0.112: Making things faster; Logbook & History
Yes. The History comes up correctly in 4-5 seconds on a Windows client or Linux browser client. My HA runs on a NUC.
The data is there in the browser. If you poke your finger on the white area you get the same pop up windows with correct content as when you hover the mouse over the area in windows/Linux browser.
You can also see that the browser in IOS adds a scroll bar on the right and you can scroll down in the white area. The data is there.
It is just rendered white on white which makes me think CSS issue
Well, I doubt anything will be done because the issue you keep linking isn’t correct for everyone. I have iOS 12 and iOS 13 devices, including an iPad with working history. If this is the case for the devs, then how can they correct an issue they can’t see?
It’s it possible that the color theme for your ui needs to be adjusted?
I run all default colour scheme. I have no custom anything related to styling my HA. I like the default design. And it should be the same in IOS and on Windows/Linux clients.
The Xiaomi Miio Air Purifier integration stopped working after upgrading to 0.112:
[homeassistant.components.xiaomi_miio.fan] Got exception while fetching the state: {'code': -5001, 'message': 'command error'}
Anyone else having this issue?
I have an important update in debugging the history on IOS but I think we have hijacked this enough. I just wanted to raise an awareness post. I will put some updates on the github item and I will be updating more later today (I am at work now)
I am also facing this issue.
Are dashboards / wall tablets a problem with this release? Have seen reports on Reddits the new disconnect if hidden/idle feature breaks them?
Can confirm that the hamburger icon is not displayed after clicking the Configuration menu item (and I refreshed the page with Ctrl+F5).
Screenshot from 2020-07-02 09-44-33
Should be displayed in the upper left hand corner, but it’s not. This is with the option “Always hide the sidebar” enabled.
EDIT
Opened a new issue in the frontend repo.
Didn’t see you had already opened an issue … and it has already been addressed.
Maybe try to add manually ? Mine Denon AVR x4000 works
Anyone else having an issue with a wake on lan switch
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 130, in handle_call_service
    connection.context(msg),
  File "/usr/src/homeassistant/homeassistant/core.py", line 1260, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1295, in _execute_service
    await handler.func(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 209, in handle_service
    self._platforms.values(), func, call, required_features
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 454, in entity_service_call
    future.result()  # pop exception if have
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 595, in async_request_call
    await coro
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 485, in _handle_entity_call
    await result
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 621, in async_turn_on
    await self.hass.async_add_executor_job(ft.partial(self.turn_on, **kwargs))
  File "/usr/src/homeassistant/homeassistant/components/wake_on_lan/switch.py", line 103, in turn_on
    port=self._broadcast_port,
  File "/usr/local/lib/python3.7/site-packages/wakeonlan.py", line 79, in send_magic_packet
    sock.connect((ip, port))
TypeError: an integer is required (got type NoneType)
direct service call on wake_on_lan.send_magic_packet seems to work.
On the off chance you aren’t joking, PLEASE don’t do that. And even if you were joking, others may not realize it - so don’t encourage others to do that unless they have useful debug information to add that isn’t already in the thread.
The proper way to “me too” is to click the reaction icon (thumbs up) on the original post of a issue.
You are 100% correct, I did not envision people actually typing “Me Too !”
I shall edit my post ‘above’ accordingly
The notify message you get when there is an error in your config, refering to the logs; It still refers to where to logs used to be. @frenck
Yes, this has been fixed for 0.112.1
Upgrade from 0.111.4 to 0.112.0 with no issues from HA. Only issues were from HACS with were resolved with updates.
Not sure if it has been mentioned but has the server restart button been moved above the yaml reload buttons in the server controls page? If so, thank you! I like the new position.
My zigbee2mqtt setup stopped working with HA 0.112. Up until now, I used for my config/configuration.yaml
mqtt:
 discovery: true
 password: pw
and for the zigbee2mqtt/configuration.yaml
"mqtt": {
  "base_topic": "zigbee2mqtt",
  "server": "mqtt://homeassistant",
  "user": "user",
  "password": "pw"
I had the same. They removed (after a year with warnings) the internal MQTT broker:
MQTT
  • The embedded MQTT broker, which has been marked as deprecated for the past year, has now been removed.
  • Remove MQTT broker tls_version parameter from your configuration and instead rely on auto negotiation.
You can use for: with a numeric state trigger…
