The whole section is, not sure how else to explain it to you. I’ts not 1 input boolean that’s causing the problem. Anyways, it’s a wrning, you can ignore it.
just experienced the new trigger based templates can not be configured in a package, hasn’t anyone else here noticed this? I can only validate the config when these are in the configuration.yaml.
Hey! For people who have problems with Xiaomi Air Purifiers after this upgrade, I have noticed two things:
After importing into the UI on upgrade, fans had a different name, with suffix _2. I needed to rename (or remove) old ones and change names to original ones.
It seems there is a problem with the AQI attribute (it’s null), so any automation that uses it will not work properly.
Well, I must ask you where you read that, because I don’t see any mentioning the trigger based template sensors can not be configured in a package. Frankly, it would be very surprising if it were the case, because anything else can be…
forgot to mention I filed an issue in this in the Core repo
O I see, yes, I missed that. Sorry.
Given the wording, I hope we can expect that to change in the near future. Otherwise we will have to overload our configuration.yaml in a heavy way…
Using packages has become such a default way of configuring HA, this really felt like a bug. Guess I didn’t realize special care needs to be taken to be able to configure things in packages.
IMHO would be nice to add checkbox “Hide HA devices” (f.e.) to Devices list.
As for me - devices by integration “HA Supervisor” is a good addition, but see no value having them in list every time. Most of the time I have no use for them…
now this is an advanced one, and seeing this as of late (though not 100% positive it is since 2021.4…)
Logger: homeassistant
Source: /usr/src/homeassistant/homeassistant/runner.py:95
First occurred: 10:09:04 AM (1 occurrences)
Last logged: 10:09:04 AM
Error doing job: protocol.resume_writing() failed
File "/usr/local/lib/python3.8/asyncio/transports.py", line 294, in _maybe_resume_protocol
self._protocol.resume_writing()
File "/usr/local/lib/python3.8/asyncio/sslproto.py", line 517, in resume_writing
self._app_protocol.resume_writing()
File "/usr/local/lib/python3.8/site-packages/aiohttp/base_protocol.py", line 31, in resume_writing
assert self._paused
AssertionError
there is nothing really I can relate to this, nor in the logs close to it.
I cant correlate the blank phase in the chart to a restart I did, or anything else really, the rest of my sensors show fine. Including the sensor this template is based on:
I’ve added all of these sensors to the recorder. Why would this gap exist, and how come the state is ‘Unknown’? This same behavior is shown on all of these trigger based template sensors.
update
no, its positive, these sensors dont survive a restart. which currently makes them useless for my goal here, recording daily power consumption/usage in a sensor.
Got the following error when updating to 2021.4.4:
ERROR: THESE PACKAGES DO NOT MATCH THE HASHES FROM THE REQUIREMENTS FILE. If you have updated the package versions, please update the hashes. Otherwise, examine the package contents carefully; someone may have tampered with them.
home-assistant-frontend==20210407.3 from https://files.pythonhosted.org/packages/1e/29/13a7ee41fdc63f2ad07fc0c7c664ffd8c8e4319764d33d95bf7727bc25b9/home-assistant-frontend-20210407.3.tar.gz#sha256=b9c7b04b5f7791bbe593843ee481184fab1f27f1f4d3abb2d22222f141ceccfa (from -c /srv/homeassistant/lib/python3.8/site-packages/homeassistant/package_constraints.txt (line 19)):
Expected sha256 b9c7b04b5f7791bbe593843ee481184fab1f27f1f4d3abb2d22222f141ceccfa
Got ca3ef965059f3874a208848f38a48191ad113550966f8871e5a74bc0b6f6e2fa
No I don’t want the startup trigger, I need them to record the value at midnight, and only then.
That’s why I had a whole setup with intermediary input_numbers to record those values, and create the template sensors based on these numbers (via a python script)
My hope was that these new trigger based template sensors would only update on the trigger, but would keep their value crossing restarts.
