really weird. I just tried with another client and it’s the same. The url I enter is for sure correct (copy & paste) but there is just no reaction what so ever (error, animation,modal close…) when the the ADD
button is clicked.
Check the supervisor system logs.
Can confirm it works in 113.3.
What’s the URL?
https://github.com/hassio-addons/repository
Checked that. Nothing in the logs about it.
I also just restarted ha and it’s still not working.
There’s something we wrong with that repository. I can’t add it. I can add others. The Picotts repo for example.
Edit: I’m an idiot. I already have that repository installed.
Edit2: actually my community addons repo link is: https://addons.community/ which is different.
Try
https://github.com/roblandry/addon-shinobi
this did the trick indeed!
Does anyone have an idea where this is used:
mdi:github-circle was renamed to mdi:github, please change your config
I don’t use it and couldn’t find it in any of my addons or integrations (and I don’t use packages).
Just do a search in your config dir, it’s there somewhere… Probably in a custom integration
Nope. Already did that.
Could be an addon? I have one like that (Logviewer)?
I had a look at all my addons (I don’t use logviewer) and could not see it being used.
Issue solved starting 0.114.0b3
All OK now…
Best, JR
hi there, anybody can provide any pointers on this issue…
It seems that the re-coding of the enOcean module has been integrated in the main branch of development, and is therefore included in the 0.113 release.
Nonetheless, nothing about that is mentionned in the release notes… Am I wrong about the inclusion ? (I saw it in GitHub), or is this something that has been forgotten ??
I’m asking because I had some customizations of the module in local, working without a hitch during months, and they now crash after updating to 0.113…
It’s in the all changes section.
Oh right, I searched in the page but did not deploy the “all changes” part, sorry.
anyone seeing dysan component start failing in 0.113.3 after hassio 4.12 upgrade?
That is not related to the upgrade, but an issue with a change in the Dyson API, fix has been made and included in tomorrows 0.114.0 release
