Hi Ingrid
thanks for this project! One question about buienalarm, the graph remains at 0, so no data is shown in the graph.
The rain radar does work.
any idea what this is related to?
the sensor works and gives data in the attributes:
Hi Ingrid
Hi 1mfaasj,
This is just the data that is published by buien alarm, they predict it wonât rain
This is the data on their website. No rain!
And this is from the buien radar website, they do predict light rain.
â Ingrid
ah I thought if one expects it, so does the other. but then it will just work I guess. thanks for your quick response!
And here are some styles:
Fixing the padding or the card, the title is now the same as others. And the tooltip is a little more compact.
style: |
ha-card #graph {
margin: 3px 10px;
ha-card .apexcharts-canvas * {
font-family: var(--ha-card-font-family, inherit) !important;
ha-card #header__title {
color: var(--ha-card-header-color, --primary-text-color);
font-size: var(--ha-card-header-font-size, 24px);
padding-top: 10px;
font-weight: normal;
ha-card .apexcharts-tooltip * {
line-height: 0.5;
font-size: 12px !important;
Iâm watching the buienalarm sensor for a week now but it stays on 0.
Itâs quite rainy today and when I look at Buienalarm Den Haag - Weersverwachting en buien radar - Buienalarm it shows data.
Am I missing something?
command_line:
#buienalarm
- sensor:
name: weather buienalarm direct
unique_id: weather_buienalarm_direct
command: python3 -c "import requests; import json; import random; dataRequest = requests.get('https://cdn-secure.buienalarm.nl/api/3.4/forecast.php?lat=52.07667&long=4.29861®ion=nl&unit=mm%2Fu',headers={'Cache-Control':'no-cache'}).text; dataRequest = dataRequest.replace('\r\n',' '); data = '{\"data\":'+dataRequest+'}'; print(data);"
json_attributes:
- data
value_template: "last_changed: {{states.sensor.weather_buienalarm_direct.last_changed | default(now())}}"
scan_interval: 240 #4min
The sensor works I guess:
So it turns out my ânewâ data source has been stale for over 2 years .
Will have to go back to finding a good data source. Up to now I only found webscrapers, no data end-pints.
During Christmas break, Iâm going to (try to) find out which source the app on my phone uses. Nice project
To be continued.
â Ingrid
Hi everyone,
I tried to make buienradar gspgadget to work in Homeassistant but until now I didnât manage to make it a succes.
website (https://gpsgadget.buienradar.nl/data/raintext?lat=51.46&lon=3.55)
Iâve got this sensor in my command_line.yaml
- sensor:
command: python3 -c "import requests; import json; import random; dataRequest = requests.get('https://gpsgadget.buienradar.nl/data/raintext?lat=51.46&lon=3.56&c='+str(random.randint(0,999999999999999))).text; dataRequest = dataRequest.replace('\r\n',' '); data = '{\"data\":\"'+dataRequest+'\"}'; print(data);"
json_attributes:
- data
value_template: "last_changed: {{states.sensor.weather_buienradar_direct.last_changed | default(now())}}"
scan_interval: 300
I looked around on this forum and found and tweaked a little bit in the template-editor
{% set value = state_attr('sensor.buienradar_gpsgadget','data') %}
{% set data = value.split() %}
{% set value = namespace(list=[]) %}
{% for n in data %}
{% set value.list = value.list + [{ "time": n.split('|')[1], "rain": ( 10** (( n.split('|')[0] | float - 109 ) / 32 )) | round(1) }] %}
{% endfor %}
{% set time = value.list | map(attribute = "time") | list | to_json %}
{% set rain = value.list | map(attribute = "rain") | list | to_json %}
{{ time.replace('"','')}}
{{ rain }}
I got the next result, 2 list arrayâs
[23:15,23:20,23:25,23:30,23:35,23:40,23:45,23:50,23:55,00:00,00:05,00:10,00:15,00:20,00:25,00:30,00:35,00:40,00:45,00:50,00:55,01:00,01:05,01:10]
[0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0,0.0]
Can anybody help how to go on with this result to make it work in some bar-graph?
Thanks in advance
Hi Eric,
Welcome to the topic. The problem is that https://gpsgadget.buienradar.nl/ datasource is a bit wobbly.
If youâre interested in learning: check this post.
I am currently testing new datapoints.
Kind regards,
â Ingrid
Hi Ingrid,
Thanks for your reply, I watched this post before and saw your journey on this project. But the apexcharts are a bit slow on my opinion
I must admit that https://gpsgadget.buienradar.nl/ was not stable and reliable in last November but I use it for 3 years now on a little screen. I build it based on a Raspberry Pi Zero and a Display HAT Mini from Pimoroni and it works fine for 99% of the time. But I tried to make it work in Homeassistant now but it seems a bit complicated for someone who doesnât have a programming background.
Anyway, thanks for your reply and Iâll keep an eye on this post.
Hi everyone,
Another day, another data source.
I decided to go back to the drawing board, and rewrite the sensors with the most stable data source I could think of, the ones used by their apps. These are cdn.buienalarm.nl and graphdata.buienradar.nl.
The buienradar api was updated to version 3.0, thats why the previous sensor wasnât working.
This is the â yet again â updated version of a two-hour forecast chart, blocks of 5 minutes. I increased the scan interval to 150 seconds = 2,5 minutes.
â Ingrid
Update 27-11-2025
This post is archived. See first post for 2h configuation.
STEP 1
Get the latitude and longitude of your location.
STEP 2
Set up sensors in your configuration.yaml file.
Buienalarm
<lat-2-decimals> and <lon-2-decimals> to your values.command_line:
- sensor:
command: python3 -c "import requests; dataRequest = requests.get('https://cdn.buienalarm.nl/api/4.0/nowcast/timeseries/<lat-2-decimals>/<lon-2-decimals>',headers={'Cache-Control':'no-cache'}).text; dataRequest = dataRequest.replace('\r\n',' '); print(dataRequest);"
unique_id: 1704013893
json_attributes:
- data
value_template: "last_changed: {{states.sensor.weather_buienalarm_minutes.last_changed | default(now())}}"
scan_interval: 150
Buienradar
<lat-3-decimals> and <lon-3-decimals> to your values.command_line:
- sensor:
command: python3 -c "import requests; response = requests.get('https://graphdata.buienradar.nl/3.0/forecast/geo/RainHistoryForecast?lat=<lat-3-decimals>&lon=<lon-3-decimals>',headers={'Cache-Control':'no-cache'}).text; data = '{\"data\":'+response.replace('\r\n',' ')+'}'; print(data);"
unique_id: 1704016555
json_attributes:
- data
value_template: "last_changed: {{states.sensor.weather_buienradar_minutes.last_changed | default(now())}}"
scan_interval: 150
STEP 4
To display the graph you need the ApexCharts card.
The data_generator starts with some JS removing timepoints that have already passed.
type: custom:apexcharts-card
series:
- entity: sensor.weather_buienalarm_minutes
color: rgb(3, 170, 244)
data_generator: >
var input=entity.attributes.data;var out=[];input.map((entry,index)=>{if(new Date(entry.time)>new Date()){out.push([new Date(entry.time),entry.precipitationrate])}});return out.slice(0,22);
- entity: sensor.weather_buienradar_minutes
color: rgb(3, 150, 244)
data_generator: >
var input = entity.attributes.data.forecasts;var out=[];input.map((entry,index)=>{console.log(new Date(entry.dateTime));if(new Date(entry.dateTime)>new Date()){out.push([new Date(entry.dateTime),entry.dataValue])}});return out.slice(0,22);
header:
show: true
title: 2h precipitation forecast
span:
start: minute
graph_span: 2h
all_series_config:
stroke_width: 3
unit: mm/u
type: area
opacity: 0.2
show:
offset_in_name: false
apex_config:
chart:
height: 250px
legend:
show: false
xaxis:
tooltip: false
border:
show: true
labels:
format: HH:mm
rotate: -45
rotateAlways: true
style:
fontSize: 10px
yaxis:
- min: 0
max: |
EVAL:function (max) {
window.chart2u_max = (Math.round(max*2)/2) + 0.5;
return window.chart2u_max;
tickAmount: 5
title:
text: rain (mm/u)
grid:
xaxis:
lines:
show: true
tooltip:
enabled: true
shared: true
x:
show: true
format: ddd d MMM HH:mm
'y':
formatter: |
EVAL:function (y) {
return y.toFixed(1)
annotations:
position: back
yaxis:
- 'y': 0.4
label:
text: 'EVAL:(window.chart2u_max > 0.4 ? ''Light'' : '''')'
style:
background: '#666'
color: '#FFF'
borderColor: 'EVAL:(window.chart2u_max > 0.4 ? ''#000'' : ''none'')'
- label:
text: 'EVAL:(window.chart2u_max > 2 ? ''Medium'' : '''')'
style:
background: '#666'
color: '#FFF'
'y': 2
borderColor: 'EVAL:(window.chart2u_max > 2 ? ''#000'' : ''none'')'
- label:
text: 'EVAL:(window.chart2u_max > 5 ? ''Heavy'' : '''')'
style:
background: '#666'
color: '#FFF'
'y': 5
borderColor: 'EVAL:(window.chart2u_max > 5 ? ''#000'' : ''none'')'
card_mod:
style: |
ha-card #graph {
margin: 3px 10px;
padding-top: 10px;
line-height: 0.5;
Hi Ingrid,
Thanks for the update !!!
I think the URL in the sensor has to be:
https://graphdata.buienradar.nl/3.0/forecast/geo/RainHistoryForecast?lat=xx.xxx&lon=x.xxx
Is there also an (3.0) update for the 24hour version?
Typo, thanks, changed it. Found another one in the annotations.
And good question, the answer is probably yes.
These will have to wait, now itâs time for champagne and âolliebollenâ.
Hi all,
There are new data sources for the 24h sensors.
I will update the original post.
â Ingrid
Installed and looks fine.
Thanks Ingrid!
Nice work indeed, and I managed to get it going over here as wellâŚ
Maybe a bit off-topic, but is it now also possible to calculate the integrated amount of rainfall expected for the coming 24h, so that I can use that one to determine whether or not to turn on the sprinklers in my garden?
Certainly @Jeroen.Rommers , if you mean just a simple addition or the precipitation in mm per hour.
If you want something like area-under-the-curve, more math is required.
{{ state_attr('sensor.weather_buienradar_hours', 'data').forecasts
| sum(attribute='dataValue')
{{ state_attr('sensor.weather_buienalarm_hours', 'data')
| sum(attribute='precipitationrate')
For a great sensor I would combine rate per 24 hours, and max rate.
{{ (state_attr('sensor.weather_buienradar_hours', 'data').forecasts
| max(attribute='dataValue')).dataValue | float
{{ (state_attr('sensor.weather_buienalarm_hours', 'data')
| max(attribute='precipitationrate')).precipitationrate | float
Kind regards,
- Ingrid
Hi Ingrid, Am very happy with you sensors and chart. But recently the https://cdn.buienalarm.nl/api/4.0/nowcast/timeseries/ url seems to have stopped working, The sensor report unavailable. No response from buienalarm. Did you notice the same? Thank.
I migrated to GitHub - jdeneef/ha_buienalarm: homeassistant restful sensors and plotly graph for precipitation api's
Note that you might have to set the timeout to 30ish seconds
Edit: you donât have to migrate I think. Increasing the timeout seems to be enough. It just takes a long time before it responds.
Every once in a while they update their API, and as very unofficial user, we are not informed about these changes.
Thanks for letting me know. I will update in a few days.
Kind regards,
I think they changed this API also:
2025-07-21 16:47:30.263 ERROR (MainThread) [homeassistant.components.command_line] Timeout for command: python3 -c âimport requests; response = requests.get(âhttps://graphdata.buienradar.nl/3.0/forecast/geo/Rain24Hour?lat=51.845&lon=4.543â,headers={âCache-Controlâ:'no-cacheâ}).text; data = â{"data":â+response.replace(â\r\nâ,â â)+â}'; print(data);â
2025-07-21 16:47:30.264 WARNING (MainThread) [homeassistant.components.command_line] Empty reply found when expecting JSON data
2025-07-21 16:47:30.264 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: âNoneâ has no attribute âforecastsâ when rendering â{% set forecasts = state_attr(âsensor.weather_buienradar_hoursâ, âdataâ) %} {% set ba = forecasts.forecasts | selectattr(âdataValueâ, âdefinedâ) | map(attribute=âdataValueâ) | map(âfloatâ) | sum %} {% set alarms = state_attr(âsensor.weather_buienalarm_hoursâ, âdataâ) %} {% set br = alarms | selectattr(âprecipitationrateâ, âdefinedâ) | map(attribute=âprecipitationrateâ) | map(âfloatâ) | sum %} {{ âonâ if (ba != 0.0 or br != 0.0) else âoffâ }}â
2025-07-21 16:49:45.860 WARNING (MainThread) [homeassistant.components.command_line] Unable to parse output as JSON: {âdataâ:
Access Denied
You donât have permission to access âhttp://graphdata.buienradar.nl/3.0/forecast/geo/RainHistoryForecast?â on this server.
Reference #18.57781202.1753109385.194b72cd
https://errors.edgesuite.net/18.57781202.1753109385.194b72cd
