What has changed with the nest integration?
Clicking the link leads to a page not found.
Hive still works for me
This - would for me provide a bit more context of how much the untracked energy is vs other measured devices - the vertical graph is great, but the more aggregated horizontal view also helps a lot imho.view also helps a lot.
Maybe voting for Add 'Unmonitored Energy' to energy dashboard individual devices - #5 by TRiSS is a good idea - should be a lot easier now it’s already added to the detail view.
There is an integration that does exactly that for Vienna smart meters:
It’s fairly complicated, and only the statistics can be updated, not the entity value. But it does work.
I know you guys created “untracked energy” that shows in the dash board - but I was wondering my self whenever you buys created an untracked energy AND untracked power entities that can be used in other people scripts ?
Asking because I’ve got those entities and I’m just wondering my self if I’m duplicating the data / can I migrate the history to the new entity.
Mine still do:
Thanks, restarting and forcing cache refresh fixed it.
Thanks for the nice update.
But I have a problem with Yale integration. I get an error if I start det integration. The error is “Config flow could not be loaded: {“message”:“Invalid handler specified”}”.
If there anyone the can tell me, how I can fix it?
@salzrat thank you so much! Will look into that and see what I can do to import it to my energy integration
Any idea how to apply the grid_columns: full
format to custom cards? e.g. I have this working for stock weather card, but can’t find a way to implement on a custom apex chart card.
type: sections
sections:
- type: grid
cards:
- show_current: true
show_forecast: false
type: weather-forecast
entity: weather.forecast_home
forecast_type: daily
secondary_info_attribute: humidity
layout_options:
grid_columns: full
- show_current: false
show_forecast: true
forecast_type: hourly
layout_options:
grid_columns: 4
grid_rows: 2
show_forecast: true
layout_options:
grid_columns: 4
grid_rows: 2
column_span: 4
title: Weather
- type: grid
cards:
- type: custom:apexcharts-card
...code removed for brevity...
column_span: 4
I tried adding the below code snippet , but it results in an apexcharts error
layout_options:
grid_columns: full
Hi, I need Sections go SMALL I have a dashboard on a 7’ tablet with 3 columns defined. but in the tablet, the 3rd column is moved to a new row. I made the cards inside the sections smaller but that just leaves bigger gaps between the section columns. Any way to fix?
Am I only the one having this issue? Tried clearing cache, but same issue.
I have a 4-core Intel machine with an SSD and haven’t had any problems with Home Assistant + MariaDB until today.
The only thing is that my VM keeps growing. To perform this migration it went from about 56 to 72GB.
I like to have yearly graphs and think that someday historical data may become useful for AI or other research.
Thanks for your answer. Love home assistant!
I wonder if there will ever be a victron integration
I have an automation that sets an alarm to my phone when you say “Set an alarm in X minutes”, I have exposed it to LLMs, but it does not work with any, seems like they do not know how to replace the X or something.
I tried with creating a script that sets the alarm in one minute, so they use the timing functionality, but it does not seem to work neither, sometimes it answers that it is not possible to set timer for the device, or they set the alarm in one minute, so they just run the script.
You’ll need to create a set of custom intent scripts to get that to work.
FYI you should never have to restart for frontend changes to take effect. Only refreshing cache. The frontend lives in your browser.
I have some automations which play sound (MP3 Media) on Apple Homepod mini. After the update no more sound playing (even if it says „Action run successfully“).
I restored my daily backup and it works fine again.
The issue is reproduceable: I did the update again —> no sound
Restored my backup again: works fine
Rgds,
Joop
UPDATE: I just installed 2024.9.1 and issue no longer exists
Great thanks for your help Chris I’m glad Hive still works for you, and thanks for being such a helpful human being. As mentioned it works for me too as I rolled back.
