0.101: Airly, Apprise, Sinch, Solar-Log, Microsoft Teams
Scenes (using covers) do not work with 0.101.0 . They used to work flawlessly with previous versions incl. 0.100.3
This is an excerpt from my scenes.yaml:
- name: Privacy
  entities:
    cover.neq1368021:
      position: 0
    cover.neq1368092:
      position: 30
    cover.neq1368281:
      position: 30
This is printed in the logs:
2019-10-31 10:25:12 ERROR (MainThread) [homeassistant.config] Invalid config for [scene]: State for cover.neq1368021 should be a string for dictionary value @ data['states'][0]['entities']. Got None. (See /config/scenes.yaml, line 0). Please check the docs at https://home-assistant.io/integrations/scene/
2019-10-31 10:25:12 ERROR (MainThread) [homeassistant.config] Invalid config for [scene]: State for cover.neq1367183 should be a string for dictionary value @ data['states'][0]['entities']. Got None. (See /config/scenes.yaml, line 11). Please check the docs at https://home-assistant.io/integrations/scene/
Failed to load no matter what I remove from config… it was streaming, then scripts, then darksky. After rollback to 0.100.3 it is the same… fails. What to do now… I noticed some cryptography, libav things un and installing…
Ok, after about 20 mins the prev version loaded again.
My configuration checks out ok with no errors, and I’m not seeing anything unusual in the logs, but my 2 attempts to upgrade have failed as others have already noted.
I get a Failed config
General Error: light.led_strip
Not sure if it crashes at the entity setup or on a scene definition but 101.0 will not start-up with it.
in config light.led_strip looks like this.
light:
 - platform: limitlessled
   bridges:
      - host: !secret ll_host
        version: 5
        port: 8899
        groups:
        - number: 1
          fade: on
        - number: 2
          fade: on
        - number: 3
          fade: on
WITH
scene:
 - name: romantic
   entities:
    light.tabletop_lamps:
       state: on
       brightness_pct: 15
       rgb_color: [220, 20, 60]
    light.led_strip:
       state: on
       brightness_pct: 15
 - name: movie
   entities:
    light.led_strip:
       state: on
       brightness_pct: 10
       rgb_color: [65, 105, 225]
       state: off
 - name: bright
   entities:
       state: on
       brightness_pct: 100
       rgb_color: [255, 255, 255]
    light.led_strip:
       state: on
       brightness_pct: 100
 - name: nite
   entities:
        state: on
        brightness_pct: 10
        rgb_color: [245, 245, 245]
    light.led_strip:
        state: on
        brightness_pct: 10
 - name: casual
   entities:
       state: on
       brightness_pct: 50
    light.led_strip:
       state: on
       brightness_pct: 50
Same error as others have reported
"No module named ‘hass_frontend’
Okay,
with 0.101.x it needs to be changed to:
- name: My Scene
  entities:
    cover.neq1368021:
      state: closed
      current_position: 0
    cover.neq1368092:
      state: open
      current_position: 30
No module named ‘hass_frontend`
I was able to resolve this issue by moving the frontend directive
frontend was moved immediately after the homeassistant block
eg
OLD
homeassistant:
logger:
frontend:
config:
history:
the following passes config checks
NEW
homeassistant:
frontend:
config:
logger:
history:
Upgrade Successful
These solved the problem:
in configuration.yaml:
host: 127.0.0.1
When registering the discovered integration:
host: 127.0.0.1
username: glances
password:
port: 61209 (I had problem to setup 61208 port).
The same host address used in Glances config.
Now it works as before the upgrade.
Got following error :frowning:
[22:39:19] INFO: Installed Home Assistant 0.101.0
[22:39:19] INFO: Making a copy of your configuration for checking...
[22:40:24] INFO: Checking your configuration against this version...
[22:54:55] ERROR: The configuration check did not pass!
[22:54:55] ERROR: See the output below for more details.
INFO:homeassistant.util.package:Attempting install of colorlog==4.0.2
Testing configuration at /tmp/config
INFO:homeassistant.util.package:Attempting install of aioesphomeapi==2.4.2
INFO:homeassistant.util.package:Attempting install of home-assistant-frontend==20191025.1
INFO:homeassistant.util.package:Attempting install of aiofiles==0.4.0
INFO:homeassistant.util.package:Attempting install of backoff==1.8.0
INFO:homeassistant.util.package:Attempting install of aiogithubapi==0.2.0
INFO:homeassistant.util.package:Attempting install of integrationhelper==0.2.2
INFO:homeassistant.util.package:Attempting install of HAP-python==2.6.0
INFO:homeassistant.util.package:Attempting install of aiohttp_cors==0.7.0
INFO:homeassistant.util.package:Attempting install of aiohue==1.9.2
INFO:homeassistant.util.package:Attempting install of sqlalchemy==1.3.10
INFO:homeassistant.util.package:Attempting install of av==6.1.2
INFO:homeassistant.util.package:Attempting install of python-telegram-bot==11.1.0
INFO:homeassistant.util.package:Attempting install of mutagen==1.42.0
INFO:homeassistant.util.package:Attempting install of distro==1.4.0
INFO:homeassistant.util.package:Attempting install of homeassistant-pyozw==0.1.4
INFO:homeassistant.util.package:Attempting install of gTTS-token==1.1.3
INFO:homeassistant.util.package:Attempting install of bomradarloop==0.1.3
INFO:homeassistant.util.package:Attempting install of python-forecastio==1.4.0
INFO:homeassistant.util.package:Attempting install of construct==2.9.45
INFO:homeassistant.util.package:Attempting install of python-miio==0.4.6
INFO:homeassistant.util.package:Attempting install of PyTransportNSW==0.1.1
INFO:homeassistant.util.package:Attempting install of psutil==5.6.3
Failed config
  homeassistant.packages.history.history:
    - Package history setup failed. Component history No module named 'sqlalchemy'
    - history: None
  homeassistant.packages.logbook.logbook:
    - Package logbook setup failed. Component logbook No module named 'sqlalchemy'
    - logbook: None
Successful config (partial)
Small problem following maj. On Lovelace my calendar does not just give the state.
[%key_id:state::default::on%]
Sans%20titre
same issue here on check config
what can be the cause?
Failed config
  General Errors:
    - Platform error notify.html5 - No module named 'hass_frontend'
    - Component error: history - No module named 'sqlalchemy'
from what I have been following with the MyQ component. there is a fix. hopefully it will be in the next minor release.
What have you been following?
Ok - once again, my mistake. I failed to remove the api_password which has been deprecated.
Once I removed that line, the upgrade worked.
I found I had to update to v0.101.0 before I was able to to ‘check config’.
Once updated config check now works again.
A lot of people have issues with sqlalchemy in this HA update.
List of changes mentions sqlalchemy upgrade twice:
  1. Upgrade sqlalchemy to 1.3.9 (@fabaff - #27322)
  2. Bump sqlalchemy to 1.3.10 (@frenck - #27408)
I wonder if that’s got something to do with it :slight_smile:
Same issue as reported by others:
Failed config
General Errors:
- Component error: logbook - No module named ‘sqlalchemy’
- Platform error notify.html5 - No module named ‘hass_frontend’
Exact the same errors, don’t think it’s an issue though… Did you already upgrade?
