2021.8.0: Feel the energy ⚡️
Thanks for posting! To be sure: this is with core Z-waveJs add-on and integration ?
Are all 30 tones available ? Have you just disabled them ?
After a factory reset a renewed include now shows me more than before, but not all sounds yet;
And a few hidden by default:
Ditto, saw this on first update to 2021.8.6 but another restart of HA fixed it.
Today i open the app an there is a firmware update
let’s see if that helps
did you find a solution. I installed the 2021.8 version 7 hours ago and still no cost showing. (0€ everywhere)
Just the 8 as displayed, there are no disabled tones I can find.
What’s the domain, light?
Have you added the {device}_cost to the Recorder?
Z-Wave JS Integration and Z-Wave JS to MQTT add-on.
what always helps, is plugging it correctly… :roll_eyes:
yeelight:
the last version 2021.6.6 work. “support features: 47” vs 44 is the only diff i can see
Yes, that change is expected. That’s just under the hood values that represent supported features. Those specific features have been removed and replaced with something different.
Are there errors in your logs?
Just learned in #devs_zwave on Discord those are endpoints, not the sounds… check the state of any of those endpoints and you’ll see all sounds listed in the attributes.
No errors, since it work fine in HA, What ever features is changed after 2021.6.6 when it pass over to Alexa, it lost the dimming feature, it become a non dimmable light just On and Off. (I connect the HA instant to alexa for voice control). Been working fine for years.
Yes the sensor daily_energy is in the recorder.yaml,
my problem is below
fwiw, I’ve been running 1.0.21 for a few weeks - issue persists in my environment. Disable polling in the Kasa add-on as the temp workaround if needed.
Like to ask if there are plans in near future to adapt the Kostal Plenticore integration to work with the new Home Energy Management function? I tried it, but no kostal related entity is available in the Home Energy Management config.
Why is the gauge description in Italian?
Screenshot 2021-08-12 at 03-25-55 Energy - Home Assistant
Nothing else in my config is.
I’ve just looked at Developer Tools-States and I can see all the tones.
I can call any one of then under Developer Tools-Services
