Currently I am using my Yale lock with August integration. In core version 2024.9 they ask to replace August integration with the Yale integration. I am trying to configure the Yale integration but none of the options work with my current username and password. Is there a problem?
Same problem here, can’t log into the Yale Home integration. My guess is that it may be locale based - in most of the world, other than North America (or maybe just USA?), people were migrated in 2023 from the Yale Access app to the Yale Home app, which imported their login information from Yale Access as part of the migration, but which I gather is a separate system.
However, for some reason that is completely unclear to me, USA/North America is still on Yale Access, and we can’t download the Yale Home app, or migrate accounts.
There may be some other way to migrate, but I wasn’t able to determine it from Yale’s documentation.
I tried both “Yale” and “Yale Home” from the list, and both seem to direct to the same login flow (below), and neither accept my usual Yale Access account info, which works on both August and Yale Access apps.
What region of the world are you in? It seems some regions may have been migrated to the Yale Home accounts, and other regions (USA/NA) are still on Yale Access only.
Thats what I’m thinking, too. I can update records in DB, but I’ll need to recalculate the graph for the last 24 hours. Could be handled by some magic inside that I’m not aware of.
Is the background picture you use on the youtube stream available? Would be nice to use that in my new (big) sections dashboard
edit: I should not use direct names for questions, removed this
Super excited to see the Roth Touchline SL integration.
Sadly at first try I get an error:
Source: config_entries.py:604
First occurred: 23:21:55 (4 occurrences)
Last logged: 23:34:15
Error setting up entry [my_user_name] for touchline_sl
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 604, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/touchline_sl/__init__.py", line 29, in async_setup_entry
TouchlineSLModuleCoordinator(hass, module) for module in await account.modules()
File "/usr/local/lib/python3.12/site-packages/pytouchlinesl/touchlinesl.py", line 66, in modules
data = await self._client.modules()
File "/usr/local/lib/python3.12/site-packages/pytouchlinesl/client/client.py", line 98, in modules
return [AccountModuleModel(**m) for m in resp]
File "pydantic/main.py", line 341, in pydantic.main.BaseModel.__init__
pydantic.error_wrappers.ValidationError: 1 validation error for AccountModuleModel
tag
none is not an allowed value (type=type_error.none.not_allowed)
I am using the exact same username and password I use to log into roth-touchlinesl.com and the documentation doesn’t seem to be that good yet, so I’m not sure what to do from here?
my MariaDB database has a recorder set up for 900 days. Size is about 12GB
this migration is running for the fifth time, it fails because the available disk space is not enough. Looks like it requires at least the same 12GB to complete the migration.
Why? Just because it needs lot of space?
Or migration will take lot of time & will need a lot of free space?
I would agree that it could be not crucial to know EXACT (not statistical) value of some “temperature” on 01.01.2022; but in SOME scenarios like “show me my track in London from 01.01.2020” could be useful.
