2022.12: Scrape and scan interval
I cannot speak for others, but I am not against moving from YAML to UI. I dislike having to do things in two places and adding more work and complexity to get to the same end.
The ship has sailed. Move on.
Said many others affiliated with other open-source projects that were ultimately forked and withered. Ignore the people that use the product. Brilliant move, if not so arrogant.
Im a moderator, im a glorified babysitter for adults, I don’t make the decisions. Im relaying them to you. So when you single out my posts acting like I made them, you’re gonna get snarky responses.
I’ve suggested your automation (the last one) a few times, especially with the recent changes to the ping sensor. I upgraded my own server only yesterday, so I had to apply this (as I’ve been planning to). I made a small, but important change: Performing these updates can take a bit of time. The repeat executes iterations in series, which means completing it for many sensors will take some time and if the interval is short, a backlog could build up. There’s unfortunately no parallel directive for loops, but one can put the action in a script and call it in a non-blocking way. So, I did this:
script:
  update_entity:
    description: "Update an entity"
    fields:
      entity_id:
        description: "An entity ID"
        example: "binary_sensor.my_sensor"
    mode: parallel
    sequence:
      - service: homeassistant.update_entity
          entity_id: "{{ entity_id }}"
automation:
  - alias: "Update Ping Sensors"
    initial_state: true
      platform: time_pattern
      # minimum resolution
      seconds: '/15'
    variables:
      entities: >-
        {{ integration_entities('ping') }}
      total_seconds: "{{ now().timestamp() | int(0) }}"
      repeat:
        for_each: "{{ entities }}"
        sequence:
          if: "{{ total_seconds % (state_attr(repeat.item, 'scan_interval') | int(0)) == 0 }}"
          then:
            # non-blocking call: fire these off in parallel (script also allows parallel execution)
            - service: script.turn_on
                entity_id: script.update_entity
                variables:
                  entity_id: "{{ repeat.item }}"
