0.90.0: Streaming camera in lovelace?
You should get an actual feed with this option not a 0,1fps “feed” do you have home assistant up to date? It works on both cards I tried it
Yes, 0.100.1
Works with picture-glance - there I have a stream, also works with picture-entity.
But with picture-element I get 0.1 fps.
This is the config. Do you see anything wrong?
      - type: picture-elements
        image: /local/blank.png
        elements:
          - type: image
            camera_view: live
            camera_image: camera.outside
            style:
              top: 50%
              left: 50%
              width: 100%
I think that also depends on the type of camera you are getting your stream from.
picture-elements works for me, but I get the extra-slow framerate when I use the generic camera.
Instead, when I use the ffmpeg camera it works pretty decently (15fps). This is true for cameras from my Hikvision NVR, but I have a bunch of other cameras and they work ok with the generic camera.
welldone done, this method is way easier
