I just insatlled Zwave to home assistant and the timing was great, because we now have a new integration!
My only problem is that I need the “zwavejs2mqtt” to support troublesome devices!
And HA kept nagging me to install Zwave-JS even if it was already installed?
Resulting in this:
One where all my devices is included from the "zwavejs2mqtt " and the other one just empty
If I remove it then HA will keep nagging me to add it again and there is no “Ignore” button available
I installed Z-wave JS as integration add-ons and during install I then selected Z-wave JS and selected the Zwavejs2mqtt to port 3100 and everything worked!
Than after a reboot I started to get this:
(No ignore button)
while still having this:
Could it be a configuration issue? I needed to change port to 3100!
you don’t need to delete those files. and if you did it wouldn’t help.
you just need to delete the old zwave integration from the integrations page.
that page in the screenshot comes from the zwavejs2mqtt add-on. It adds a zwavejs server when you install it.
Again I’m not sure why yours asks you to configure another zwavejs integration. Mine didn’t ask to configure.
Maybe it’s because I don’t run a supervised installation.
If it were me I would just ignore the discovery pop up when it asks you to configure the second one. I know you can’t officially ignore it with an ignore button but you can’t still just ignore it. It won’t hurt anything.
And you could (should) submit a bug report on it because one way or another it doesn’t seem to be acting right.
