Yes, I am using also some of the ones you mentioned. I would add also mini-graph to your list.
But the question is, how do we still use them? Where is the problem? Should we contact the developer of each card or is there something wrong in this release and wait for 110.x?
I notice that some of them were already updated. e.g Custom Header. This was also bugging my configuration.
same problem around here, back to version 109.6
I replaced by a state-label card
I used the circle card to indicate fuel amount and fuel range, would like to find something similar, any suggestions to what to use rather than the circle-card ?
yeah, use state-label card …
i also used circle-card for my fuel and range, replaced with state-label
do you use the audi mmi integration by any chance? there is an example in the thread there
No, I use the BMW Connected… But for now I’ll adapt to the example you provided Nice example, thx bud!
Fin bil
I have a 530d, unfortunately too old to be ‘connected’.
Anyway, think I’ll wait for the custom cards to be updated before trying to upgrade again. Too much work have gone into the yaml.
Thanks for this, very helpful in hunting down these issues
BTW, I have text-element working fine. However, you can add big-number to the not working list.
Takk Ole
@pergola.fabio Can you please post your not working code, the one that was visible in the picture? Maybe Petro can take a look? 10x
Mine’s is quite big to post it here.
Did anyone managed to solved this? I have upgraded some of the cards but the issue is still there.
The issue was solved by updating the custom:circle-sensor-card according to him.
Well, the issue is not solved, he just replaced with something else.
But in my case I do not have alternatives.
@olealm add this to the list: simple-weather-card
For example, I have this(see bellow), if I use it stand alone this is working fine, but as soon as I add it to a picture element card with several elements, will ruin my entire card.
type: 'custom:simple-weather-card'
backdrop: false
entity: weather.dark_sky
style: |
:host {
left: 25%;
top: 80%;
ha-card {
background: none !important;
box-shadow: none !important;
flex-flow: row-reverse !important;
padding: 0 !important;
.weather__info--add{
display : none !important;
.weather__info{
flex-grow: 1;
min-height: 0 !important;
height: 2.4vw;
margin-left: 0.6vw;
.weather__icon{
margin-right:0.5% !important;
margin-top: -1%;
width: 2vw !important;
height: 2vw !important;
flex: 0 0 2vw !important;
**strong text**
You can’t style elements inside picture elements with card mod. You have to put the style for elements on the picture element card and use a selector to get to the object element you want to style. This has always been the case.
OK, thank you for the hint. I will try that as well.
OK, I did what you suggested and it does not work.
I tend to believe that is not the issue because it applies only to some of them. If it would be like you said than it would be the case for all of them, no?
And then I raise the question, why now? What changed in picture element card?
(Sorry if I insist on this but, I have worked on it 3 weeks before the update. I enjoy it for two days and now it’s gone.)
It’s always been the case.
picture elements card has a built in style field that is required. Card mod overrides it. The style field is required for positioning. Unless I’m mistaken, the only option is place the card-mod modifications on the elements card.
something like this
type: picture-elements
style:
card-mod-styles using selectors
elements:
- type: custom:simple-weather-card
etc...
style:
left: 25%
top: 80%
The problem is, you’ll have to use the correct selector(s) and bypass the shadow root elements using $:
EDIT: There’s an advanced usage section now that helps you through this process
using
debug_cardmod: true
will help.
Ok, I think I am lost. I don’t think it is related to styles.
I have this, can you explain on this?
This is the most basic configuration I can think off. It reproduces the error. There is no styling on it.
I still believe there is an error with the picture-elements card.
elements:
- type: state-badge
entity: sensor.washing_machine_status
- entity: weather.dark_sky
image: 'https://demo.home-assistant.io/stub_config/floorplan.png'
