Cool to have added Kodi discovery. I had to read the full blog article to understand why some of my Kodi instances are suddenly showing up. One isn’t, I will have to investigate.
After performing this upgrade I am no longer able to save edits to Automations or Scripts with in Home Assistant I have to edit them in a separate note pad editor.
Here is the issue: https://github.com/home-assistant/home-assistant-polymer/issues/1131#issuecomment-385223893
Homekit does not work on Hassio( HA ) just gives an error, guess its missing some components.
After upgrading from 0.67 to 0.68, my system is completely offline. Can’t even ping. Using a 32GB SD card that was less than 3 months old with <7% use, 2.5A power supply. Been running sweet until the attempted upgrade through the GUI. Any idea on how I even start to debug that?
Going to pull the card out to see if my backups are accessible as the first step.
same getting error when i save automation version 068.
Mon Apr 30 2018 17:19:43 GMT+1200 (New Zealand Standard Time)
Error handling request
File "/usr/lib/python3.6/site-packages/aiohttp/web_protocol.py", line 381, in start
resp = await self._request_handler(request)
File "/usr/lib/python3.6/site-packages/aiohttp/web_app.py", line 322, in _handle
resp = await handler(request)
File "/usr/lib/python3.6/site-packages/aiohttp/web_middlewares.py", line 88, in impl
return await handler(request)
File "/usr/lib/python3.6/site-packages/homeassistant/components/http/static.py", line 68, in staticresource_middleware
File "/usr/lib/python3.6/site-packages/homeassistant/components/http/real_ip.py", line 27, in real_ip_middleware
File "/usr/lib/python3.6/site-packages/homeassistant/components/http/ban.py", line 68, in ban_middleware
File "/usr/lib/python3.6/site-packages/homeassistant/components/http/auth.py", line 28, in auth_middleware
File "/usr/lib/python3.6/site-packages/homeassistant/components/http/view.py", line 104, in handle
result = await result
File "/usr/lib/python3.6/site-packages/homeassistant/components/config/__init__.py", line 121, in post
self._write_value(hass, current, config_key, data)
File "/usr/lib/python3.6/site-packages/homeassistant/components/config/automation.py", line 32, in _write_value
if cur_value[CONF_ID] == config_key:
KeyError: 'id'
Great release. Thought the issue was with Broadlink, but was actually caused by my automations not being enabled after upgrade. Keep an eye on that!
Looks like this caused when you copy pasted automations into the automations.yaml
file and did not add an ID (as per instructions ). I’ll include a fix in 0.68.1 to correct this.
What is the ETA we can expect?
Thanks for that
After upgrading to 0.68 my ASUS dsl-ac68u isn’t detecting anymore and presence detection fails.
I didn’t notice any changes to asus components in the change log?
The asus component has been rock solid up until now?
Somehow HA borked on me eating up the config. Now doing a reinstall using 0.68.1 - Add-On Store missing after fresh install. So I am stuck as I can’t enable SMB …
@xbmcnut samething here. My HASSIO was running fine on RP3 and new SD card for last 6 months until I upgrade to 0.68 and now my system is completely offline. I was hoping to debug with the console but everything seem to be lock and just having the HA logo with no login doesn’t help.
HASSIO is very nice and I still recommend for starting but I found it too dangerous for me to lose your whole home system without any way to debug it. On the SD is only the resin boot os. Unfortunately this is enough for me to not go back to HASSIO until they provide a safe login on the console for those situation.
As I’m about to be more serious on my home automation, this will be a good time to move on HA on VM and setup redundancy and DR plan if this occur again. I believe VM are more easy to backup and restart.
Also I realized that the HASSIO Supervior had no approval process to update his version and saw it update automatically his new version this last few days. May it be this new version that cause the problem? We won’t be able to tell as I can’t even log on anymore.
My suggest:
- Supervisor update should be a manual update process like the HA and OS unless user accept to automatically update it (not recommend for a production system).
- Config and Backup should be on the SD card accessible for recovery plan situation which there are not presently.
@Starwolf73. My SD card seems to have completely died during the process. Is not ‘seen’ by the bios in either Windows or Linux. Can’t say I’ve ever seen that before. My biggest peeve with this is no native way in HA to perform a backup to an offsite location. If it is super easy to insert a thumb drive and have HA save my weekly backup .tar files there, please show me how. Although I was doing automated weekly backups, that’s of no use whatsoever if you can’t access your card.
Thank you!.
0.68.1 Has resolved my Google Home integration issue. Very happy!
@xbmcnut A simple solution to backup HASSIO on Windows platform is to install Samba addon and map a drive on HASSIO backup folder with \{Hostname}\backup or \hassio\backup. After you can use any simple backup solution on Windows PC and you can automate your backup.
I finally was able to log on my RP3 via ethernet cable and for some reason the WIFI doesn’t work anymore. Will try another RP3 later but so far I did find an error in the Hardware log.
➜ ~ hassio -d ho hardware
DEBUG [CmdHost]: action->‘hardware’, endpoint=‘hardware’, serverOverride->’’, GET->‘true’, options->’’, rawjson->‘false’, filter->’’
DEBUG [ExecCommand]: basepath->‘host’, endpoint->‘hardware’, serverOverride->’’, get->‘true’, Options->’’, Filter->’’, RawJSON->‘false’
DEBUG [GenerateURI]: basepath->‘host’, endpoint->‘hardware’, serverOverride->’’
DEBUG [RestCall]: data->‘http://hassio/host/hardware’, GET->‘true’, payload->’’
DEBUG [RestCall]: ResponseBody->‘404: Not Found’
Error decoding json invalid character ‘:’ after top-level value: 404: Not Found#
Update: Test the RP3 WIFI with another OS (SD card of Octopi) and work fine. My file system-connections/resin-wifi file is also good with no error. Finally I did run the configuration check and it return valide. So there is something that recently change to affect the WIFI.
Use scp or rsync to back up to another computer on your LAN.
Upgrading to 0.68.1 has fixed hass.io connections to my asus router for presence detection.
Cheers guys
I have an Aeotec Door Sensor 6 and I am no longer able to switch parameters, mainly 121 between the binary and basic set sensors but it shows sensor.front_door1_access_control, sensor.front_door1_alarm_level, sensor.front_door1_alarm_type, sensor.front_door1_sourcenodeid in my states. However binary_sensor.front_door1_sensor stays on(Open) at all times and does not toggle off(Closed) When closed. sensor.front_door1_access_control, sensor.front_door1_alarm_level, sensor.front_door1_alarm_type, sensor.front_door1_sourcenodeid also do not change when door is open or closed. The only parameter I can change is #9
