Zwave suddenly stopped to work
Helo there!
After power outage I started to face problem with my zwave setup in my HASSIO. I was able to configure everything to work, but after power outage and system restart I can’t get it in back in order. My config (somehow limited, but it is more testbed for future expansion):
  • Aeotec Gen 5 USB stick and it worked (and still works) fine - it activates properly in HASSIO and I can see other nodes connected to.
  • Aeotec range extender - seems to work fine, triggers on sensors/switches causes reception light to blink. Also if it would not work properly USB stick is too far from devices I test, so signal is passed properly.
  • Aeotec Wallmote Quad - seems to work, I can see it triggering events in HASSIO.
  • NeoCam door sensors… here the problems starts:
  • One of these after failure is in permanent initialization state (it is visible in zwcfgxxxxx.xml but with incomplete data (comparing the the other one). homeassistant log shows WARNING (MainThread) [homeassistant.components.zwave] Z-Wave node 5 not ready after 30 seconds, continuing anyway).
    I tried to remove and add it again to HASSIO, but it seems not to be possible, whatever I do from Zwave configurator, it still shows as Unknown Node 5 (Node:5 Probe) (itried also to reset device itself, but it didn’t helped.
  • with the the other sensor (and wallmote as well) the issue is that while I can see that these devices are triggering events, none of configured automations works anymore… For example sensor is attached to door to switch on the light. I can see in HASSIO status of door being reported (open/closed), but related automation is not triggered to switch the light on/off. It worked previously OK. Light itself is wotking fine, as I can switch it on/off directly from HASSIO. Same apply to wallmote, previously working automation stopped to work. Any help where to start troubleshooting would be appreciated!
    Best regards,
    mirekmal
