Yes, missed it completely. Will check it out. Thank you!
Exactly how does it look like that??
You really need to work on your reading.
What does that upper pict say?
It says you can power it from DC, but nowhere does it say it can switch DC loads, and I wouldn’t want to assume. I also see no provisions for an external switch, just the app or integration. Did I miss something there?
The image clearly says DC inputs to the relays doesn’t it?
Both the left bulb and the motor is DC.
The product page also says it has dry contacts.
The buttons labeled R1, R2, R3 and R4.
On the opposite side there is four LEDs.
I assume the buttons switch the relays and the LEDs is indication, but I don’t know since I don’t have on.
But you can probably google or look at some video about it.
