Zwave response times
Hi guys, I have an issue in that I have several automations that run for lighting, using Zwave devices some Fibaro some Everspring they used to work pretty much ok 99.8% of the time on Domoticz, I have now moved over to Home Assistant but many rooms need the pir to activate twice before the lights come on, then other times instant.
This morning come downstairs hall lamps straight on walked past toilet straight on (Dont ask) Kitchen nothing have a wander round nothing finally sucuumb and switch it on manually.
Other times straight on no delay, Wife comes down goes to her office (dining Room) nothing wanders about gives up then it finally comes on, Last night goes to the office to get a drink around 9 nothing then 30secs later lights on as im coming out, again other times comes on instantly. same wih the bathroom. Im using a PI4 4Gb with a proper genuine power supply the USB Z Wave and Zigbee Sticks are on the USB 2 ports and on 2m usb extenders in opposite directions.
The Core CPU is running at 1.4% and Core Ram running at 13.8%
Even the Zigbee is hit and miss, I have a Zigbee light switch in the bedroom to control a Zwave Fibaro double switch and that is sluggish and seems to need 2 hits to get it going ay ideas im loosing mind here cheers
What zwave do you use? The built in one, openzwave beta or zwave2mqtt?
Hi there I use the following:
zwave
Not that this helps, but just stating how it should be, my Z-Wave and ZigBee actions are instant. My lights will turn on within the blink of an eye from pressing a button or switching them in the HA GUI, same for motion controlled lights.
There is definitely something wrong with your setup somewhere. Could it be how you have coded the automations?
What I have done previously is to walk around with a tablet watching the relevant motion sensors to determine whether it’s the sensors not being triggered or HA not responding.
I did follow the HA demo code for light switching,
- alias: Turn on Kitchen light when there is movement
    platform: state
    entity_id: binary_sensor.kitchen_pir_sensor
    to: 'on'
    service: switch.turn_on
    entity_id: switch.fibaro_system_fgs223_double_relay_switch_4
- alias: Turn off Downstairs Loo 10 minutes after last movement
    platform: state
    to: 'off'
    for:
      minutes: 10
    service: switch.turn_off
- id: 12670501003d4f09b228c3b5c98392d2
  alias: Turn on Dining light when there is movement
  - platform: state
    entity_id: binary_sensor.dining_room_pir_sensor
    to: 'on'
  - service: light.turn_on
    entity_id: light.dining_dimmer_level_3
  mode: single
- id: 125b32840642471298bdba535d7a1952
  alias: Turn off Dining light 10 minutes after last movement
  - platform: state
    to: 'off'
    for: 0:10:00
  - service: light.turn_off
  mode: single
  - platform: state
    to: 'on'
  mode: single
  - platform: state
    to: 'off'
    for: 0:10:00
  mode: single
just 2 of the lights in my system Dining is a Dimmer (Fibaro) and the Kitchen (Fibaro double relay)
Both are within max 10m of the Pi4 same floor non foil backed non insulated plasterboard is in between the Pi & the kitchen, and the Dining room is a Red Brick internal wall
My logs seem to have some issues too
Error fetching ipp data: Invalid response from API: Error occurred while communicating with IPP server.
9:16:03 AM – Internet Printing Protocol (IPP) (ERROR) - message first occurred at December 18, 2020, 10:32:28 AM and shows up 7 times
Error fetching brother data: No SNMP response received before timeout
9:15:48 AM – Brother Printer (ERROR) - message first occurred at December 18, 2020, 10:32:29 AM and shows up 7 times
[Living Room TV(192.168.2.248):8009] Heartbeat timeout, resetting connection
9:10:55 AM – /usr/local/lib/python3.8/site-packages/pychromecast/socket_client.py (WARNING) - message first occurred at December 18, 2020, 12:03:12 PM and shows up 39 times
Climate Update - Home Heating: Error executing script. Unexpected error for call_service at pos 1: Not connected!
7:00:00 AM – Automation (ERROR) - message first occurred at December 18, 2020, 7:06:11 PM and shows up 8 times
[SHIELD Android TV(192.168.2.243):8009] Error communicating with socket, resetting connection
5:22:00 AM – /usr/local/lib/python3.8/site-packages/pychromecast/socket_client.py (WARNING) - message first occurred at December 18, 2020, 5:19:01 PM and shows up 7 times
Error purging history: (sqlite3.DatabaseError) database disk image is malformed [SQL: DELETE FROM events WHERE events.time_fired < ?] [parameters: ('2020-10-25 15:12:44.836264',)] (Background on this error at: http://sqlalche.me/e/13/4xp6)
4:12:00 AM – Recorder (WARNING)
Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: DELETE FROM events WHERE events.time_fired < ?] [parameters: ('2020-10-25 15:12:44.836264',)] (Background on this error at: http://sqlalche.me/e/13/4xp6)
4:12:00 AM – Recorder (ERROR)
get_circles: OK again
3:03:37 AM – Life360 (ERROR)
Connection problem to snitun server
3:03:23 AM – /usr/local/lib/python3.8/site-packages/hass_nabucasa/remote.py (ERROR) - message first occurred at 3:01:49 AM and shows up 9 times
Can't connect to SniTun server eu-west-2.ui.nabu.casa:443
3:03:23 AM – /usr/local/lib/python3.8/site-packages/snitun/client/client_peer.py (ERROR) - message first occurred at 3:01:49 AM and shows up 9 times
Coolkit API error: Cannot connect to host eu-api.coolkit.cc:8080 ssl:default [Try again]
3:02:51 AM – Sonoff (ERROR) - message first occurred at 3:02:31 AM and shows up 2 times
Timeout sending report to Alexa
3:02:44 AM – Amazon Alexa (ERROR) - message first occurred at 3:02:05 AM and shows up 6 times
Unable to connect: Cannot connect to host cloud.nabucasa.com:443 ssl:default [Try again]
3:02:26 AM – /usr/local/lib/python3.8/site-packages/hass_nabucasa/iot_base.py (WARNING) - message first occurred at 3:00:46 AM and shows up 5 times
Ping fails, no response from peer
3:01:36 AM – /usr/local/lib/python3.8/site-packages/snitun/multiplexer/core.py (ERROR)
[Living Room TV(192.168.2.248):8009] Failed to connect to service BRAVIA-4K-GB-ATV3-fafa74e425bc79f3e12562e454a1f01a._googlecast._tcp.local., retrying in 5.0s
3:01:12 AM – /usr/local/lib/python3.8/site-packages/pychromecast/socket_client.py (ERROR) - message first occurred at December 18, 2020, 10:48:04 PM and shows up 6 times
get_circles: CommError: HTTPSConnectionPool(host='api.life360.com', port=443): Max retries exceeded with url: /v3/circles.json (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f95c893d0>: Failed to establish a new connection: [Errno -3] Try again'))
3:00:31 AM – Life360 (ERROR) - message first occurred at 3:00:17 AM and shows up 2 times
[Living Room TV(192.168.2.248):8009] Error reading from socket.
12:16:09 AM – /usr/local/lib/python3.8/site-packages/pychromecast/socket_client.py (ERROR) - message first occurred at December 18, 2020, 10:48:04 PM and shows up 4 times
Login attempt or request with invalid authentication from supervisor (172.30.32.2) (Python/3.8 aiohttp/3.7.3)
December 18, 2020, 10:36:04 PM – HTTP (WARNING)
MatthewFlamm/nwsradar - Repository is archived.
December 18, 2020, 9:51:13 PM – HACS (ERROR)
You are using a custom integration for alarmo which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
December 18, 2020, 6:33:34 PM – loader.py (WARNING)
Connection closed: Received non-Text message: 8
December 18, 2020, 6:17:55 PM – /usr/local/lib/python3.8/site-packages/hass_nabucasa/iot_base.py (WARNING)
Hot tub tree Icicles on/off: Already running
December 18, 2020, 3:57:57 PM – Automation (WARNING)
Updating state for device_tracker.sm_t580 (<class 'homeassistant.components.mobile_app.device_tracker.MobileAppEntity'>) took 4.032 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+mobile_app%22
December 18, 2020, 11:20:45 AM – helpers/entity.py (WARNING)
Received unexpected bridge id: 93eadbeef13
December 18, 2020, 8:27:45 AM – /usr/local/lib/python3.8/site-packages/aiohue/util.py (WARNING) - message first occurred at December 18, 2020, 8:27:45 AM and shows up 9 times
Platform rpi_power does not generate unique IDs. ID rpi_power already exists - ignoring binary_sensor.rpi_power_status
December 18, 2020, 8:26:12 AM – Binary sensor (ERROR)
Received message for unregistered webhook 191f5914aec8cdd582967c2b20f4cc81fed0632f364aac99061c9b0ce320037e from 127.0.0.1
December 18, 2020, 8:25:28 AM – Webhook (WARNING)
Platform met does not generate unique IDs. ID home already exists - ignoring weather.home
December 18, 2020, 8:25:14 AM – Weather (ERROR)
Invalid config for [automation]: Expected HH:MM, HH:MM:SS or Entity ID with domain 'input_datetime' or 'sensor' @ data['at'][0]. Got None. (See /config/configuration.yaml, line 24).
December 18, 2020, 8:25:09 AM – config.py (ERROR) - message first occurred at December 18, 2020, 8:25:09 AM and shows up 2 times
Any help cheers
Might have to give that a go, it seems to be getting worse.
I might start from scratch, see if that works it just takes ages to setup again, and i dont get hours of time, but needs must :slight_smile:
