JTPublic
(JT)
March 21, 2019, 1:38am
188
Depending on your states value, this works for me:
- type: custom:config-template-card
variables:
- states['device_tracker.a_phone'].attributes['battery']
- states['device_tracker.a_phone'].attributes['battery_charging']
config:
type: custom:hui-entities-card
title: TESTING
entities:
- entity: binary_sensor.carport
name: "${'Battery Level' + '\xa0'.repeat(16) + vars[0]}"
name: "${'Battery Level' + '\xa0'.repeat(16) + ((vars[0] >= 100) ? 'Excellent' : (vars[0] > 80) ? 'Good' : (vars[0] > 60) ? 'Fair' : 'Weak')}"
I screwed up the state.
This works:
- type: 'custom:config-template-card'
variables:
- states['sensor.sonoff1_2914_status'].attributes['MqttCount']
- states['sensor.sonoff1_2914_status'].attributes['WiFi LinkCount']
- states['sensor.sonoff1_2914_status'].state
- states['sensor.sonoff2_3110_status'].attributes['MqttCount']
- states['sensor.sonoff2_3110_status'].attributes['WiFi LinkCount']
- states['sensor.sonoff2_3110_status'].state
- states['sensor.sonoff5_1083_status'].attributes['MqttCount']
- states['sensor.sonoff5_1083_status'].attributes['WiFi LinkCount']
- states['sensor.sonoff5_1083_status'].state
- states['sensor.sonoff6_3719_status'].attributes['MqttCount']
- states['sensor.sonoff6_3719_status'].attributes['WiFi LinkCount']
- states['sensor.sonoff6_3719_status'].state
entities:
- sensor.sonoff1_2914_status
- sensor.sonoff2_3110_status
- sensor.sonoff5_1083_status
- sensor.sonoff6_3719_status
card:
type: 'custom:hui-entities-card'
title: MQTT & Wifi Connections
show_header_toggle: false
entities:
- entity: sensor.sonoff1_2914_status
name: "${'Coffee' + '\xa0'.repeat(16) + 'MQTT ' + vars[0] + '\xa0'.repeat(4) + 'WiFi ' + vars[1] + '\xa0'.repeat(2) + ( vars[2] >= 100 ? 'Excellent' : vars[2] >= 80 ? 'Good' : vars[2] >= 60 ? 'Fair' : 'Weak')}"
- entity: sensor.sonoff2_3110_status
name: "${'Toothbrush' + '\xa0'.repeat(7) + 'MQTT ' + vars[3] + '\xa0'.repeat(4) + 'WiFi ' + vars[4] + '\xa0'.repeat(2) + ( vars[5] >= 100 ? 'Excellent' : vars[5] >= 80 ? 'Good' : vars[5] >= 60 ? 'Fair' : 'Weak')}"
- entity: sensor.sonoff5_1083_status
name: "${'Garage' + '\xa0'.repeat(15) + 'MQTT ' + vars[6] + '\xa0'.repeat(4) + 'WiFi ' + vars[7] + '\xa0'.repeat(2) + ( vars[8] >= 100 ? 'Excellent' : vars[8] >= 80 ? 'Good' : vars[8] >= 60 ? 'Fair' : 'Weak')}"
- entity: sensor.sonoff6_3719_status
name: "${'Alarm' + '\xa0'.repeat(17) + 'MQTT ' + vars[9] + '\xa0'.repeat(4) + 'WiFi ' + vars[10] + '\xa0'.repeat(2) + ( vars[11] >= 100 ? 'Excellent' : vars[11] >= 80 ? 'Good' : vars[11] >= 60 ? 'Fair' : 'Weak')}"
iantrich
(Ian)
March 21, 2019, 2:44am
190
This is so cool and so scary at the same time…
I don’t suppose I can calculate anything? like state/2-100 to convert to dBm?
iantrich
(Ian)
March 21, 2019, 2:49am
192
If you can do it in JS, you can do it in the template; yes
Hopefully someone can post an example… I don’t seem to be able to work out how.
JTPublic
(JT)
March 21, 2019, 3:53am
194
Would the calculation here help?
genius actually…
entities:
name: "${'Coffee' + '\xa0'.repeat(16) + 'MQTT ' + vars[0] + '\xa0'.repeat(4) + 'WiFi ' + vars[1] + '\xa0'.repeat(3) + ( vars[2] >= 100 ? 'Excellent' : vars[2] >= 80 ? 'Good' : vars[2] >= 60 ? 'Fair' : 'Weak' ) + '\xa0'.repeat(3) + ((parseInt(vars[2]) / 2) - 100 ) + 'dBm'}"
name: "${'Toothbrush' + '\xa0'.repeat(7) + 'MQTT ' + vars[3] + '\xa0'.repeat(4) + 'WiFi ' + vars[4] + '\xa0'.repeat(3) + ( vars[5] >= 100 ? 'Excellent' : vars[5] >= 80 ? 'Good' : vars[5] >= 60 ? 'Fair' : 'Weak' ) + '\xa0'.repeat(3) + ((parseInt(vars[5]) / 2) - 100 ) + 'dBm'}"
name: "${'Garage' + '\xa0'.repeat(15) + 'MQTT ' + vars[6] + '\xa0'.repeat(4) + 'WiFi ' + vars[7] + '\xa0'.repeat(3) + ( vars[8] >= 100 ? 'Excellent' : vars[8] >= 80 ? 'Good' : vars[8] >= 60 ? 'Fair' : 'Weak' ) + '\xa0'.repeat(3) + ((parseInt(vars[8]) / 2) - 100 ) + 'dBm'}"
name: "${'Alarm' + '\xa0'.repeat(17) + 'MQTT ' + vars[9] + '\xa0'.repeat(4) + 'WiFi ' + vars[10] + '\xa0'.repeat(3) + ( vars[11] >= 100 ? 'Excellent' : vars[11] >= 80 ? 'Good' : vars[11] >= 60 ? 'Fair' : 'Weak' ) + '\xa0'.repeat(3) + ((parseInt(vars[11]) / 2) - 100 ) + 'dBm'}"
JTPublic
(JT)
March 21, 2019, 3:02pm
196
Is it possible to template something like !secret garage_cam?
This does not work for me, I got Secret ${var[0]+’_cam’} not defined.
variables:
- ('garage')
config:
type: custom:hui-picture-elements-card
image: !secret "${vars[0]+'_cam'}"
elements: ....
iantrich
(Ian)
March 21, 2019, 4:52pm
197
templates are for the full text, not just portions.
image: "${'!secret ' + vars[0] + '_cam'}"
JTPublic
(JT)
March 21, 2019, 4:58pm
198
No go for variables: - (’!secret garage_cam’) either.
Not possible for !secret then?
I’m done screwing with this now I think… I just added some icons as well and reorganised some of the text.
variables:
entities:
card:
entities:
name: "${'Coffee' + '\xa0'.repeat(16) + 'MQTT ' + vars[0] + '\xa0'.repeat(4) + 'WiFi ' + vars[1] + '\xa0'.repeat(3) + ((parseInt(vars[2]) / 2) - 100 ) + '\xa0' + 'dBm' + '\xa0'.repeat(3) + ( vars[2] >= 100 ? 'Excellent' : vars[2] >= 80 ? 'Good' : vars[2] >= 60 ? 'Fair' : 'Weak' )}"
icon: "${vars[2] >= 100 ? 'mdi:wifi' : vars[2] >= 80 ? 'mdi:wifi-strength-3' : vars[2] >= 60 ? 'mdi:wifi-strength-2' : 'mdi:wifi-strength-1' }"
name: "${'Toothbrush' + '\xa0'.repeat(7) + 'MQTT ' + vars[3] + '\xa0'.repeat(4) + 'WiFi ' + vars[4] + '\xa0'.repeat(3) + ((parseInt(vars[5]) / 2) - 100 ) + '\xa0' + 'dBm' + '\xa0'.repeat(3) + ( vars[5] >= 100 ? 'Excellent' : vars[5] >= 80 ? 'Good' : vars[5] >= 60 ? 'Fair' : 'Weak' )}"
icon: "${vars[5] >= 100 ? 'mdi:wifi' : vars[5] >= 80 ? 'mdi:wifi-strength-3' : vars[5] >= 60 ? 'mdi:wifi-strength-2' : 'mdi:wifi-strength-1' }"
name: "${'Garage' + '\xa0'.repeat(15) + 'MQTT ' + vars[6] + '\xa0'.repeat(4) + 'WiFi ' + vars[7] + '\xa0'.repeat(3) + ((parseInt(vars[8]) / 2) - 100 ) + '\xa0' + 'dBm' + '\xa0'.repeat(3) + ( vars[8] >= 100 ? 'Excellent' : vars[8] >= 80 ? 'Good' : vars[8] >= 60 ? 'Fair' : 'Weak' )}"
icon: "${vars[8] >= 100 ? 'mdi:wifi' : vars[8] >= 80 ? 'mdi:wifi-strength-3' : vars[8] >= 60 ? 'mdi:wifi-strength-2' : 'mdi:wifi-strength-1' }"
name: "${'Alarm' + '\xa0'.repeat(17) + 'MQTT ' + vars[9] + '\xa0'.repeat(4) + 'WiFi ' + vars[10] + '\xa0'.repeat(3) + ((parseInt(vars[11]) / 2) - 100 ) + '\xa0' + 'dBm' + '\xa0'.repeat(3) + ( vars[11] >= 100 ? 'Excellent' : vars[11] >= 80 ? 'Good' : vars[11] >= 60 ? 'Fair' : 'Weak' )}"
icon: "${vars[11] >= 100 ? 'mdi:wifi' : vars[11] >= 80 ? 'mdi:wifi-strength-3' : vars[11] >= 60 ? 'mdi:wifi-strength-2' : 'mdi:wifi-strength-1' }"
This is awesome. Thanks @iantrich !
I have a custom component that has weather forecasts, and I was starting down the road trying to figure out how to configure existing custom weather cards to simply display the text forecast. Using your card, with the existing markdown card makes it very straightforward!
One question: How can I covert a datetime like:
2019-03-23T10:00:00-04:00
Into a day off the week like Saturday?
I currently have Day0 but would like the day of week.
variables:
- states['weather.home'].attributes['forecast'][0].detailed_description
entities:
weather.home
card:
type: 'custom:hui-markdown-card'
title: Weather Forecast
content: "${'**Day0** <br/>' + vars[0]}"
iantrich
(Ian)
March 23, 2019, 3:17pm
201
new Date(dateString).getDay()
I believe should work.
Holy cow! We can define reusable functions too!
I cant figure out if the template can be split onto multiple lines, is this possible?
variables:
- states['weather.home'].attributes['forecast'][0].datetime
- states['weather.home'].attributes['forecast'][2].datetime
- states['weather.home'].attributes['forecast'][2].detailed_description
entities:
weather.home
card:
content: "${function weekday(datetime){var options={ weekday: 'long'}; return new Date(datetime).toLocaleDateString('en-US', options);} '**' + weekday(vars[0]) + '**<br/>' + vars[1] + '<br/>**' + weekday(vars[2]) + '** <br/>' + vars[3]}"
iantrich
(Ian)
March 23, 2019, 5:11pm
203
i have tried >, >-, |, and |- with no luck
Example:
content: >-
"${function weekday(datetime){var options={ weekday: 'long'}; return new Date(datetime).toLocaleDateString('en-US', options);} '**' + weekday(vars[0]) + '** <br/>' + vars[1] + '<br/>**' + weekday(vars[2]) + '** <br/>' + vars[3]}"
Nevermind, the whitespace is super-super sensitive here. I had to get rid of a lot of internal and trailing whitespace. |- ended up working
Thanks for the help, here is what I’ve landed on for now.
variables:
entities:
weather.home
card:
content: |-
"${function forecast(item){var options={ weekday:'long'};
var day = '**' + new Date(item.datetime).toLocaleDateString('en-US', options) + '**';
if(!item.daytime){var day = day + ' **Night**';}
return day + '<br/>' + item.detailed_description;}
var text='';
for(var i=0; i<5; i++){var text=text+forecast(vars[0][i]) + '<br/>';}
text}"
JTPublic
(JT)
March 24, 2019, 1:02am
206
Does the same function still work if, let say, you have a second markdown card without declaring it again?
Doesn’t seem to work for me, but I am a javascript novice.
