Can you please share a picture of 2n2222, the one you are using so that I could place online order same one?
Thanks,
Thanks,
The 2n2222 is so incredibly generic, you really canāt go wrong with ordering one. Yours might look different but itāll work the same way. Donāt hesitate, just go for it
Thank you, Iāll buy this
Iāve been using this with great success so far, thank you very much for developing and releasing this.
One thing Iām stuck on has been programming some ācloningā 433MHz remote controls I have. Iāve bought a whole heap of them to use as switches around the house and need to program the buttons on each to all have an individual (random is fine). They ācloneā by listening to the commands sent by another remote with the button held down for a few seconds so it repeats the command.
Iāve tried changing the pulse length parameter in the OpenMQTTGateway to a few seconds, and putting a loop in the send command section but either way it just causes it to crash.
Is there a better way for me to program these? Randomly generated strings would be great as I have 20 of them with 4 buttons each to doā¦
Sorry but I donāt understand this part?
As your remote controls paced around the house only listening or also emitting?
What do they control?
Sorry iāll explain that a bit better. The remotes clone a signal being transmitted by another source. If I hold down the button of another 433MHz remote/source while programming a button on my new remotes, they will receive that code, store it, then re-transmit when I press the button on the new remote.
My new remotes will be only transmitting, theyāre basically just going to be wireless toggle commands for my lights. But to program them, they listen/receive temporarily so I need to transmit a repeated signal for a few seconds to allow this to happen.
These remotes here are what Iām referring to::
You could try to increase RF_EMITTER_REPEAT into user_config.h to 40 or more. It will repeat the RF signal 40 times. Try yo do it first with standard parameter ; donāt specify any pulselength or protocol. Just send your signal to home/commands/MQTTto433
Iāve given that a go, unfortunately setting it any higher than 40 (say even 50) causes the arduino to crash and restart. Havenāt been able to work out why so starting to strip the code down to bare essentials to see if I can get around the crashing.
@mynameisdaniel Ive made automations to repeat the signal for x amounts of minutes depending on witch state my light/switch is.
Example:
- id: unique38
alias: Repeat signal to 433mhz gateway
platform: time
minutes: '/5'
condition:
condition: and
conditions:
- condition: state
entity_id: input_boolean.433herhalen
state: 'on'
- condition: state
entity_id: light.keukenlamp
state: 'on'
- service: light.turn_on
Thank you for the very nice project. Just want to ask, do you have sample yaml config for BT gateway?
No I donāt have, as this implementation is quite new I will be interested by some feedback
I donāt see any response from the Arduino serial monitor after power on/off on my Skybeacon. Is this expected? I tried to subscribe to this topics āhome/BTtoMQTT/#ā & āhome/BTtoMQTTā w/o luck.
Yes you should see mac adress on the serial monitor and with mqtt. Do you have the message saying āConnection OK to HM-10ā in the serial monitor when you power the arduino?
So as to debug most of the time I subscribe to all the topic with:
sudo mosquitto_sub -t +/# -v
According to the hm10 data sheet if you use AT+SHOW1 you should get the device name as well which will be handy as iphone keeps changing mac, I have tried it but doesnāt seems to get it working, have any of you tried it before?
Thanks for the info I will try that, I have repopened the corresponding request:
Yes I see āConnection OK to HM-10ā in my serial monitor. The BLE Gateway not publishing anything. Might not even detect my skybeacons.
Are your skybeacons paired and connected with something ?
Could you install a beacon simulator to your smartphone and see if the gateway detect it?
And at final what is your hm10 firmware version
After upgrading the HM-10 fw to V550. I was able to detect the Skybeacon. Thanks, Cheers!
Thanks for the feedback, what was your previous version ?
