The supervisor does auto-update.
Yes, but it is not as an option.
I think the idea of making supervisor updates optional has been rasied and dismissed previously, at length. I donât think it will happen!
Does anybody know when the next release will happen? I am still on 2020.12.2 hoping that this fix is applied to 2021.1.5: https://github.com/home-assistant/core/pull/45245
some of my sensors are sending data through MQTT and I am capturing the data in node red and assigning it to an input_number and then using a filter to get the data filtered
Thatâs a very long winded way to go about filtering data.
Capture the data using a home assistant mqtt sensor and apply the filter to that.
Thank you, I will investigate that option but at the moment I have many sensors setup in this way and some of them with complex rules so I guess it will take me a while to move them all to sensors and I don´t want to wait as it seems there is some security issues with the HA Core previous to 2021.1.3.
Coming back to my previous question, does anybody know when 2021.1.5 will be released?
No guarantees if it does get released. Itâs not tagged for a milestone and kinda to be dependent on another commit. I wouldnât count on it personally.
Thank you very much for the info, time to start working on my sensors then
I cannot update from 2021.1.1.0 to 2021.1.1.4.
Any suggestions?
Bug in 2021.1.4. Configuration=>Entities and then click to select all entities, and non of them get checks in their boxes yet notice says they are selected. Also, randomly some show selected when not selected.
You should be on 2021.1.5 now, see the 2nd security disclosure.
After update to 2021.1.5 I cannot see the Automations menu option in Configuration anymore, I see the message âHome Assistant is starting, not everything will be available until it is finishedâ for eternity and âCheck configurationâ option does not finish anymore. Everything was working on 2021.1.3.
Anyone has reproduce this behaviour?
Edit: I have a wonderful surprise on my logâŚ:
2021-01-24 08:31:37 ERROR (MainThread) [homeassistant.setup] Setup of automation is taking longer than 300 seconds. Startup will proceed without waiting any longer
After update to 2021.1.5 there are some bugs in lovelace ui:
When I try to edit dashboard and push the button âEdit Dashboardâ, I I cannot see the button âRaw configuration editorâ, instead of this I see the button âEdit Dashboardâ again. Also I cannot see the button to close edit mode.
Not seeing that issue myself. Have you tried clearing your browser cache?
Hi all, anyone else having issues with the latest core-2021.1.5 version?
It looks like Tasmota auto-discover and âIncomfortâ integration are both brokenâŚ
That is not a bug in Lovelace, but an issue with Custom Header. You can verify by viewing your Home Assistant with ?disable_ch
at the very end of your URL.
The author of Custom Header stopped development several months ago, so it wonât be getting any bug fixes and will continue to break more things like this in the future.
This bug is still there in 2021.1.5 as well. Can anyone else try to replicate for me to ensure it is not just my setup? Select âConfigurationâ from left panel, then select âEntitiesâ and then put a check mark in the top box in left column to select all entities. None of the entities show as selected (their boxes do not fill) but the text above the top box says all entities have been selected.
You are right, Custom Header was the cause of this issue. Thank you
Yes - Same here.
Is it because some of my entities are read only? I cannot select a read only entity.
It is possible to select individual entities as long as they are not read only
I was ready to update to 2021.1.5 for the security fix, and ran the Check Home Assistant Config first as I always do. This time the feedback was the error:
[10:04:27] INFO: Installed Home Assistant 2021.1.5
[10:04:27] INFO: Making a copy of your configuration for checking...
[10:05:05] INFO: Checking your configuration against this version...
[10:08:44] ERROR: The configuration check did not pass!
[10:08:44] ERROR: See the output below for more details.
Testing configuration at /tmp/config
Fatal error while loading config: (idna 3.1 (/usr/local/lib/python3.8/site-packages), Requirement.parse('idna<3,>=2.5'), {'requests'})
Failed config
General Errors:
- (idna 3.1 (/usr/local/lib/python3.8/site-packages), Requirement.parse('idna<3,>=2.5'), {'requests'})
Successful config (partial)
[10:08:44] INFO: The full output has been written to /share/check_config.txt
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
The error is for idna
, but from the message it appears that I need to have an instance >= 2.5, and the message says I have 3.1 (I could be totally reading this wrongâŚ). I donât know what idna is, outside of what I can find on Google (not a lot that seems relevant).
Question - is it safe to continue with the installation? I donât really want to go backwards with idna, and I donât use any of the affected CCs.
EDIT: I should have added Iâm running Core 2021.1.4 and supervisor 2021.01.7
