I clocked the August to Yale integration change for my Connexis lock. No biggie there.
Seems the Yale Smart Living Integration for my alarm and Key Fre Connected lock is borked by the update - in process on github. I’d suggest anyone using it to hold fire if you need it!
Hi. I have seen this before on previous updates. In my case, the problem seems to resolve itself, usually within an hour. Not sure if the same will happen in your case …
Currently I am using my Yale lock with August integration. In core version 2024.9 they ask to replace August integration with the Yale integration. I am trying to configure the Yale integration but none of the options work with my current username and password. Is there a problem?
Same problem here, can’t log into the Yale Home integration. My guess is that it may be locale based - in most of the world, other than North America (or maybe just USA?), people were migrated in 2023 from the Yale Access app to the Yale Home app, which imported their login information from Yale Access as part of the migration, but which I gather is a separate system.
However, for some reason that is completely unclear to me, USA/North America is still on Yale Access, and we can’t download the Yale Home app, or migrate accounts.
There may be some other way to migrate, but I wasn’t able to determine it from Yale’s documentation.
I tried both “Yale” and “Yale Home” from the list, and both seem to direct to the same login flow (below), and neither accept my usual Yale Access account info, which works on both August and Yale Access apps.
What region of the world are you in? It seems some regions may have been migrated to the Yale Home accounts, and other regions (USA/NA) are still on Yale Access only.
Thats what I’m thinking, too. I can update records in DB, but I’ll need to recalculate the graph for the last 24 hours. Could be handled by some magic inside that I’m not aware of.
Is the background picture you use on the youtube stream available? Would be nice to use that in my new (big) sections dashboard
edit: I should not use direct names for questions, removed this
Super excited to see the Roth Touchline SL integration.
Sadly at first try I get an error:
Source: config_entries.py:604
First occurred: 23:21:55 (4 occurrences)
Last logged: 23:34:15
Error setting up entry [my_user_name] for touchline_sl
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 604, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/touchline_sl/__init__.py", line 29, in async_setup_entry
TouchlineSLModuleCoordinator(hass, module) for module in await account.modules()
File "/usr/local/lib/python3.12/site-packages/pytouchlinesl/touchlinesl.py", line 66, in modules
data = await self._client.modules()
File "/usr/local/lib/python3.12/site-packages/pytouchlinesl/client/client.py", line 98, in modules
return [AccountModuleModel(**m) for m in resp]
File "pydantic/main.py", line 341, in pydantic.main.BaseModel.__init__
pydantic.error_wrappers.ValidationError: 1 validation error for AccountModuleModel
tag
none is not an allowed value (type=type_error.none.not_allowed)
I am using the exact same username and password I use to log into roth-touchlinesl.com and the documentation doesn’t seem to be that good yet, so I’m not sure what to do from here?
