Wonder if your states[āsensor.bom_hobart_wind_gust_ktā].state is returning numbers. My coloring-changing temperature template uses parseInt() or parseFloat() for numeric conditions, maybe try
parseInt(vars[0]) <= 10
Solution (thanks to Thomas Loven):
- type: 'custom:config-template-card'
entities: sensor.bom_hobart_wind_gust_kt
variables:
- states['sensor.bom_hobart_wind_gust_kt'].state
card:
type: 'custom:hui-picture-entity-card'
entity: sensor.bom_hobart_wind_direction
show_name: false
show_state: false
state_image:
CALM: /local/icons/wind/CALM.png
E: "${'/local/icons/wind/' + ( vars[0] <= 10 ? 'E-blu.png' : vars[0] <= 20 ? 'E-grn.png' : vars[0] <= 30 ? 'E-yel.png' : 'E-red.png' ) }"
ENE: "${'/local/icons/wind/' + ( vars[0] <= 10 ? 'ENE-blu.png' : vars[0] <= 20 ? 'ENE-grn.png' : vars[0] <= 30 ? 'ENE-yel.png' : 'ENE-red.png' ) }"
ESE: "${'/local/icons/wind/' + ( vars[0] <= 10 ? 'ESE-blu.png' : vars[0] <= 20 ? 'ESE-grn.png' : vars[0] <= 30 ? 'ESE-yel.png' : 'ESE-red.png' ) }"
'N': "${'/local/icons/wind/' + ( vars[0] <= 10 ? 'N-blu.png' : vars[0] <= 20 ? 'N-grn.png' : vars[0] <= 30 ? 'N-yel.png' : 'N-red.png' ) }"
NE: "${'/local/icons/wind/' + ( vars[0] <= 10 ? 'NE-blu.png' : vars[0] <= 20 ? 'NE-grn.png' : vars[0] <= 30 ? 'NE-yel.png' : 'NE-red.png' ) }"
NNE: "${'/local/icons/wind/' + ( vars[0] <= 10 ? 'NNE-blu.png' : vars[0] <= 20 ? 'NNE-grn.png' : vars[0] <= 30 ? 'NNE-yel.png' : 'NNE-red.png' ) }"
NNW: "${'/local/icons/wind/' + ( vars[0] <= 10 ? 'NNW-blu.png' : vars[0] <= 20 ? 'NNW-grn.png' : vars[0] <= 30 ? 'NNW-yel.png' : 'NNW-red.png' ) }"
NW: "${'/local/icons/wind/' + ( vars[0] <= 10 ? 'NW-blu.png' : vars[0] <= 20 ? 'NW-grn.png' : vars[0] <= 30 ? 'NW-yel.png' : 'NW-red.png' ) }"
S: "${'/local/icons/wind/' + ( vars[0] <= 10 ? 'S-blu.png' : vars[0] <= 20 ? 'S-grn.png' : vars[0] <= 30 ? 'S-yel.png' : 'S-red.png' ) }"
SE: "${'/local/icons/wind/' + ( vars[0] <= 10 ? 'SE-blu.png' : vars[0] <= 20 ? 'SE-grn.png' : vars[0] <= 30 ? 'SE-yel.png' : 'SE-red.png' ) }"
SSE: "${'/local/icons/wind/' + ( vars[0] <= 10 ? 'SSE-blu.png' : vars[0] <= 20 ? 'SSE-grn.png' : vars[0] <= 30 ? 'SSE-yel.png' : 'SSE-red.png' ) }"
SSW: "${'/local/icons/wind/' + ( vars[0] <= 10 ? 'SSW-blu.png' : vars[0] <= 20 ? 'SSW-grn.png' : vars[0] <= 30 ? 'SSW-yel.png' : 'SSW-red.png' ) }"
SW: "${'/local/icons/wind/' + ( vars[0] <= 10 ? 'SW-blu.png' : vars[0] <= 20 ? 'SW-grn.png' : vars[0] <= 30 ? 'SW-yel.png' : 'SW-red.png' ) }"
W: "${'/local/icons/wind/' + ( vars[0] <= 10 ? 'W-blu.png' : vars[0] <= 20 ? 'W-grn.png' : vars[0] <= 30 ? 'W-yel.png' : 'W-red.png' ) }"
WNW: "${'/local/icons/wind/' + ( vars[0] <= 10 ? 'WNW-blu.png' : vars[0] <= 20 ? 'WNW-grn.png' : vars[0] <= 30 ? 'WNW-yel.png' : 'WNw-red.png' ) }"
WSW: "${'/local/icons/wind/' + ( vars[0] <= 10 ? 'WSW-blu.png ': vars[0] <= 20 ? 'WSW-grn.png' : vars[0] <= 30 ? 'WSW-yel.png' : 'WSw-red.png' ) }"
You canāt chain m < x < n comparisons like I did.
Grab the file from the release or use HACS
Hey Ian, This appears to be stopping firefox from responding (Chrome seems to ignore it):
Not sure if itās my config (which seems to be working) or the card.
I opened an issue.
Davidās āminutes agoā conversion is a good start, but has anyone come up with a good way of converting attr last_changed to relative time?
Hi @iantrich, itās a great component you created! I used it already once and it works great. I want to use it again to display a card to control the fan speed, which is an attribute of a fan.
What is the syntax to follow to access the attribute please? This does not work obviously as I want to control the value, not just know the current state.
Thereās an example in the docs
Hi @iantrich, I am sorry, but I have double read the docs and I canāt find the answer. Are you talking about the doc under this link? https://github.com/iantrich/config-template-card
name: "${states['climate.ecobee'].attributes.current_temperature > 22 ? 'Cozy' : 'Too Hot/Cold'}"
This is not Jinja. Checkout templater-card if you want to use jinja
What do you mean by This is not Jinja?
The example you gave is to check the value of an attribute but not to control it, isnāt it?
Service calls are used to control entities. You donāt need this card to do that, you just need to figure out the correct service call for your fan.
Ok thank you.
I have a few questions regarding this card:
I have read on your repo (at the issues) that the card polls constantly if nothing is filled. Is this still the case? I use input text a lot with your card, but I wonder if that counts as āhaving something filled inā or if it will keep polling regardless.
If I wrap your card around an auto-entities card that has a button-card in it, the states of the button no longer updates unless I refresh, is there something I can do about it?
The same is true for example dbuits popup card, it will take the config nicely, but the popup is unresponsive when this card is wrapped around it
Thanks for this amazing card btw!
entities
option? Then yes and always will be. It needs to know what entities to watch so it is not updating on every state change in the HA.I think I figured out question 2. The reason I ask is because I get tons of āmax pending messagesā errors and I saw somewhere this card had a relation with it. I need to debug when I have a pc around.
Though I do have another question. What is the difference between entities and variables? To me it looks the same, either it monitors the entity or it monitors the state. Not exactly sure how that works. Been reading through your documentation over and over but to me it seems both methods results are the same. I know I am terribly wrong here that is why I ask.
Thanks for replying
variables are just handy additions to make it easier to create templates. entities is a list of entities that, when their state changes, cause the card to update.
a lot of āmax pending messagesā sounds like youāre using a jinja2 template somewhere that is being re-evaluated far too often
Hello @iantrich,
Iām trying to get a png overlay opacity dynamically changing while the outside brightness changes (in a picture-elements
card). I ended up with this:
cards:
- type: "custom:config-template-card"
entities:
- sensor.brightness_opacity
# variables:
# - states['sensor.brightness_opacity'].state
card:
- type: "custom:hui-picture-elements-card"
image: /local/plan/0_n_no.png?v=2
elements:
- entity: sun.sun
hold_action:
action: none
state_image:
above_horizon: /local/plan/0_g_no.png?v=2
below_horizon: /local/plan/alphamini.png
style:
height: 100%
left: 50%
mix-blend-mode: lighten
opacity: >-
${ states['sensor.brightness_opacity'].state }
top: 50%
width: 100%
tap_action:
action: none
type: image
- entity: media_player.samsungtv_tizen
I checked it and read all the paper a lot of times but I canāt figure out why I get
No card type defined
error in Lovelace.
Funny thing is if I comment out the config-template-card
bit of code all works, all but the dynamic opacity indeed.
Please help me figure this out.
Thank you,
R.
I presume because itās
so you donāt need a list here
you need just one card. remove the dash
