Glad you like it - If the auto-completion is not what you think it could be let us know; easy to add/improve it so lets know what could help you best
Thanks, I have now installed that ssh-addon and will have a play later!
Oh man, this is the feature I did not know I wanted. It’s perfect. Can’t wait to get started.
Because it Awesome!
@maxandersen Thanks
Thanks for doing this, I love iT1
Is Hass-cli different from hassio-cli, which is invoked with hassio
rather than hass-cli
Yes. Hass-cli is for homeassistant not hassio. That said eventually I could see us expose lot of what hassio does - at least for those things available via homeassistsant APIs.
So i’am using hass-cli but i can only ‘list/get’ items and i dont see the options i see on your demo on https://asciinema.org/a/216235?autoplay=1&speed=1 i don’t see the option for example to do ‘hass-cli entity delete’
Am i missing something?
1 replyits renamed to hass-cli state delete
and yes, I should get the ascinema recording updated
https://formulae.brew.sh/formula/homeassistant-cli is now at 0.7
haven’t yet found a way to automate updates of brew at release time - if anyone knows how I would love to get a contribution for making that happen!
1 replyI have a WIP on adding hassio-cli commands to hass-cli at https://github.com/home-assistant/home-assistant-cli/pull/276
but you can use https://github.com/home-assistant/hassio-cli to have hassio-cli and use it remotely.
Perhaps the kubernetes
guys have a solution:
Either that or via the brew
plugin for fastlane
somehow?
The challenge is that for python based brew formulas you need to somehow manually update the dependency info; kubernetes is just a single binary thus its fairly simply to a brew update.
I’m not sure what you refer to with respect to brew plugin for fastlane ?
If you find a way to automatically update the homebrew formula to please open a PR as these days I now have the release of hass-cli down to just be me doing a git tag which triggers build and release to pyp and the docker containers. I would like brew would be automated in the same flow.
1 reply(I was thinking about Fastlane the build automation suite, and that they have a plugin for brew
(/and cask
but maybe this:
Notice an application that’s out-of-date in Homebrew Cask? In most cases, it’s very simple to update it. We have a script that will ask for the new version number, and take care of updating the Cask file and submitting a pull request to us:
install and setup script - only needed once brew install vitorgalvao/tiny-scripts/cask-repair cask-repair --help # use to update <outdated_cask> cask-repair <outdated_cask>
If there is a more complicated change, or there is a case where cask-repair
fails (for example, where a Cask uses a url do
block or the language
stanza), you can also follow the steps in Adding a Cask to do the same thing manually. Remember to update the version
and shasum
values.
Just wanted to say thanks for making hass-cli. It has solved a problem for me in renaming a pile of Z-Wave entity_ids that get automatically created with ugly names. See What is the preferred way to rename z-wave entities? for my BASH 1-liner to save me endless clicking and typing, one entity at a time…
Would someone please be kind enough to help me get started with Home Assistant CLI on Windows 10? I already have Python installed. It doesn’t look like the instructions were meant for Windows 10.
All I want to do is turn OFF (or ON) my appliance using a python script. …So I can just execute Toaster-ON.py to turn on my toaster, for example. Looking forward to some assistance.
Hello, I am dead with trials. I want to run a service by hass-cli, but can not find proper format of the command. Lets say I have a tuya scene defined “both_yellow” that sets two lamps to yellow color. in Home-Assistant, I see the entity as scene.both_yellow. How do I run that scene from hass-cli please? Thank you very much, Jan
1 replyFor those people using this tool, it appears return UTC time for history queries, is that right?
I got one question that should be simple… How do I change my keyboard settings? I got a keyboard with a Belgian layout.
Can anyone see what I am doing wrong here when trying to add my server:
Thanks!
1 replyAnd what result do you get when you follow that recommendation?
try putting --server
before the (inner) command you want to run:
hass-cli --server http://blahblah info
Is this project abandoned? It’s not working, there are multiple issues with connection and discovery, and last release is 2-3 years ago now.
I am just looking for a way to run ha script commands from command-line remotely.
