2024.9: Sections go BIG
Maybe you have some overlap/duplicates in what you measure individually?
Good catch. That was an empty link in the TOC, I removed it. Noteworthy stuff is under integrations sub-header.
I guessed it’s a template thing. And I just needed a new - admin approved, what a great bonus - proof that I read the release notes (usually twice) :wink:
Can it be a rounding error?
Upgrading before the release live broadcast , that’s new …
There is a functionality for changing the faulty in dev tools - statistics.
But for me, for my case, the DB was updated but the bar graph was not.
I clocked the August to Yale integration change for my Connexis lock. No biggie there.
Seems the Yale Smart Living Integration for my alarm and Key Fre Connected lock is borked by the update - in process on github. I’d suggest anyone using it to hold fire if you need it!
Just for the wider sections, this update is incredible! Thank you soooo much!
Edit: guess who just updated his dashboards with a column_span option! :smiley:
Hi. I have seen this before on previous updates. In my case, the problem seems to resolve itself, usually within an hour. Not sure if the same will happen in your case …
extrem nice update, big fan of the untracked energy dashboard. Would be great if its also included in the individual devices total usage view :slight_smile:
Whoohoo! Was waiting for the wider sections, thanks!! This will be the moment to convert my existing dashboards :tada:
Currently I am using my Yale lock with August integration. In core version 2024.9 they ask to replace August integration with the Yale integration. I am trying to configure the Yale integration but none of the options work with my current username and password. Is there a problem?
Same problem here, can’t log into the Yale Home integration. My guess is that it may be locale based - in most of the world, other than North America (or maybe just USA?), people were migrated in 2023 from the Yale Access app to the Yale Home app, which imported their login information from Yale Access as part of the migration, but which I gather is a separate system.
However, for some reason that is completely unclear to me, USA/North America is still on Yale Access, and we can’t download the Yale Home app, or migrate accounts.
There may be some other way to migrate, but I wasn’t able to determine it from Yale’s documentation.
Are you selecting the correct Yale integration?
For me, this worked without issues:
I can’t seem to adjust the new Section Width for existing sections with cards in them for some reason, it works only for new blank sections.
Adding column_span: 2 manually via yaml works fine however.
You missed to mention new UI configuration for LCN integration.
…I was awaiting for a while for this one :wink:
I tried both “Yale” and “Yale Home” from the list, and both seem to direct to the same login flow (below), and neither accept my usual Yale Access account info, which works on both August and Yale Access apps.
What region of the world are you in? It seems some regions may have been migrated to the Yale Home accounts, and other regions (USA/NA) are still on Yale Access only.
I tried them all and none accept my username and password??? I reinstalled the August integration and it works.
Nice! Good stuff. Finally was confident enough to convert all my Views into Sections.
The only thing missing now is:
  1. The ability to lock position of sections
    (Force browser/devices to work around cards instead of other way around.)
  2. Move 2 sections in a vertical space.
    (For example: 3 sections. 2 columns. #1 = 20 items. #2 - 5 items. #3 = 5 items. #3 will always be under #20)
Thats what I’m thinking, too. I can update records in DB, but I’ll need to recalculate the graph for the last 24 hours. Could be handled by some magic inside that I’m not aware of.
