I had a bulk renaming problem to solve unrelated to doing a Home Assistant upgrade, and found that using hass-cli
in a shell script a good solution to bulk entity renaming. See the thread over here: What is the preferred way to rename z-wave entities? - #173 by lmamakos for some info that technique.
i threw myself over a “ctrl + f” yet again to be disappointed
there is still a bug affecting everyone using more than one philips hue bridge wanting to apply hue scenes. so close but still no cigar
This update creates a mes with my deconz groups, hue platform did not work and a lot of my input_boolean got renamed to _2.
So stay away if you dont want a lot of work…
Painless update for me. Well done folks.
Is there any plan to add the new input_*.reload
services to the Configuration/Server Controls
menu?
I get these errors after update:
2020-01-16 09:22:05 ERROR (MainThread) [aiounifi.api] Couldn't find key: 'None'
2020-01-16 09:22:05 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 284, in async_update_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 320, in _async_write_ha_state
state = self.state
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 588, in state
return STATE_ON if self.is_on else STATE_OFF
File "/usr/src/homeassistant/homeassistant/components/unifi/switch.py", line 219, in is_on
return self.port.poe_mode != "off"
File "/usr/src/homeassistant/homeassistant/components/unifi/switch.py", line 264, in port
return self.device.ports[self.client.sw_port]
AttributeError: 'NoneType' object has no attribute 'ports'
after update, my MPD media player is failing to init.
I’ve got this error:
mpd: Error on device update!
File “/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py”, line 299, in _async_add_entity
await entity.async_device_update(warning=False)
File “/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity.py”, line 461, in async_device_update
await self.hass.async_add_executor_job(self.update)
File “/usr/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/mpd/media_player.py”, line 154, in update
self._fetch_status()
File “/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/mpd/media_player.py”, line 136, in _fetch_status
position = self._status[“time”]
KeyError: ‘time’
Any idea? I guess it’s related to @ndonegan changes.
Hi, QNAP NAS after update, failing to start. I’ve got this error:
Failed to fetch QNAP stats from the NAS
File "/usr/src/homeassistant/homeassistant/components/qnap/sensor.py", line 191, in update
self.data["system_stats"] = self._api.get_system_stats()
File "/usr/local/lib/python3.7/site-packages/qnapstats/qnap_stats.py", line 207, in get_system_stats
force_list=("DNS_LIST")
File "/usr/local/lib/python3.7/site-packages/qnapstats/qnap_stats.py", line 67, in _get_url
self._init_session()
File "/usr/local/lib/python3.7/site-packages/qnapstats/qnap_stats.py", line 49, in _init_session
if self._login() is False:
File "/usr/local/lib/python3.7/site-packages/qnapstats/qnap_stats.py", line 57, in _login
result = self._execute_post_url("authLogin.cgi", data, False)
File "/usr/local/lib/python3.7/site-packages/qnapstats/qnap_stats.py", line 98, in _execute_post_url
return self._handle_response(resp, **kwargs)
File "/usr/local/lib/python3.7/site-packages/qnapstats/qnap_stats.py", line 110, in _handle_response
data = xmltodict.parse(resp.content, force_list=force_list)['QDocRoot']
File "/usr/local/lib/python3.7/site-packages/xmltodict.py", line 173, in parse
handler = _DictSAXHandler(*args, **kwargs)
TypeError: __init__() got an unexpected keyword argument 'force_list'
Checked config, restarted couple of times, even rebooted hassio. Nothing helped.
The HEOS integration doesn’t work anymore. My devices were unavailable → I removed the integration and wanted to re-add it via Lovelace, but HEOS is not available as an option…
Working fine for me
I’m concerned about upgrading and having to do all that work to get deCONZ to work properly again + all automations and scripts around it.
@Robban @frenck do you have any tips or things to check before upgrading to ensure a smooth(er) upgrade?
Working for me now too. I was using the custom component from @tormagj. The built-in integration works indeed.
Is there a way to get the all_lights group back ? I use it in node-red (together with some function node) to turn off all lights EXCEPT a couple …
Also the locks group was quite handy to lock all my doors at night, or to check if all the doors were locked. How should this be done now ? Do I have to create (and maintain …) these groups manually now ?
Removing all these groups is quite a big change. Is there a way to get them back ?
Seems like the new “light buttons” do not respect defined groups in groups.yaml?
I have the generated lovelace view. Instead of my previously organised groups with light switches, I now have a bunch of unorganised big buttons , any way to go back to switches without customizing the lovelace view?
@devastator there’s this:
This is way too cumbersome. Do I need to create a new binary_sensor too to check if all doors are locked ?
But disappointed by this drop without a simple replacement or way to turn it back on.
Praise the lord for fixing the RFXtrx covers! Up to now, “up” was “down” and vice versa!
This is cumbersome?
- service: light.turn_on
entity_id: all
You can still create your own groups too.
Yes, and then I have to maintain them too. Point is, this was all done automatically. Add a lock to the system, the UI was immediately up to date thanks to the all_locks group.
I ninja edited my post. Did you see this?
entity_id: all
I’ve done the prerequisite work of removing existing ring config but when I go to integrations and click ‘Ring’ it goes back to the choose integration pop up.
Log shows
Error occurred loading config flow for integration ring: cannot import name 'Auth' from 'ring_doorbell' (/config/ring_doorbell/__init__.py)
I did previously do the Ring workaround, could this be affecting it?
Edit - Deleted the folder ring_doorbell from config and it’s working.
