0.114: Dark mode, Open Z-Wave progress and more automation & scripts
I just woke up this morning to a “dark” home assistant on android, which looks hoerible with my dashboard layout which was designed to work only with a white background. I looked up dark mode home assistant and landed up here to this update
There are NO dark/light/auto settings available in my user profile, I believe because I haven’t updated home assistant itself! The android app updated on its own and HA is still an old version and now I am stuck with dark mode! With all due respect, this isn’t the way to release features
Just updated to 114.1 and all the Covid sensors are broken. Is this a known issue? I haven’t seen anyone reported it…
After applying 0.114.1 I am missing HACS: 2020-08-17 09:09:25 ERROR (MainThread) [homeassistant.setup] Setup failed for hacs: Integration not found.
Anyone else has this issue?
That’s different, for the fadein/out function of the script i control this per parameter. Runtime acutally is between 15 and 30 min ( i have to simulate sunrise and sundown, this is a wish from my wife and not discutable :blush:) For all other functions of the Script (status requests etc.) the 60sec are no problem they are naturaly much quicker. First I tested the Flux LED/MagicLight integration but that fits not for all of my needs so wrote my own script.
Did you figure this out? I would like to get the precipitation also. I can’t find enough information on the secondary info attribute. There is more than one precipitation shown so I believe that is causing the issue. Not sure how to call out the correct one?
hi steven, the idea with the starter script works perfect, except nohup but no need for that, shell_command starter_script fires up my led.sh in the background and terminates quickly thats all i need :+1:
How to add it would depend on whether you use the UI or YAML mode to configure Lovelace. I use YAML and this is mine (a previous poster shows where to add it using the UI):
        - type: weather-forecast
          entity: weather.home
          secondary_info_attribute: precipitation
The docs are here.
I only see one precipitation value per day in my state info though. I don’t know why you’d see more.
Whichever way, I still see the unformatted value.
just updated HASS to 0.114 and updated the android app as well- it still does not switch to light mode even on changing it from the user profile. I am using it on a Pixel 4, so there’s no chance of android OS issues. ONLY on turning off the dark mode in android does it show up in the light mode again!
Hmm, apparently it does, because now it reports 86%… :slight_smile:
Thanks. It seems like nohup is going to be the a good solution in this case.
Was systemmonitor impacted by this change? I don’t see it in the notes but since the upgrade to .114 I no longer get my systemmonitor entities.
I had the same issue after 0.114.2
but a restart solved it
I’ve restarted several times now and I still don’t see the HACS tab nor are any of my custom components working. Anyone else has any ideas?
Update: went to 114.2 and now systemmonitor is back.
@markusmazurczak - Did you get to the bottom of this, I am having the exact same issue when I upgraded too
@jegormeister - I am having the same problem, not sure whats up yet
Theres a fix for this in the works now to allow the user to change the apps theme as well.
GDPR also applies to associations, commercial or not. It is only private people collecting data related to family and friends. A project like Home Assistant that has a clear leadership making decisions must comply with GDPR. I hate GDPR so I am not telling you because I want you to start nagging me with spam and popups. I am just passing on what I know from other open source projects I am associated with.
Adding on top of this that Home Assistant defacto is run by same leader as Nabu Casa there is a likelyhood that a court can find Nabu Casa responsible for the data. And quite honestly that is what I think too. You can no longer separate Nabu Casa from Home Assistant.
Thanks for you reply. I personally don’t care or have a play in it. I think you are wrong though.
Im very happy with this update!! Runs fast with a restart! THANKS DEVS !!
