I upgraded to 0.17 this morning. Immediately after upgrading all of my zwave devices went offline. I am on homeassistant 2025.6. Logs keep repeating
2025-06-23 14:02:11.040 CNTRLR [Node 000] is unknown - discarding received command…
2025-06-23 14:02:11.640 CNTRLR [Node 000] is unknown - discarding received command…
2025-06-23 14:02:12.240 CNTRLR [Node 000] is unknown - discarding received command…
2025-06-23 14:02:12.840 CNTRLR [Node 000] is unknown - discarding received command…
2025-06-23 14:02:13.440 CNTRLR [Node 000] is unknown - discarding received command…
2025-06-23 14:02:14.040 CNTRLR [Node 000] is unknown - discarding received command…
2025-06-23 14:02:41.041 CNTRLR [Node 000] is unknown - discarding received command…
2025-06-23 14:02:41.641 CNTRLR [Node 000] is unknown - discarding received command…
2025-06-23 14:02:42.241 CNTRLR [Node 000] is unknown - discarding received command…
2025-06-23 14:02:42.840 CNTRLR [Node 000] is unknown - discarding received command…
2025-06-23 14:02:43.441 CNTRLR [Node 000] is unknown - discarding received command…
2025-06-23 14:02:44.040 CNTRLR [Node 000] is unknown - discarding received command…
2025-06-23 14:03:11.040 CNTRLR [Node 000] is unknown - discarding received command…
My controller is node 001. After leaving it alone for about 2 hours, It finally finished interviewing about 100 nodes. I found the ones that failed the interview and interviewed them separately to get them working. Still getting a steady stream of the error complaining about node 000.
