Yep, it stopped working for me as well. I replied to the blog entry about 0.65 with the error.
I’ll post the error here again to save having to go to that topic.
2018-03-11 00:32:21 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform sabnzbd
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py", line 82, in async_setup
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/lib/python3.5/asyncio/tasks.py", line 400, in wait_for
return fut.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/asyncio/tasks.py", line 239, in _step
result = coro.send(None)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/sensor/sabnzbd.py", line 152, in async_setup_platform
if not (yield from async_check_sabnzbd(SabnzbdApi, base_url, api_key)):
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/sensor/sabnzbd.py", line 62, in async_check_sabnzbd
yield from sab_api.check_available()
File "/srv/homeassistant/lib/python3.5/site-packages/pysabnzbd/__init__.py", line 43, in check_available
with aiohttp.ClientSession() as session:
File "/srv/homeassistant/lib/python3.5/site-packages/aiohttp/client.py", line 742, in __enter__
raise TypeError("Use async with instead")
TypeError: Use async with instead
