Use scp or rsync to back up to another computer on your LAN.
Upgrading to 0.68.1 has fixed hass.io connections to my asus router for presence detection.
Cheers guys
I have an Aeotec Door Sensor 6 and I am no longer able to switch parameters, mainly 121 between the binary and basic set sensors but it shows sensor.front_door1_access_control, sensor.front_door1_alarm_level, sensor.front_door1_alarm_type, sensor.front_door1_sourcenodeid in my states. However binary_sensor.front_door1_sensor stays on(Open) at all times and does not toggle off(Closed) When closed. sensor.front_door1_access_control, sensor.front_door1_alarm_level, sensor.front_door1_alarm_type, sensor.front_door1_sourcenodeid also do not change when door is open or closed. The only parameter I can change is #9
