ZwaveJS UI and ZST39 LR, 50% of devices are suddenly offline
Something happened (I don’t know what) and 50% of my zwave devices are no longer showing as active. I tried soft reset, power cycling, and restoring a addon backup but I can’t seem to get anything that really indicates what the problem is. I did not make any recent changes, any suggestions?
2025-02-03T23:53:17.960Z CNTRLR » [Node 019] pinging the node...
2025-02-03T23:53:25.726Z CNTRLR   [Node 019] The node did not respond after 1 attempts, it is presumed dead
2025-02-03T23:53:25.727Z CNTRLR   [Node 019] ping failed: The node did not acknowledge the command (ZW0204)
Just an update, after shutting off power at the breaker, zwave devices are coming back online, but that doesn’t really solve the issue (have to pull the battery for every sensor?)
Happened to me too. I updated the firmware of the stick. Then I got the tip to monitor the traffic and reduce the amount of traffic to the stick.
I had a lot of traffic going to the controller and that caused problems with the ZST39 here too. Devices went offline for the first time ever in 10 years that I have Z-Wave devices. Never had issues before.
Reducing the amount of traffic eventually solved the issue. The stick is more stable now even though now and then it sometimes is offline for a few seconds.
