I am using mariadb and I am pleased to advise that the database seems to have updated just fine. I still have data back to well before updating to 0.112. Well done on upgrading the database schema to get these speed improvements. Love your work.
This looks similar to my issue, where during the migration it says it loses connection to DB, but the DB remains up, then it’ll start and Recorder won’t work.
Got this message while trying to update to 112.1
HomeAssistant update fails -> rollback!
20-07-03 07:21:56 INFO (SyncWorker_19) [supervisor.docker.interface] Update image homeassistant/intel-nuc-homeassistant:0.112.0 to homeassistant/intel-nuc-homeassistant:0.112.1
20-07-03 07:21:56 INFO (SyncWorker_19) [supervisor.docker.interface] Pull image homeassistant/intel-nuc-homeassistant tag 0.112.1.
20-07-03 07:22:56 ERROR (MainThread) [supervisor.utils] Can't execute update while a task is in progress
20-07-03 07:23:07 INFO (SyncWorker_19) [supervisor.docker.interface] Stop homeassistant application
20-07-03 07:23:08 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Received message 8:1000 is not str
20-07-03 07:23:08 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
20-07-03 07:24:08 INFO (SyncWorker_19) [supervisor.docker.interface] Clean homeassistant application
20-07-03 07:24:08 INFO (MainThread) [supervisor.homeassistant] Update pulse/client.config: /data/tmp/homeassistant_pulse
20-07-03 07:24:08 INFO (SyncWorker_8) [supervisor.docker.homeassistant] Start homeassistant homeassistant/intel-nuc-homeassistant with version 0.112.1
20-07-03 07:24:13 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation in progress
20-07-03 07:24:28 INFO (MainThread) [supervisor.homeassistant] Updated Home Assistant API token
20-07-03 07:25:08 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation done
20-07-03 07:35:10 WARNING (MainThread) [supervisor.homeassistant] Don't wait anymore of Home Assistant startup!
20-07-03 07:35:10 CRITICAL (MainThread) [supervisor.homeassistant] HomeAssistant update fails -> rollback!
20-07-03 07:35:10 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.112.0
System is okay, however I could not upgrade to 112.1
Whenever i update, the update seems to go through fine, everything boots up and is working fine, shows on the latest version number then after a few mins home assistant restarts and never comes back up. I have to manually power cycle and when it starts up its back on the old version? Anyone else seen this happen?
Hello, I will need some help please. Namely after upgrade to 0.112 my xiaomi philips lamps are not working. Can you point me in which direction to go.
Thank you very much.
BR
Thank you everybody who is involved for the continuing amazing work!
I got a failure and my Logbook just shows the loading indicator:
Logger: aiohttp.server
Source: core.py:118
First occurred: 10:30:41 AM (1 occurrences)
Last logged: 10:30:41 AM
Error handling request
File “/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py”, line 418, in start
resp = await task
File “/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py”, line 458, in _handle
resp = await handler(request)
File “/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py”, line 119, in impl
return await handler(request)
File “/usr/src/homeassistant/homeassistant/components/http/real_ip.py”, line 39, in real_ip_middleware
File “/usr/src/homeassistant/homeassistant/components/http/ban.py”, line 73, in ban_middleware
File “/usr/src/homeassistant/homeassistant/components/http/auth.py”, line 127, in auth_middleware
File “/usr/src/homeassistant/homeassistant/components/http/view.py”, line 129, in handle
result = await result
File “/usr/src/homeassistant/homeassistant/components/logbook/init.py”, line 195, in get
return await hass.async_add_job(json_events)
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/usr/src/homeassistant/homeassistant/components/logbook/init.py”, line 192, in json_events
_get_events(hass, self.config, start_day, end_day, entity_id)
File “/usr/src/homeassistant/homeassistant/components/logbook/init.py”, line 376, in _get_events
entity_ids = _get_related_entity_ids(session, entities_filter)
File “/usr/src/homeassistant/homeassistant/components/logbook/init.py”, line 335, in _get_related_entity_ids
result = [row.entity_id for row in query if entity_filter(row.entity_id)]
File “/usr/src/homeassistant/homeassistant/helpers/entityfilter.py”, line 167, in entity_filter_2
domain = split_entity_id(entity_id)[0]
File “/usr/src/homeassistant/homeassistant/core.py”, line 118, in split_entity_id
return entity_id.split(“.”, 1)
AttributeError: ‘NoneType’ object has no attribute ‘split’
I checked my MariaDB and it looks like the upgrade went well
I just put in a netgate/pfsense firewall as well as 4 unify UAP-AC-M-US mesh AP’s a couple weeks ago replacing all my other various ap’s. The Ubiquity management server caused me a bit of grief at first and one unit was stubborn about adopting but its all stable now that it’s on my NUC. I was on a FaceTime call w my sis tonite and walked around my property and the AP roaming/handoff function was Simply flawless. It was so good, I didn’t even realize it at the time. No way I could do that before. Its certainly got my vote.
This last update to supervisor 228 was an unmitigated disaster as my install is on Supervised on generic Linux/Docker (recently un-deprecated, thankfully) on my NUC but a full reinstall/restore fix it. After moving off my Pi, I’m Loving Ubuntu. What a Slick OS.
wow, this is awkward. seeing this for all my scripts rendering the integration script invalid, which of course makes my complete HA instance useless:
Package package_printers setup failed. Integration script cannot import name 'EVENT_SCRIPT_STARTED' from 'homeassistant.const' (/usr/src/homeassistant/homeassistant/const.py) (See /config/packages/package_printers.yaml:5).
It only mentions the packages because the script is declared there. All scripts are gone…
I am testing the new script integration as a custom component, so that might be it (it worked flawlessly on 111.4) but taking it out also causes issues, rendering the script integration not to be setup.
I’m with you on this one. 90+% of the time I use home assistant from iPads/iPhone. History flashes briefly on safari, but nothing on chrome. Very annoying. At least let me remove the link When I’m on iOS to free up some Menu real estate.
Oh yes, I got MQTT too !
Add in the HACS sidebar-order feature and I have made space for what I need to add too.
Thanks @VDRainer
- name: panel-redirect
# url_path needs to be unique for each panel_custom config
url_path: redirect-mqtt-controls
sidebar_title: MQTT
sidebar_icon: mdi:lan-pending
module_url: /local/panel-redirect.js
config:
# Where you want to redirect to
target: /config/mqtt?config_entry=88d8fc6108a64d61a78bf7236a21b7c9
