0x20, 0x00, 0x00, 0x02, 0xc9
2018-05-04 09:40:06.080 Detail, Node027,   ZW_SEND_DATA Request with callback ID 0x20 received (expected 0x20)
2018-05-04 09:40:06.080 Info, Node027, Request RTT 24 Average Request RTT 24
2018-05-04 09:40:06.080 Detail,   Expected callbackId was received
2018-05-04 09:40:06.091 Detail, Node027,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x1b, 0x06, 0x85, 0x03, 0x01, 0x01, 0x00, 0x01, 0x6d
2018-05-04 09:40:06.091 Info, Node027, Response RTT 36 Average Response RTT 36
2018-05-04 09:40:06.092 Info, Node027, Received Association report from node 27, group 1, containing 1 associations
2018-05-04 09:40:06.092 Info, Node027,   The group contains:
2018-05-04 09:40:06.092 Info, Node027,     Node 1
2018-05-04 09:40:06.092 Info, Node027, Get Associations for group 2 of node 27
2018-05-04 09:40:06.092 Detail, Node027, Queuing (Send) AssociationCmd_Get (Node=27): 0x01, 0x0a, 0x00, 0x13, 0x1b, 0x03, 0x85, 0x02, 0x02, 0x25, 0x38, 0x66
2018-05-04 09:40:06.092 Detail, Node027,   Expected reply and command class was received
2018-05-04 09:40:06.093 Detail, Node027,   Message transaction complete
2018-05-04 09:40:06.093 Detail, Node027, Removing current message
2018-05-04 09:40:06.093 Info, Node027, Sending (Send) message (Callback ID=0x21, Expected Reply=0x04) - AssociationCmd_Get (Node=27): 0x01, 0x0a, 0x00, 0x13, 0x1b, 0x03, 0x85, 0x02, 0x02, 0x25, 0x21, 0x7f
2018-05-04 09:40:06.101 Detail, Node027,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-05-04 09:40:06.102 Detail, Node027,   ZW_SEND_DATA delivered to Z-Wave stack
2018-05-04 09:40:06.118 Detail, Node027,   Received: 0x01, 0x07, 0x00, 0x13, 0x21, 0x00, 0x00, 0x02, 0xc8
2018-05-04 09:40:06.118 Detail, Node027,   ZW_SEND_DATA Request with callback ID 0x21 received (expected 0x21)
2018-05-04 09:40:06.118 Info, Node027, Request RTT 24 Average Request RTT 24
I thought maybe the repeater was faulty, so I factory reset it, removed it, and tried the other one, but I got exactly the same result as soon as I hit refresh node.
Any ideas on what’s going on? and what can be done about it?
Does that device (“node 27”) work fine and without “flooding” if you bring it close to the controller? It seems to me that your controller keeps asking for members of group 2 and keeps getting replies about members of group 1. This does not sound like a communication problem if the replies are indeed coming from “node 27”. Either there’s some problem with your repeaters mangling the message (in which case you might try updating their firmware - I see a recent update on the Aeotec site, your devices almost certainly have something older inside), or “node 27” might not even have a “group 2” (but declare that in some ambiguous way) and it might be stupid enough to disregard which group it’s being asked for (in which case the exact same thing should happen up-close to the controller, hence my question - if this is the case all you can do is buy a smarter “node 27”). Link to the firmware page: https://aeotec.freshdesk.com/support/solutions/articles/6000193286-range-extender-6-zw117-firmware-update-1-15-2018-
I am having the same issue (n/w message flood). Did upgrading the repeater’s firmware help?
I ended up returning both repeaters and installing a zwave light switch in that corner of the house to serve the same purpose (and automate my outdoor light at the same time). I had a third identical repeater that is in the garage and it seems to be fine.
