Yep, thermostat fixed for my Netatmo in 0.81.4 too.
What is the one of two arrows in a circle, is that not fan?
As mentioned above, in 0.81.0 I had a full functional fan button, but it was invisible.
Solved with 0.81.4 for me too.
But Iām getting some strange things when using themes different than default.
When using midnight theme
When using dark_red theme
Iāve tried also clearing browser cache, but doesnāt work.
Anyone tried with themes?
Please read the thread before postingā¦ Fixed in the latest beta. Release 0.82 will have the fix as well
HomematicIP IP is working fine now.
As in fixed in 0.81.4 or fixed in candidate for 0.82. (Iām on 0.81.4 and my previously working thermostat card does not show this is for a nest)
As in fixed in the latest beta and will be in 0.82? Beta is 0.82.0dev1
0.81.5 and I have the card
EDIT: Itās now working. Not sure why but itās trying to get a āmid_24ā key and gives an error because the broadlink climate component uses āmed_ā instead of āmid_ā. Iāve replaced all the med_ with mid_ .
Iām not sure what changed from one version to the other, but Iām using this component for months so maybe something has changed in 0.81.5
Anyway itās working now.
When I move the dial I see a:
But then I get an error:
Error doing job: Task exception was never retrieved
6:26 PM custom_components/climate/broadlink.py (ERROR)
Log Details (ERROR)
Sun Nov 04 2018 18:26:11 GMT+0000 (Hora padrĆ£o da Europa Ocidental)
File "/usr/local/lib/python3.6/configparser.py", line 789, in get
value = d[option]
File "/usr/local/lib/python3.6/collections/__init__.py", line 883, in __getitem__
return self.__missing__(key) # support subclasses that define __missing__
File "/usr/local/lib/python3.6/collections/__init__.py", line 875, in __missing__
raise KeyError(key)
KeyError: 'mid_24'
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/service.py", line 226, in _handle_service_platform_call
await func(entity, data)
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/climate/__init__.py", line 572, in async_service_temperature_set
await entity.async_set_temperature(**kwargs)
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/config/custom_components/climate/broadlink.py", line 279, in set_temperature
self.send_ir()
File "/config/custom_components/climate/broadlink.py", line 163, in send_ir
command = self._commands_ini.get(section, value)
File "/usr/local/lib/python3.6/configparser.py", line 792, in get
raise NoOptionError(option, section)
configparser.NoOptionError: No option 'mid_24' in section: 'heat'
Is this a card issue, or is something with the Broadlink Climate Component?
Is there something I can try to solve this?
thanks
how does one put the range feature in the thermostat?
If I use this code all it does is create another thermostat with another entity, which seems correct. but couldnāt find out how they did the range thing.
