HACS Docker Installation Guide - Portainer, Synology, QNAP & Terminal
Need to install HACS on your Docker Home Assistant setup? This guide covers 4 different methods depending on your platform.
I’ve also created a video walkthrough for visual learners:
Prerequisites: Home Assistant running on Docker + GitHub account
Method 1: Terminal/Command Line
:open_book: Full Terminal Guide →
Step 1: Connect to Container
docker ps
Docker PS Command Output
docker exec -it [YOUR_CONTAINER_NAME] bash
# Example: docker exec -it homeassistant bash
Step 2: Install HACS
wget -O - https://get.hacs.xyz | bash -
Step 3: Exit and Restart
exit
docker restart [YOUR_CONTAINER_NAME]
Method 2: Portainer
:open_book: Full Portainer Guide →
Step 1: Access Portainer Console
  1. Go to Containers in Portainer
  2. Find your Home Assistant container
  3. Click the “Exec Console” button (>_)
Step 2: Connect to Terminal
  1. Ensure /bin/bash is selected in Command field
  2. Click “Connect”
Step 3: Install HACS
Step 4: Restart Container
  1. Exit console → Return to Containers view
  2. Select Home Assistant container → Click “Restart”
Method 3: Synology Container Manager
:open_book: Full Synology Guide →
Step 1: Access Container Manager
  1. Log in to Synology DSM
  2. Open Container Manager from main menu
Step 2: Open Container Terminal
  1. Click Container tab
  2. Find Home Assistant container
  3. Right-click → Open Terminal
  1. Click Create → Choose bash
  2. Run installation command:
  1. Close terminal window
  2. Right-click Home Assistant container
  3. Select “Action” → “Restart”
Notes:
  • DSM 7.x: Use Container Manager (recommended)
  • DSM 6.x: Use Docker package instead
Method 4: QNAP Container Station
:open_book: Full QNAP Guide →
Step 1: Access Container Station
  1. Log in to QNAP web interface
  2. Open Container Station
Step 2: Open Console
  1. Find Home Assistant container in list
  2. Click container → View details
  3. Navigate to Actions → Execute
  4. Select /bin/bash → Click Execute
  3. Click “Restart” button
Setting Up HACS Integration (All Methods)
After installation and container restart:
Step 1: Open Integrations
  1. Go to Settings → Devices & Services
Open your Home Assistant instance and show your integrations.
Step 2: Add HACS Integration
  1. Click Add Integration (bottom right)
  2. Search for “HACS” and select it
Open your Home Assistant instance and start setting up a new integration.
Step 3: Accept Terms
Review and accept HACS terms by checking all boxes → Click Submit
Step 4: GitHub Authentication
  1. Copy the device code shown
  2. Click link to open GitHub authorization
  3. Log in to GitHub if needed
Step 5: Authorize HACS
  1. Paste code into GitHub device activation page
  2. Click Authorize HACS
Step 6: Complete Setup
  1. Choose area for HACS integration (optional)
  2. Click Finish
Step 7: Access HACS
You should see the HACS icon in your sidebar
Troubleshooting
Can’t see HACS icon?
  • Hard refresh browser: CTRL+F5 (Windows/Linux) or CMD+SHIFT+R (Mac)
  • Clear browser cache
Thank you. I’m running Umbrel OS and HA is installed as a Docker and I’m fairly clueless about containers. Full Terminal instructions did the trick. I am now loaded up with goodies.
