433mhz, infrared IR to and from MQTT on ESP8266
Try to go to a minimalist approach in this case, put only your IR emitter or a normal led and upload a sample sketch and see if you see your led blinking.
Try also in another board
I just changed the board - same - I try with sketch
oo yee skectch is working - little LED blinking on IR Transmitter module, and I left the IR Receiver module as well powered and on the module blinking little red LED as well which means that it takes same signal.
but - what’s next ?
what is the pin config on your irremote sketch?
on GPIO pin (D2) like in sketch by default - ok I change it to PIN16 and see what happens
yes it’s works on PIN 16 as well
Can I change the sketch with my LED remote info
home/IRtoMQTT/protocol 3
home/IRtoMQTT/bits 32
home/IRtoMQTT 16712445
and see - that the LED command ( on/off) works in sketch on not ?
yes but you don’t need to change the sketch, all the infos are into the wiki
little help :wink: or some directional or seems that the module itself works, but not with MQTT gateway ;(
Good day, looking for some help. I flashed the Sonoff RF Bridge and can see the gateway reporting as follows:
pi@hassbian:~ $ sudo mosquitto_sub -u username -P password -t home/# -v
home/OpenMQTTGateway/LWT Online
home/OpenMQTTGateway/version 0.5
However, when I activate some door sensors I get nothing. I tried with some Telldus 433 sensors and got nothing. Then tried with the sonoff door sensors and I see the RF red light on the bridge flashing, but I still see nothing on the console.
Any guidance is much appreciated.
And I still don’t get my senders to work :confused:
I changed on the sketch - in the loop where is NEC irsend and but my number
void loop() {
Serial.println("NEC");
irsend.sendNEC(16712445, 32);
delay(2000);
and now the sketch switching my led on and off, but I still don’t get to work in MQTT gateway
Could you post the command you are sending ti the broker and what you see in the serial monitor ?
With MQTT Gateway the same -
from terminal in the raspberry I send
mosquitto_pub -h 192.168.200.205 -p 1883 -u user -P pass -t home/commands/MQTTtoIR -m 16712445
because without the login
mosquitto_pub -t home/commands/MQTTto433 -m 1315156
says the authentic problem –
in MQTT monitoring I show the command coming IN
home/command/MQTTtoIR/ 16712445
but from serial monitor windows is empty like nothing is coming in
If you see in your mqtt monitoring
It is more likely you sent with a command with a slash at the end of the subject that should not be. Are you sure you are sending
and not:
mosquitto_pub -h 192.168.200.205 -p 1883 -u user -P pass -t home/commands/MQTTtoIR/ -m 16712445
When I send
MQTT= home/command/MQTTtoIR 16712445
When I send
MQTT = home/command/MQTTtoIR/ 16712445
hmm, try maybe with
mosquitto_pub 192.168.200.205 -p 1883 -u user -P pass -t home/commands/IR_NEC -m 16712445
And see if it process it on the serial monitor.
If not please paste a screenshot of what you see on the serial monitor and on mosquitto.
More info here in case you have not seen it
First when I plug the NOD and serial monitor shows all connecting
HAWiFi
OpenMQTTGateway mac:
2C:3A:E8:43:82:E2
OpenMQTTGateway ip:
192.168.200.169
WiFi ok
MQTT connection…
Connected to broker
Subscription OK to the subjects
after that I testing IR reader and press the LED remote on/off
Rcv. IR
8936,4514,518,612,518,584,544,584,518,610,518,584,544,584,518,610,518,582,546,1710,518,1710,518,1710,544,1710,518,1710,518,1710,544,1710,518,1710,518,610,518,582,546,584,518,608,518,584,546,582,520,1708,548,580,546,1682,546,1710,520,1710,518,1710,544,1710,520,1710,520,608,520,1708,520
isAduplicate
Adv data IRtoMQTT
Sending IRtoMQTT
16712445
IRtoMQTT OK
Hey I got a callback
Storing signal
Min ind:
0
store code :
16712445/188060
Col: val/timestamp
0:16712445/188060
1:0/0
2:0/0
3:0/0
4:0/0
5:0/0
6:0/0
7:0/0
8:0/0
9:0/0
10:0/0
11:0/0
Data stored
16712445
mosquitto_sub from terminal shows
now I try send from terminal command
serial - is empty
mosquitto terminal
home/commands/MQTTtoIR 16712445
I send
serial still nothing
terminal
home/commands/MQTTtoIR/ 16712445
and your example
that’s command don’t works without mosquitto_pub “-h”
when use this with -h the serial still nothing and mosquito terminal
home/commands/IR_NEC 16712445
seems that commands don’t going out – they don’t send trough GPIO16 port :confused
Could you shre me your ir config and user config without credentials please
Actually all conf is like by default
user_conf.yaml (5.5 KB)
here is my user con I renamed it with yaml prefix ) it’s only way to uload the file
IR_config.yaml (3.0 KB)
and IR config as well
As a first approach for debugging I suggest to comment:
  #define ZgatewayRF
  #include "config_RF.h"
  #define ZgatewayBT
  #include "config_BT.h"
But the most important thing is that you changed home to home2:
Example:
  #define subjectMQTTtoX "home2/commands/#"
In this case you should put home2 in your mosquitto commands.
