OK, I give up. Trying to hide my alarm type badge. So confused. Tried:
zwave:
customize:
sensor.__alarm_type_3_0:
hidden: true
…in the configuration.yaml file, no deal.
Tried the same thing in my zwave_device_config.yaml file - no deal.
Tried simply adding hidden: true under:
sensor.__alarm_level_3_1:
ignored: false
polling_intensity: 1
hidden: true
Nothing works - some configurations cause errors - some simply ignore. From reading about customize, it looks like the option has changed recently.
Question - how do I hide a zwave sensor?
roddie
(Roddie)
March 18, 2017, 4:59am
2
Ah, the magic of posting a question - solved it myself.
Had to put the “customize” sensor in the configuration.yaml in the homeassistant: section, and use the proper “Entity ID”
andrey
(Andrey)
March 19, 2017, 4:51pm
4
ignored: true
in zwave device_config
is preferred to hidden: true
in customize
hidden: true
just hides the device from the UI.
ignored: true
gets rid of it completely.
Neither of these seems to work for me in any form, my expectation is that I hide and ignore and it is gone from the interface, that is what this is doing right?
homeassistant:
customize:
binary_sensor.garagedooropener_sensor_7_0_1:
hidden: true
customize_glob:
"binary_sensoor.garagedooropener*":
hidden: true
or
zwave:
usb_path: /dev/ttyACM0
device_config:
ignored: true
device_config_glob:
"binary_sensor.garagedooropener*":
ignored: true
I stil have the senor, it is not hidden or ignored. Any ideas?
The details of the sensor:
new entity id
old entity id
value instance
1
value index
0
node id
7
thanks for your help
I think I Have figured it out, I was fooled by the configuration reload features in the UI, once I restart on the OS leve things seem to change.
one thing i could not do is reference and disable an individual sensor on the same device, there is:
and
binary_sensor.garagedooropener_sensor_2
binary_sensor.garagedooropener_sensor:
ignored: true
disabled both and
binary_sensor.garagedooropener_sensor_2:
ignored: true
disables nothing. Thoughts?
