My media player and vacuum cards are working fine
Have you tried clearing cache
chrome/edge
F12, right click on refresh button
select empty cache and hard reset
chrome/edge
Great release! I got one problem with the Foscam integration: itās not working anymore.
Yes I have, in both Safari and Edge. Same issue. Both cards lack at least some controls. For example when used with a TV entity, it now lacks the power button and it cannot be reinstated in any way. Vacuum Card lacks the controls buttons row.
Iām talking about Mini Media Player Card, not the default Media Card.
I still have the tuya thermostat issueā¦
Iām using SmartLife app, not sure if this is relevantā¦
I understood @frenck is the one dev who worked on tuya fixes the most. Iām sorry to bother you man, Iām just wondering if itās me having some weird config or making any mistake or some bugs are still thereā¦
Enable beta releases in HACS for the mini-media player card.
The beta release fixes the missing icons. Itās stable.
Thanks so much for such a robust release. Also, your commitment to address the Tuya integration so quickly is very appreciated. I had lost all my dimmers so thrilled to see them return now!
Yes it is! Thank you so much!
Does the updated Tuya V2 provide power consumption support?
I got a similar one from PostgreSQL:
Error executing query: (psycopg2.errors.UndefinedColumn) column statistics_meta.name does not exist LINE 1: ...atistics_meta.has_sum AS statistics_meta_has_sum, statistics... ^ [SQL: SELECT statistics_meta.id AS statistics_meta_id, statistics_meta.statistic_id AS statistics_meta_statistic_id, statistics_meta.source AS statistics_meta_source, statistics_meta.unit_of_measurement AS statistics_meta_unit_of_measurement, statistics_meta.has_mean AS statistics_meta_has_mean, statistics_meta.has_sum AS statistics_meta_has_sum, statistics_meta.name AS statistics_meta_name FROM statistics_meta WHERE statistics_meta.has_sum = true] (Background on this error at: https://sqlalche.me/e/14/f405)
Error executing query: (psycopg2.errors.InFailedSqlTransaction) current transaction is aborted, commands ignored until end of transaction block [SQL: SELECT statistics_meta.id AS statistics_meta_id, statistics_meta.statistic_id AS statistics_meta_statistic_id, statistics_meta.source AS statistics_meta_source, statistics_meta.unit_of_measurement AS statistics_meta_unit_of_measurement, statistics_meta.has_mean AS statistics_meta_has_mean, statistics_meta.has_sum AS statistics_meta_has_sum, statistics_meta.name AS statistics_meta_name FROM statistics_meta WHERE statistics_meta.has_sum = true] (Background on this error at: https://sqlalche.me/e/14/2j85)
I even tried manually creating the column, but then it failed when it tried to apply the migration. My database is at schema version 20, verified by both the schema_changes
table and looking at what is in migrations 20 and 22 and confirming 20 is applied and 22 is not (21 was mysql only).
It seems so! I see new sensors for current and voltage where there werenāt any on my plug.
The battery sensors on my Zigbee door sensors (some SmartThings and some Visonic) are all reporting āunavailableā with this release. My water sensors still report their battery. I tried to reconfigure and then re-add one of the sensors with no luck. I restored 2021.10.7 and the battery sensors are back.
Iām using a Pi 4 with a HUSBZB-1.
Update went well, except for breaking my Xiaomi Vacuum.
Unsupported device found! Please create an issue at https://github.com/syssi/xiaomi_airpurifier/issues and provide the following data: roborock.vacuum
Last month was a Tuya disaster, was hoping this monthās release would solve those problems.
Unfortunately, now my covers appear like this:
āCurtain switch (unsupported)
by Tuyaā
Any solution?
What model?
There were S4, S5 and S5 Max users in the beta that had no issues.
Roborock.
Iām trying to test this PR but Iām useless using vi
and canāt get the additional lines to save
EDIT: Can confirm this PR fixes the issue.
I feel for you. Vi really sucks hard when you arenāt used to it. Would be so much easier if they included nano in the container.
Ended up finding some of my old instructions to copy the files off the machine using WinSCP.
# Copy to your machine #
sudo docker cp homeassistant:usr/src/homeassistant/homeassistant/components/xiaomi_miio/const.py /home
# Copy back to HA #
sudo docker cp /home/const.py homeassistant:/usr/src/homeassistant/homeassistant/components/xiaomi_miio/const.py
And yes, nano in the HA container would make life so much easier.
I printed out some Vi instructions a while back and itās possible to edit the file directly but just not easy unless you are familiar with Vi. I know some people swear by it I just swear AT it.
Apologies if this has been discussed already, but is non cloud-dependant Tuya support still on the table for the built in integration? I seem to remember it being mentioned as a possibility for the new versionā¦
I only have one Tuya device and it runs great via LocalTuya, though obtaining the key was a messy process and I believe itās only gotten harder since I did it. Though in this matter, weāre really just at the mercy of Tuya, and if they donāt want to support local control, thereās nothing we can really do besides buy other products (which is a shame considering the massive range Tuya do have)
