So 0.85.0 completely bricks my HA instance. However, I do get a couple errors when I run the upgrade from 0.84.6:
pyowm 2.8.0 has requirement requests<2.19,>=2.18.2, but you’ll have requests 2.21.0 which is incompatible.
locationsharinglib 3.0.6 has requirement requests~=2.19.1, but you’ll have requests 2.21.0 which is incompatible.
I’m not sure how to go about fixing this. I am running on Hassbian.
According to google: A slug is a short label for something, containing only letters, numbers, underscores or hyphens. In the case of Home Assistant, no numbers.
I don’t think so. e.g. I had a sensor.samsung_a5_battery, and it’s still the same name after the update. I can also see the history, etc, of this sensor, so it works fine. I think that the automatic “creation” of entity_id’s has changed a bit. But I have to agree, it’s also not completely clear to me what is exactly changed.
Without app_key I get: Invalid config for [sensor.ambient_station]: required key not provided @ data['app_key']. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.ambient_station/
RE: Ambient, there shouldn’t be an application key per user. According to a conversation I had with their support, every HASS user should use the same application key; it’s the API key that should change.
I have a PR in place to make some architectural adjustments to this platform: https://github.com/home-assistant/home-assistant/pull/19902 – I’ll revise it to hard-code the application key I received and remove that as a required configuration option.
In my small ZHA setup issue seems to be related to having the Hampton Bay Wink fan module connected, if I remove it my 6 other ZHA lights all come back and function correctly. Opened an issue for this…
since updating to 0.85 the Service group.turn_on longer works.
019-01-10 15:12:23 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.alarm_fully_armed_turn_off_lights_ect. Service not found for call_service at pos 1: (ServiceNotFound(...), 'Service group.turn_on not found')
I do not use the “sudo hassbian-config upgrade homeassistant” method.
I had previously monkeyed around with the locationsharinglib stuff in the past to try to get the Google Maps sharing device tracker to work. I was able to get it working but I have since quit using Google Maps for device tracking.
I think (This is going off memory) that group.turn_on used to be a service and it was removed. If not, it’s always been homeassistant.turn_on. This is dating back to 2015ish. My memory might be alittle off.
