I am using Zwave2Mqtt for my zwave devices and I’m curious if I can customize the device class of the access control entity to turn it into a door:
I’ve tried to set it manually in Customize.yaml:
sensor.front_door:
device_class: door
It looks like the only options in the UI customizations screen are voltage/power related:
Do I need to use a template sensor for this? I wanted to avoid that if possible to keep things cleaner if possible. Thanks in advance!
