šŸ“ 100% Templatable Lovelace Configurations
Thanks, that actually was it!
With Font Awesome icons it is working!!!
Any thoughts as to why the secondary_info is not working here? The icon is working fine, but I donā€™t see the secondary_info.
      - type: 'custom:config-template-card'
        config:
          type: 'custom:hui-entities-card'
          title: Investments
          show_header_toggle: false
          entities:
            - type: custom:card-modder
              style:
                --paper-item-icon-color: "${var state = parseFloat(states['sensor.portfoliochange2'].state);
                  state <= 0 ? 'rgb(194, 39, 45)' : 'rgb(37, 145, 60)'}"
              card:
                type: custom:hui-sensor-entity-row
                entity: sensor.pc_investment
                secondary_info: "${states['sensor.portfoliochange2'].state}"
                icon: "${parseFloat(states['sensor.portfoliochange2'].state) > 0 ? 'mdi:arrow-up-bold-circle' : 'mdi:arrow-down-bold-circle' }"
If you are using the built-in ā€œhuiā€ entity rows, secondary-info can only be in (entity_id, last_changed). You can override with custom values if you switch the type to this:
That was actually the icon not being part of HA!
But I found something new, it does look like it is in conflict with HA border/shadow functionality maybe?
This is with the templatable config card:
This is without:
Check the bottom right corner on each ā€œtemperature boxā€
secondary_info is restricted to entity-id , last-changed
EDIT: I see @MizterB beat me to the answer :slight_smile: And even has a better solution! Thanks!
Iā€™m not seeing the differences. Can you perhaps highlight what youā€™re referencing?
Edit: I THINK I see it nowā€¦I really need a better monitor :wink: Post on the repo with your full configuration of both, please, and confirm the differences. Thanks.
Sorry to disappeoint but no, I tried A LOT using the custom-secondaryinfo but it doesnā€™t seems to work!
I will post an example soon
Will do in few mins :slight_smile:
Edit: Done :slight_smile:
Okay actually I was wrong, I managed to make it work :smiley:
But I need some help please ^^
secondary_info: "${'OnePlus 5 Battery: ' + states['sensor.andrea_oneplus5_battery'].state + '% -' + states['binary_sensor.andrea_oneplus5_charging'].state === 'true' ? 'Charging' : 'Not Charging'}"
It always return ā€œNot chargingā€
Thanks :slight_smile:
New entities option fixed the hold_action for me, thanks.
That makes sense I think if you have a busy system. The template card is re-instatiating the card each time there is a state change if not restricted by the entities option. So the card could have been ā€œgoneā€ while you held it.
Well that question opens up a whole can of worms.
I donā€™t even know what a hui-sensor-entity-row is except by experimentation and by inferring from the contents of this post.
I can find no reference to anything hui anywhere and I did ask the question recently and was told,
in order to
So to me they are some undocumented ā€˜magicā€™.
Which all means that I have no idea why this config-template-card needs to use them or what syntax and options are available to use them natively.
So, cutting to the chase, to answer your question, I donā€™t know. But I have tried the following with the results shown. (Interestingly neither appears as a ā€˜cardā€™ unless of course they default to a transparent background).
  - type: custom:hui-sensor-entity-row
    entity: sensor.bakerloo
    secondary_info: last-changed
    style:
      --primary-text-color: yellow
A binary sensor has a state on or off. Your code has true which it will never have so thatā€™s why itā€™s always showing ā€œNot chargingā€.
ALL core cards/row/elements have a prefix/suffix that follows this convention:
hui-<card/row/element name>-<type card/row/element>
e.g.
hui-shopping-list-card
You can look in the create files here: https://github.com/home-assistant/home-assistant-polymer/tree/dev/src/panels/lovelace/common
Thatā€™s a good point, thanks! :smiley:
But, why the first part of the text is not beinbg show?
My plan was to have an output like:
OnePlus 5: 85% - Charging/Not Charging
But it is showing only the final part, beside the wrong binary_sensor value
EDIT: Tested with ā€˜onā€™, it still only say ā€œNot Chargingā€
Had some fun, used this card to do a temperature-based color weather icon with pop-up forecast and weather map (browser-commander), thanks again for this great card!!
  - type: state-icon
    entity: sensor.dark_sky_minutely_summary
    tap_action:
      action: none
      service: python_script.browser_cmd
      service_data:
        cmd: 'popup'
        data: 'weather'
    hold_action:
      action: call-service
      service_data:
        cmd: 'popup'
        data: 'weathermap'
    style:
      top: 50%
      left: 50%
      height: auto
      width: 2.6vw
      background-color: "${var colors=['#442299','#3b0cbd','#3311bb','#4444dd','#e6ffff','#ccffff','#ffffff','#11aabb','#12bdb9',
                                       '#22ccaa','#69d025','#aacc22','#d0c310','#ccbb33','#feae2d','#ff9933','#ff6644','#ff4422',
                                       '#ff3311','#ee1100','#f80c12'];
                                     var temp=parseInt((parseInt(states['sensor.dark_sky_temperature'].state)-10)/(70/20));
                                     if (20>=temp>=0) colors[temp];else if (temp<0) colors[0];else colors[20]}"
      border-radius: 100%
:tada: Introducing Variables :tada:
1.0.4 Released
You can now use the new variables configuration to create a list of reusable variables to hopefully help clean up your templates. See the updated docs on the repo for an example.
Have fun templating!
Further to my previous answer it doesnā€™t look like I can. I had guessed I would be able to, following the example given above by @arsaboo where he,
and changes the colour behind an icon:
If the answer is not too complex for this post, why can paper-item-icon-color be defined but not primary-text-color and is there any way to discover that information?
Should I change config to card? Seems like it would be more consistent with other cards.
  • Keep config
  • Breaking change to use card
0 voters
2 quick questions on the new variables option:
  • whatā€™s the scope of these declared variables? I have picture-elements card under config, will all cards inside that picture-elements ā€˜seeā€™ the variables?
    [Edit: Tested, all cards under config ā€˜seeā€™ the variables]
  • Is it possible to declare constants in variables option? Like:
    variables:
      - states['light.bed_light'].state
      - ('red')
    [Edit: Works, vars[1] will show 'red', thanks to Ian!! ]
TIA
