Hmm…
I think I remember asking exactly that same question a while back in that other thread and if memory serves I was never given an answer then…
Hmm…
Not sure if it has to do with 0.118.5, but my I had a node-red flow that had a “switch” node in it. It would would switch the payload from “on” to “off.” Was working fine until I updated. Now for some reason the msg.payload won’t change unless I have the initial node feeding in data output as boolean value instead of a string like it was before. Weird but thought I’d throw it out there.
I’ve seen this before, and it’s usually a browser cache issue. Try reloading the page (F5).
Hi @heyepic
I got excatly the same issue on my side (also running it under Synology)
Impossible to upgrade my 0.118.4 version to 2020.12.1
System always reports “Unknown error, see supervisor” and here are the error I have under supervisor (same as you)
I really don"t know how to fix this. If someone has any idea that would be great.
Did you click on the read more link or look in the supervisor log?
Most likely you are not using Debian Buster or HAOS and are using watchtower. Just a guess.
Yes indeed Watchtower was installed but not working (I never be able to make it work properly)
I uninstall it and restarted Supervisor, but I have same issue (without Watchtower mentionned in the Log this time)
The Log alert me on some other issues, but I don’t know how to fix them
See below : (as reminder I’m running Docker on a Synology NAS)
There is a way you can disable the check for healthy I believe. Check out the ha su options help via ssh…
Do you have any detailed procedure how to do this ?
