0.90: Remote UI, Streams, User Groups
I just tried that with an automation like this:
- id: startup
  alias: Startup Routine
  initial_state: 'on'
    platform: homeassistant
    event: start
    - service: cloud.remote_connect
However, when I restarted the server it gave the following in the log:
2019-03-21 13:54:08 ERROR (MainThread) [homeassistant.components.automation] Error while executing automation automation.startup_routine. Unknown error for call_service at pos 1:
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/automation/__init__.py", line 381, in action
    await script_obj.async_run(variables, context)
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/script.py", line 131, in async_run
    await self._handle_action(action, variables, context)
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/script.py", line 210, in _handle_action
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/script.py", line 299, in _async_call_service
    context=context
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/service.py", line 88, in async_call_from_config
    domain, service_name, service_data, blocking=blocking, context=context)
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/core.py", line 1138, in async_call
    self._execute_service(handler, service_call))
  File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
    future.result()
  File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
    raise self._exception
  File "/usr/lib/python3.5/asyncio/tasks.py", line 239, in _step
    result = coro.send(None)
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/core.py", line 1160, in _execute_service
    await handler.func(service_call)
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/cloud/__init__.py", line 184, in _service_handler
    await cloud.remote.connect()
  File "/srv/homeassistant/lib/python3.5/site-packages/hass_nabucasa/remote.py", line 246, in connect
    raise RemoteNotConnected()
hass_nabucasa.remote.RemoteNotConnected
Edit:
It appears to work if I add this before the service call:
- delay: '00:00:30'
So, it looks like at the time the start event is received it is not quite ready to connect to the remote endpoint.
