2023.8: Translated services, events, and wildcards!
Does 23.8.1 have release notes?
Yes Release 2023.8.1 Ā· home-assistant/core Ā· GitHub
My experience is that ignored updates come back every once in a while. It would be good if ignored repairs function similarly.
Ok. It us d to be in the blog post.
I canā€™t explain why it is not, perhaps the update person is a little busy.
I think you should be here PSA: MQTT Name changes in 2023.8
So you didnā€™t read the first comment in this thread which is brightly highlighted and explains everything about this?
The problem is that pinned comment doesnā€™t show pinned on the release notes page 2023.8: Translated services, events, and wildcards! - Home Assistant which is what is linked from the UI when you do the update.
The text on the release note really does need an update to be a little clearer. After spending several minutes it seems all will be good in Sep when I can update zigbee2mqtt but this change is going to worry a lot of people unnecessarily, which wouldnā€™t be the case if the patch notes explained it better (or even better had it be deferred for a month)
Now that sentence triggers have been improved, could someone explain to me the differences and benefits of sentence triggers vs adding custom sentencesā€¦? When to use which?
Custom sentences use sentence triggers. So what your asking really doesnā€™t make sense.
had the same problem but the new update 2023.8.1 fixed that, thank you for fixing !!
Is anyone aware if the TP-Link Kasa Smart problems have been fixed in 2023.8.1? Just checking before I update.
According to the post right above yours it was fixed.
I hope this event entity will be added to the KNX integration soon. It could simplify many thingsā€¦
:smiley: :crazy_face: :rofl: :rofl: Love it :rofl:
Thanks fro pointing out the obvious.
Can confirm that the TP-Link Kasa Smart problems have been fixed in 2023.8.1.
Thanks to the HA Team.
Iā€™ve just updated to 2023.8(.1) from 2023.7(.x) and all went okay.
Iā€™m glad @petro had issued his advice because even after reading the Breaking Changes in the release notes I would not have known what to do (or what not to do). Iā€™m also glad Iā€™d seen the issue with the Workday sensor as I could have missed this. I would have liked to see a Repair for this.
Anyway, now itā€™s time to play with the sentance wildcards!
Thanks everyone! :slight_smile:
Tuya integration and ā€œReolink Ip Cameraā€ no longer works. Fixed by reverting to 2023.7.1
Both work just fine
The iCloud CalDav stopped working after update. All calendars disappeared.
Reverting didnā€™t fix the problem. Logs and github fix problems.
