Okay. I did not know about FutureNow and Sisyphus and luckily for me, they are local components that I could put to use. Thanks.
Update: Oh, man… Sisyphus is very cool…!
sisyphus end table time lapse #3
And controlled by Home Assistant!? That gets me excited!
Very cool, but not an every day purchase.
Not all products that can be controlled by Home Assistant are not an everyday purchase, such as a Radio Thermostat and Konnected Alarm Panel.
I do not see the last_seen attribute for google location sharing device trackers.
Anyone else has this issue?
See the docs here.
Does it mean we can also change the domain of a given entity? For instance, I have a smart power plug that gets listed as light.
, can I change it to switch.
devices_tracker does not work with luci in OpenWrt 18.06.0
There are threads here already. Suggest you use search.
Yup, broken for me too.
after upgrade to 75.1 getting lots of log entries and devices keeps going unavailable then coming back.
2018-08-06 22:55:12 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.multisensor_6_in_1_44 is taking over 10 seconds
2018-08-06 22:55:15 WARNING (MainThread) [homeassistant.components.switch.wemo] Lost connection to Zaras Bedroom Light
2018-08-06 22:55:18 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating ring binary_sensor took longer than the scheduled update interval 0:00:10
2018-08-06 22:55:18 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2018-08-06 22:55:20 WARNING (MainThread) [homeassistant.components.switch.wemo] Lost connection to Upstairs Porch Light
2018-08-06 22:55:20 WARNING (MainThread) [homeassistant.components.switch] Updating wemo switch took longer than the scheduled update interval 0:00:10
2018-08-06 22:55:21 WARNING (MainThread) [homeassistant.components.sensor] Updating bom sensor took longer than the scheduled update interval 0:00:30
2018-08-06 22:55:21 WARNING (MainThread) [homeassistant.components.sensor] Updating darksky sensor took longer than the scheduled update interval 0:00:30
2018-08-06 22:55:25 WARNING (MainThread) [homeassistant.components.switch.wemo] Lost connection to Upstairs Toilet Light
2018-08-06 22:55:27 WARNING (MainThread) [homeassistant.components.sensor] Updating speedtest sensor took longer than the scheduled update interval 0:00:30
2018-08-06 22:55:27 WARNING (MainThread) [homeassistant.components.sensor] Updating ring sensor took longer than the scheduled update interval 0:00:30
2018-08-06 22:55:27 WARNING (MainThread) [homeassistant.components.sensor] Updating plex sensor took longer than the scheduled update interval 0:00:30
2018-08-06 22:55:27 WARNING (MainThread) [homeassistant.components.sensor] Updating synologydsm sensor took longer than the scheduled update interval 0:00:30
2018-08-06 22:55:29 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating ring binary_sensor took longer than the scheduled update interval 0:00:10
2018-08-06 22:55:29 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2018-08-06 22:55:30 WARNING (MainThread) [homeassistant.components.switch.wemo] Lost connection to Downstairs Bathroom Light
2018-08-06 22:55:30 WARNING (MainThread) [homeassistant.components.switch] Updating wemo switch took longer than the scheduled update interval 0:00:10
2018-08-06 22:55:35 WARNING (MainThread) [homeassistant.components.switch.wemo] Lost connection to Lauras Bedroom Light
2018-08-06 22:55:40 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating ring binary_sensor took longer than the scheduled update interval 0:00:10
2018-08-06 22:55:40 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2018-08-06 22:55:46 WARNING (MainThread) [homeassistant.components.switch.wemo] Lost connection to Backyard-Switch4
2018-08-06 22:55:51 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating ring binary_sensor took longer than the scheduled update interval 0:00:10
2018-08-06 22:55:51 WARNING (MainThread) [homeassistant.components.switch.wemo] Lost connection to Master Wardrobe Light
2018-08-06 22:55:52 WARNING (MainThread) [homeassistant.components.sensor] Updating bom sensor took longer than the scheduled update interval 0:00:30
2018-08-06 22:55:52 WARNING (MainThread) [homeassistant.components.sensor] Updating darksky sensor took longer than the scheduled update interval 0:00:30
2018-08-06 22:55:52 WARNING (MainThread) [homeassistant.components.switch] Updating wemo switch took longer than the scheduled update interval 0:00:10
2018-08-06 22:55:55 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.dark_sky_wind_speed is taking over 10 seconds
2018-08-06 22:55:55 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.bom_cabarita_rain_today is taking over 10 seconds
2018-08-06 22:55:56 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ring_upstairs_wifi_signal_category is taking over 10 seconds
2018-08-06 22:55:56 WARNING (MainThread) [homeassistant.components.switch.wemo] Lost connection to Gallery Light
2018-08-06 22:55:57 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.speedtest_ping is taking over 10 seconds
2018-08-06 22:55:57 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.memory_usage_real is taking over 10 seconds
2018-08-06 22:55:58 WARNING (MainThread) [homeassistant.components.sensor] Updating speedtest sensor took longer than the scheduled update interval 0:00:30
2018-08-06 22:55:58 WARNING (MainThread) [homeassistant.components.sensor] Updating ring sensor took longer than the scheduled update interval 0:00:30
2018-08-06 22:55:58 WARNING (MainThread) [homeassistant.components.sensor] Updating synologydsm sensor took longer than the scheduled update interval 0:00:30
2018-08-06 22:55:59 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.ring_front_door_ding is taking over 10 seconds
2018-08-06 22:56:01 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.samsung_tv is taking over 10 seconds
2018-08-06 22:56:01 WARNING (MainThread) [homeassistant.components.switch.wemo] Lost connection to Upstairs Toilet Light
2018-08-06 22:56:02 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating ring binary_sensor took longer than the scheduled update interval 0:00:10
2018-08-06 22:56:02 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2018-08-06 22:56:03 WARNING (MainThread) [homeassistant.components.switch] Updating wemo switch took longer than the scheduled update interval 0:00:10
2018-08-06 22:56:06 WARNING (MainThread) [homeassistant.components.switch.wemo] Lost connection to Spare Bedroom Light
2018-08-06 22:56:08 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.plex is taking over 10 seconds
2018-08-06 22:56:11 WARNING (MainThread) [homeassistant.components.switch.wemo] Lost connection to Backyard-Switch2
2018-08-06 22:56:13 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating ring binary_sensor took longer than the scheduled update interval 0:00:10
2018-08-06 22:56:13 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2018-08-06 22:56:13 WARNING (MainThread) [homeassistant.components.switch] Updating wemo switch took longer than the scheduled update interval 0:00:10
2018-08-06 22:56:15 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.multisensor_6_in_1_44 is taking over 10 seconds
2018-08-06 22:56:15 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.multisensor_6_in_1_44 is taking over 10 seconds
2018-08-06 22:56:16 WARNING (MainThread) [homeassistant.components.switch.wemo] Lost connection to backyard-switch1
1 reply
Also having delay issues.
I think you replied to the wrong person but I’m also having issues with the ddwrt device_tracker since the update.
Will Xiaomi Mi Smart Pedestal Fan be integrated?
Today exists this custom component: https://github.com/syssi/xiaomi_fan
Thanks in advance.
1 replyWhen the developer of the custom component submits a PR to include it, and it’s approved for inclusion.
