Continue Discussion 36 replies
December 2021
VMG
This is awesome to have :slight_smile:
How ever this raises privacy concerns as I do not rely want HA at the Office to have my sensors and location data but like to have to for the home HA.
1 reply
December 2021
petro Great contributor
I guess I need to make a second server now
December 2021 ▶ VMG
VMG
As the Admin of the Office HA I can disable the sensors in HA but still users are not so lucky.
This should be configurable in the app per server.
1 reply
December 2021
tom_l
Update to HA core 2021.12.2 at least. It was brought back in that release.
1 reply
December 2021 ▶ tom_l
VMG
The problem is you can not configure it per server, so if you have the location service enable in the IOS App all HA server will get you location and you may not like to have it on the Office HA were all you co workers can monitor you.
December 2021
iamhueman
@zacwest You are the man! I’ve been waiting for this feature and it finally arrived, so happy to see this feature as I have multiple instances of HA (home, office, dev, etc). THANK YOU SO MUCH!
December 2021
zacwest
Enabling/disabling location per server is coming in a future release; it requires some core-side changes that mean it won’t be available until 2022.2 is out. You will be able to choose what is sent: exact coordinates, current zone name (home, work, not_home etc.), or no location data.
Enabling/disabling sensors per server is likely coming, too; I need to wrap my head around what I want to limit; e.g., whether it is all sensors or certain sensors.
1 reply
December 2021
e-raser
Maybe I missed something or you guys placed a bet on how long it will take until a guy asks the following question anyway:
(When) Will this great multi server support feature arrive in the Android app?
Now you can resolve your bets :smile:
December 2021 ▶ e-raser
arganto
Perhaps at the the time the ios app will bring the faceid/Touchid, Android already has a long time. :sweat_smile:
December 2021
Ildar_Gabdullin
iPhone 5S (iOS 12.5.5) - the App does not start.
1 reply
December 2021
zacwest
December 2021
Argo
Love this, thanks a ton!
ctml
I’ll be the second asking about Android. Been trying to figure this out as it’s been a feature I’ve been wanting for years after setting up HA in two locations.
December 2021
smarty
Tremendous news! What about multiserver support for Android smartphones?
December 2021
pplucky
Is it just me, or this three-finger swipe is not the most effective way of switching between servers? Is adding a button somewhere - in sidebar, for instance - an option, to avoid having to go through settings, servers and activate?
I end up changing input_selects, switches or input_booleans by chance while I’m trying to swipe (and it doesn’t always work).
Tried both in an iPhone and Mac, doesn’t work properly in either.
@zacwest Any thoughts on this?
December 2021 ▶ pplucky
VMG
Not dust you, I find it awkward to use three-finger on the screen.
December 2021 ▶ zacwest
pplucky
Is enabling/disabling notifications also a setting to be considered per server?
1 reply
December 2021
Alfagek
Awesome work. It’s easy to controle my own system and my dads system.
Only thing I now have, if I use “shortcuts” in iOS, I have to tell to which server.
Do use for example in “shortcuts”, loading my phone: toggle lights off. And normally it’s works flawless, but now my phone is asking, which server to select, before the lights are getting toggled. That’s not really “automated”.
How can I fix that?
Thanks in advanced.
December 2021 ▶ Alfagek
pplucky
Not sure if this can be considered as a breaking change in ‘Shortcuts’, but it sure looks like.
I had the same “issue” as you and I had to edit all my Shortcut HA actions to indicate in which system it should run (to avoid the popup to appear).
After that, shortcuts resumed working as before.
December 2021
pplucky
I had the same “issue” as you and I had to edit all my Shortcuts’ HA actions to indicate in which system it should run (to avoid the popup to appear).
Odd, I didn’t have to update anything. However I only have 1 server. Do you have multiple servers? If yes, then I would expect that you’d have to do that regardless.
Alfagek
How did you select which server to use in shortcuts?
December 2021
zacwest
You will need to update existing shortcuts when adding additional servers. If you do not add additional, the existing ones will not prompt for server choice.
You can edit the server for a Shortcut by exposing the additional options in the Shortcut.:
1 reply
December 2021
zacwest
1 reply
zacwest
Notifications is a little more tricky as it’s a received action. I’m not sure. I can’t stop the server from sending the notifications, and Apple has repeatedly denied us permission to prevent certain notifications from showing upon delivery. I can likely remove the notify service though.
Can you speak more about what situation you want this to happen in?
Alfagek
Thanks a lot.
The first time it didn’t show up. But it’s now showing and working :+1:t2:
December 2021
hwinkel
After update to the latest IoS Version the UI regulary does not load and delivers a empty screen. Just a Restart of the app helps. Anyone have the same expierence?
1 reply
December 2021 ▶ hwinkel
We’re aware and a fix is being tested. Should be in next hot fix of Home Assistant (Core, not iOS).
January 2022
benjycov
Just to add, this is totally awesome and has totally transformed life.
January 2022
neliss
Thanks so much for making this possible! I will put it to good use :blush:
January 2022
ValentinoRa
I also need to use 2 HA instances, I hope the multiserver feature will be considered soon also for android app.
1 reply
January 2022 ▶ ValentinoRa
smarty
As I understood from the latest livestream, multiserver support is considered for Android also, but currently Wear OS support is priority.
January 2022
theadlee
For some reason I can’t get the three finger swipe for multi server to work on MacOs Monteray. This on a 14" M1 Macbook Pro. Any ideas? I can switch servers via the app preferences window but not with three finger swipe.
July 2022
leweems
Does multi-sever functionality support more than 2 servers? When I try to add a third remote server (Nabu Casa), it just logs me into server but doesn’t add the server so I can swipe to it.
February 2023 ▶ zacwest
filmgarage
I would like to add a button entity or Lovelace button card in my dashboard to link to the secondary server to allow me to switch for one server to the other without swiping with three fingers. I can easily add a navigation link in the button card but it will open the second server in the browser instead of the companion app. Is there a way to stay in the app?
May 2023
rhodan52
Not sure when they came out with it but it is indeed possible to add multiple instances on the Android phone. Log into HA, go to Companion App. At the top you have Servers & Devices - Click add server.
I haven’t test it on two servers that both use Nabu Casa (just 1 Nabu Casa and a local instance), but I don’t see why it wouldn’t work.
