ZWave-JS - NodOn Soft Remote
Here is a blueprint for Nodon Soft Remote.
blueprint:
  name: Nodon SoftRemote (Z-Wave JS)
  description: |
    Create automations for the Nodon Soft Remote using the Z-Wave JS integration.
  domain: automation
  input:
    nodon_softremote:
      name: Nodon Soft remote
      description: List of available Soft Remote devices.
      selector:
        device:
          integration: zwave_js
          manufacturer: ID-RF
          model: Soft Remote
    button_full_circle:
      name: "'Full circle' button simple press"
      description: Action to run when the 'full circle' button is pressed once.
      default: []
      selector:
    button_plus:
      name: "'+' button simple press"
      description: Action to run when the '+' button is pressed once.
      default: []
      selector:
    button_empty_circle:
      name: "'Empty circle' button simple press"
      description: Action to run when the 'empty circle' button is pressed once.
      default: []
      selector:
    button_minus:
      name: "'-' button simple press"
      description: Action to run when the '-' button is pressed once.
      default: []
      selector:
  source_url: https://community.home-assistant.io/t/zwjs-nodon-soft-remote/300993/300945
mode: single
max_exceeded: silent
variables:
  device_id: !input "nodon_softremote"
  - platform: event
    event_type: zwave_js_value_notification
condition: "{{ trigger.event.data.device_id == device_id }}"
  - variables:
      property_key_name: "{{ trigger.event.data.property_key_name }}"
      property_name: "{{ trigger.event.data.property_name }}"
      label: "{{ trigger.event.data.label }}"
      command_class_name: "{{ trigger.event.data.command_class_name }}"
      value: "{{ trigger.event.data.value }}"
      node_id: "{{ trigger.event.data.node_id }}"
  - service: logbook.log
      message:
        "received event from node {{node_id}}: {{ command_class_name }} - {{
        value }} - {{ label }}"
  - choose:
      - conditions: |
          {{  property_name == 'scene'
              and property_key_name == '001'
              and (value == 'KeyPressed' or value == 0)
        sequence: !input "button_full_circle"
      - conditions: |
              and property_key_name == '002'
        sequence: !input "button_plus"
      - conditions: |
              and property_key_name == '003'
        sequence: !input "button_empty_circle"
      - conditions: |
              and property_key_name == '004'
        sequence: !input "button_minus"
Updated to make it work. Works fine
